Nitrogen Tire fill.
Discussion in 'Wheels & Tires' started by Joel Fox, Sep 24, 2007.
  1. Sep 24, 2007 at 3:16 PM
    Joel Fox
    Joel Fox [OP] Member
    Most Costco's are starting to carry nitrogen for tires:) My Local one said they would fill tires for free, if they weren't busy!!!!
  2. Sep 24, 2007 at 3:32 PM
    Spacedude
    Spacedude Well-Known Member
    Campbell, CA.
    2007 PreRunner TRD Off-Road Indigo
    Bed mat, Access Limited Edition tonneau cover, DeeZee Elite nerf bars, AVS Bugflector II, Toyota aluminum skid plate, Toyota TRD seat covers.
    Air is 78.08% nitrogen by volumn. What advantage does pure nitrgen have?
  3. Sep 24, 2007 at 3:58 PM
    Joel Fox
    The literature that I've read said That it increases tire wear up to 30% ( if this is true all tires should be filled with it) 30% is a lot!!
    Also reduces tire cracking from oxidation to air. And the tire's running temperature is cooler with nitrogen.
    I'm just doing research my self....
    So if any one can add to the pros's and con's I'd I would like to hear about it.
    :confused:
  4. Sep 24, 2007 at 4:09 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    umm.....u sure u meant to say that? i dont think i'd want 30% extra wear
  5. Sep 24, 2007 at 4:13 PM
    Joel Fox
    Yep, that is straight from the Toyota package given to me at the dealer. Spec's at www.whynitrofill.com
    I guess I said that back words.. It should increase tire life by 30%
  6. Sep 24, 2007 at 4:20 PM
    The_Hodge
    SC
    right...this is what the site says....
    In 7 million miles of truck tire testing, nitrogen inflated tires lasted longer.
    Tire failures were reduced by 50%
    Tread life was increased by 25-30%
    now read what u said....u said "it(nitrogen) increases tire wear up to 30%". it increases tread life...not tire wear. increased tire wear is a bad thing.
  7. Sep 24, 2007 at 4:26 PM
    Joel Fox
    Thanks for the English lesson. I do that kind of stuff all the time! I can fix any thing that runs... but cant' get my foot out of my mouth.:eek:
  8. Sep 24, 2007 at 6:17 PM
    The_Hodge
    SC
    haha...no prob...just making sure the full point was getting out...lol
  9. Sep 25, 2007 at 7:47 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I'm gonna use hydrogen in my tires. It will make my truck lighter so i can get better mileage. It will probably also help me drive across large bodies if i ever needed to. I'm no historian but i can't think of a single instance when hydrogen ever caused any kind of problem or catastrophe.... I'm an expert on gasses, just ask my gf, she'll vouch for that :)
  10. Sep 25, 2007 at 7:58 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Hindenburg Tacoma... Sweet. :rolleyes:
  11. Sep 25, 2007 at 9:03 AM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    pure nig. doesn't expand and contrat. therefor when you go from cold to hot you lose no PSI. We use nitrogen in aircraft tires so when they go from 0ft to 30,000ft 32 deg. air then back to 0 ft 90 deg. air. the tires don't lose psi.
  12. Sep 25, 2007 at 10:18 AM
    nd
    Nate
    Greenville, SC
    I can have flaming wheels. I'll be just like ghost rider except in a Tacoma :)
  13. Oct 1, 2007 at 9:19 PM
    professorchaos
    professorchaos Member
    06 prerunner
    Black billet grille, Westin bull guard with PIAA lights, leveling kit in the front
    i race legend cars at irwindale speedway and we use it for the same reason as stated above...when those small tires get going they can heat up pretty quick with just regular stuff...but nitrogen keeps them where they shood be!
  14. Oct 22, 2007 at 8:30 AM
    m3dragon
    m3dragon Well-Known Member
    Sacramento
    Nitrogen molecule are denser than Air molecules (AKA larger) thus your tires will keep pressure longer. Most performance cars run nitrogen to keep temps down and well as keep tire pressure. When you drive around corners in any car the, the tire deflects and forms small gaps where air slowly leaks. With nitrogen it is a larger molecule, thus they can't escape.
    It is better so if you can get do it. =)
  15. Nov 2, 2007 at 4:23 PM
    NORCAL Tacoma
    NORCAL Tacoma Active Member
    Humboldt County
    07 Tacoma SR5 4x4 2.7L Access Cab
    Rear Suspension TSB, new leafs and Bilstein Shocks. Aftermarket Stereo, bug guard, all weather floor mats.
    Nitrogen also makes beer taste better.. More smooth, less after taste than C02 as carbonation.
    If its good in beer, it must be good in my truck.
  16. Dec 16, 2007 at 8:10 AM
    hans17
    hans17 Well-Known Member
    san juan puerto rico
    tacoma xtra cab v6 sport 2007
    3"ez-lift kit , 1" spacer , stock wheels 17" , 285/70-17
    all i can say is that were i work we use nitro and beleive me if airplane use it it's safe. and were i'm from cotsco filled mine for free and just a $5.00 dollar tip to keep the guy happy.
  17. Dec 16, 2007 at 8:41 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    Story of my life!
  18. Dec 20, 2007 at 9:27 AM
    5862007
    5862007 Active Member
    2007 Toyota Tacoma Regular Cab 4x2
    I shelled out $29 for Nitro-Fill at a Toyota dealership this past Monday. The dealership informed me that any future Nitro-Fill refills would be free for those tires since I had paid for the initial fill at that service center.
    I've brought this up in another thread, so apologies in advance for repetitiveness...
    My tire pressure light stayed on when I got into my Tacoma on Monday morning, the second morning after I bought the vehicle. There was a massive temperature drop here in Georgia that previous night, hence the warning for tire pressure. Having not been familiar with the specifics of the tire pressure warning light, I was suspect of the explanation from the dealership at first about driving the vehicle until the pressure light went off and I wanted to make sure that I wasn't going to be seeing the light every other day, so I had them take a look. There was a lower pressure in my spare tire that had caused the light to stay on, so I had the dealership fill all five tires with nitrogen.
    Three days later and no additional problems.
    (*Jason knocks on his wooden desktop.*)
    Seriously...the Nitro-Fill seems like a reasonable enough idea, especially for truck tires.
  19. Dec 20, 2007 at 10:12 AM
    ATLRay
    ATLRay New Member
    Cumming, Georgia
    08 SR5 Prerunner TRD Off Road Pkg, Silver,perfectly showroom stock
    None.....Showroom Stock is beautiful!
    There is no data or scientific evidence that nitrogen filled tires stay inflated longer then normal air inflation in typical driving conditions on earth. Only in extreme conditions of pressure change and temperatures (commercial air, space shuttle) would this become an issue. As for the moisture/rust issue, when was the last time your wheel rusted off from the inside?? The real issue is under/over inflation. Check tires weekly. Keep them at the proper pressure and all will be fine.
  20. Jan 22, 2008 at 5:58 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    We put it in tires at my dealership- I have it in my Taco- reg cab w/16" rims. ALOT less bounce when I hit potholes and stuff, and no difference in tire pressure even at -10 degrees. I get a couple more MPG as well. A great investment. You'll notice a difference- esp on our small trucks.
    Dave
