Nitrogen in tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coffeesnob, Apr 19, 2010.
  1. Jul 5, 2010 at 11:48 AM
    #61
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I just found out my truck tires were filled with nitrogen when it was first unloaded at the dealership. That explains those green valve stem caps. My question now is if and whenever they need adjusted can I use air or do I have to deflate them all the way first of the nitogen?
  2. Jul 5, 2010 at 11:58 AM
    #62
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Its better to use nitrogen, but it doesn't matter. This came from the tire shop guy I deal with.
  3. Jul 5, 2010 at 12:23 PM
    #63
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can use air. The air around you is 78% nitrigen anyway.
  4. Jul 5, 2010 at 12:25 PM
    #64
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Has anyone asked how they fill the tire with nitrogen?
    Why is that important you may ask: well, air is 78% nitrogen already. So a tire just put on the rim is filled with air...22% "other stuff (mostly O2)". Pressure with even pure nitrogen and you still got "other stuff"; it's bad and it's still in there doing it's bad things.
    The only way to avoid it is to put it in a vacuum chamber first, back-fill it with nitrogen then pressurize it. Maybe NASCAR or an airline logistical service agency would have one to do it but I doubt seriously your local tire shop does.
    Oh..and the obvious thing to consider: it's 78% (MOSTLY) nitrogen in there even if only use air as usual.
    I buy the dry reasoning, cause then it don't matter that there's still some bad stuff in there if the goal is to keep moisture out over the life of servicing the tire's pressure.
  5. Jul 5, 2010 at 12:28 PM
    #65
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    about 21% is O2, and less than 1% is Co2
  6. Jul 5, 2010 at 12:39 PM
    #66
    ctxtaco
    ctxtaco Well-Known Member
    Austin, Texas
    2010 PreRunner SR5 Double Cab
    Black tube steps
    My dealer fills all their tires with nitrogen, checks them and fills whenever you come by, and will refill if you ever have a flat. I have noticed the pressure stays very constant with temperature changes. It's free to me, but I wouldn't pay extra to get it.
  7. Jul 5, 2010 at 12:44 PM
    #67
    buddywh1
    Philly PA
    07 DC SR5 4x4
    You're right: brain dead me didn't check that memory. But it makes my point even more valid: the more reactive of the gasses being oxygen.
  8. Jul 6, 2010 at 4:47 PM
    #68
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Regardless, here's something to think about.....
    Atmospheric pressure is 14.7psi(ish)
    Pumping tires to 30 psig, or 45 psi absolute, means you are only putting in 66% nitrogen, the rest is just plain air.
    Effectively you are only reducing the non nitrogen level to around 8%.
    It's a scam, and if you wasted your cash on it, get over it.......
    Dry air is as beneficial as Nitrogen, end of story.
    Reminds me of window etching and extended warranties.
  9. Jul 7, 2010 at 2:51 PM
    #69
    coffeesnob
    VA
    whats window etching?
  10. Jul 7, 2010 at 3:19 PM
    #70
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    IMO, it's a gimmick. As others have said, normal air is over 70% nitrogen anyway. As far as dry goes, compressed air as found in a tank has most of the moisture condensed out anyway. Pressure does that. Those that have air compressors know that you need to drain the condensation out of the tank regularly. I have a 30 gallon air compressor and live where the humidity is single digit and I still get a good cup of water out after about 3 refills. So what if a little moisture gets in the tire? I won't hurt anything. Also if you are trying to eliminate the oxygen inside the tire, what do you do to eliminate it on the outside? You wear a tire out long before any O2 has an effect on the rubber in the tire.
  11. Jul 7, 2010 at 5:22 PM
    #71
    Isthatahemi
    TRD OFF ROAD
  12. Jul 7, 2010 at 5:34 PM
    #72
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Now if they offered Helium - that would be a different deal all the way. I could lose some of my weightiness! ;)
  13. Jul 7, 2010 at 5:43 PM
    #73
    cjd141985
    cjd141985 Coonass
    Christopher
    Louisiana
    Toyota Tacoma Prerunner
    OEM Fog Lights, Towing Package, 1.5" Leveling Kit, Black Badges Mod, OEM Curise Control
    I have nitrogen in my tires and I know that the pressure of the tires doesn't chage due to weather, but as far as prolonging the wear of a tire I would say that nitrogen doesn't help at all.
  14. Jul 7, 2010 at 5:46 PM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what I have in my tires....My truck weighs 9#.....I push it around...
  15. Jul 7, 2010 at 5:55 PM
    #75
    HBMurphy
    Paul
    So California Coast
    None
    :) Do you talk in a high voice when you are driving it? :)
  16. Jul 7, 2010 at 5:56 PM
    #76
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only if one of my tires has a leak.
