Nitrogen recharge: When?
Discussion in 'Suspension' started by nvdeserted, Nov 26, 2010.
  1. Nov 26, 2010 at 10:19 AM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Howdy,
    I have some SAW 2.0 c/os and they just recently developed a clunk at the first tap of uptravel when hitting bumps.
    The ride is still good, seals look good, no leakage... time to recharge? or rebuild?
    I have plenty of experience dealing with dirtbike forks but none with nitrogen charging. Also, everything seems fine... except for the annoying clunk.
    I did crank them up another .5" about 500miles ago.
  2. Nov 26, 2010 at 11:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No real way to tell if they need a recharge. Best to have them charged every 2 years, depending on use.
  3. Nov 27, 2010 at 11:08 AM
    nvdeserted
    Reno, NV
    Really? Why would I ever recharge them then?
    I'm not sure what the clunk is, but I have a feeling that if I put them back down .5" the clunk will disappear...
    I did get these cheap. new, but old stock. Prob should recharge anyway.
    thanks C4x
  4. Nov 27, 2010 at 1:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can tell....They feel kinda "flat"....Hard to explain.
