Nitrogen in tires....(Warning. Unscientific test inside)
Discussion in 'Technical Chat' started by chris4x4, Jul 1, 2011.
  1. Jul 1, 2011 at 2:50 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A friend of mine, and myself, decided to see whats what in the world of Nitrogen vs. "Air". First, The most pure Nitrogen we could find from local tire shops, was only 95% pure Nitrogen. Unless a shop gets its Nitrogen from a local gas company, then the machines they use to get the pure nitrogen arent as "pure" as people think. Anyway, Upon researching this N2 use in tires, vs. "air", we came accross some info. Seems the reason regular air expands more in heat, is due to the moisture content. Being as he has an air "dryer" on his compressor, we decided to cunduct our own little experiments. Filling 3 20# high pressure tanks with different gasses. 1 with Nitrogen from a local gas company, 1 with Co2, and the other with regular "Off the shelf" Air. All three tanks were filled to 150 psi, as that was what his compressor was set at, and we wanted to keep the pressures equal amoung the 3. The tanks were filled to 150 psi at 82*, then thrown in his freezer in his garage over night. The temp was 0*. The next afternoon, he checked the temps, and found they had all dropped the same. Then, He left them outside for a couple days. PSI was checked at 4 pm, and the tanks were 145*. PSI was the same accross the board. We are currently testing to see if his tires deflate, or stay in flated at the same psi's longer with N2 vs. Co2 vs. Air right now. Results should be ready in 30 days. Some people say that the larger molecules of the Co2, and n2 keep the psi more stable in tires, as teh pourus rubber allows air molecules to filter thru it more than does N2 or Co2. We'll see. Being that the moisture in the air can cause the tire psi to be less stable, I can see how N2 "might" have a benafit in more humid environments, but those that live in.....say, a Desert, arent going to see any benafits from N2. (IMHO). Now.....I know some people are going to say that using N2 reduces Corosion in the wheel. Fine. I agree. However, I have never seen a wheel fail due to any corosion in it. Could be my location......
  2. Jul 1, 2011 at 2:55 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Sir you need to get a hobby
    :anonymous:
  3. Jul 1, 2011 at 2:57 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    this IS his hobby-
  4. Jul 1, 2011 at 2:58 PM
    Jester243
    Dan
    Spokane, WA
    I thought his hobby was more blowing things up and lighting stuff on fire?
  5. Jul 1, 2011 at 3:00 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    im interested to hear the results. I know jeep guys who swear by nitrogen in the tires for permeation loss and also for less psi fluxuation at differing altitudes. personally, i think they just like to tell people they put N2 in their tires. great idea for a test btw.
  6. Jul 1, 2011 at 3:00 PM
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    No no no
    Its catching and releasing spiders:spy:
  7. Jul 1, 2011 at 3:00 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Hey Chris I am with you on this-never needed that crap in our tires till someone stuk it out there as the "it" thing. Besides-isnt air 78% nitrogen anyways?? So you're only increasing your nitrogen 20%
  8. Jul 1, 2011 at 3:01 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    No that his funtime-this is when he's thinkin about stuff:D
  9. Jul 1, 2011 at 3:05 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'm hoping this experiment will get to that point after the preliminary testing is done. :rasta:
  10. Jul 1, 2011 at 3:15 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Ironically, most TPMS sensor corrosion is cause by moisture in the air :D
    Only benifits of Nitrogen are:
    1) Less permeable through rubber.
    2) Less expansion and contraction (As Chris stated, more from moisture then anything). Also, Nitrogen technically DOES expand and contract less then PURE O2 (Notice the pure, the tests conducted in my textbooks mentioned this), but this effect is so small its neglegable. There is a ratio of nitrogen expantion table vs temperature in my Power engineering books.
    3) Nitrogen is an inert gas, meaning it doesn't burn. which means fuck all when your tire explodes in a real world environment. I actually once had a dodge salesmen try to tell me if my vehicle was ever on fire to the point that my tires would explode, that the nitrogen in them when they burst would not fuel the fire.... I laughed at him and said if my vehicle is on fire to the point of tires exploding, insurance will buy me a new one.
  11. Jul 1, 2011 at 3:17 PM
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    In a place like Charleston SC where the humidity is rediculous, I believe N2 does make a differance.
  12. Jul 1, 2011 at 3:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRC, THe TPMS sensors in the wheel (exposed parts) are plastic, or coated in plastic.
  13. Jul 1, 2011 at 3:18 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    YES, most people do not realize that--guess they want a few more bucks to put air in your tires--trying to justify the extra cost--WHAT A RACKET--
  14. Jul 1, 2011 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    THATS A DAM GOOD IDEA!!! Altitudes! I will check the PSI at 1100 feet, and again at 7500 feet, and see if there is much difference. i wont be able to do this right away, so give me time :)
  15. Jul 1, 2011 at 3:20 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Rent a plane for an afternoon and test at 40,000 ft :D
  16. Jul 1, 2011 at 3:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When someone has a Tacoma at that altitude, I'll consider a way to check the PSI.
  17. Jul 1, 2011 at 3:26 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Is that a challange?
  18. Jul 1, 2011 at 3:32 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Actually air has 78% nitrogen already so how could adding a measly 18% more nitrogen make a frikkin difference?
  19. Jul 1, 2011 at 3:38 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Don't forget the heat. A tire gets hot during driving and the gas is affected by the heat. That constant expansion is a key to using nitrogen over plain room air.
  20. Jul 1, 2011 at 3:38 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    But the dealerships are using it as a gimic. It is effective in airplane tires.
