Nitrogen?
Discussion in 'Wheels & Tires' started by FireTacMedic, Aug 20, 2011.
  1. Aug 20, 2011 at 7:39 PM
    FireTacMedic
    FireTacMedic [OP] I can save your life or ruin it
    Atlanta, GA
    2011 PreRunner SR5, Blacked Out
    Blacked out windows, Black Tacoma Badges, 18x9 Vrock Recons, 285/60/18 Terra Grapplers
    Is anyone running Nitrogen in their tires and if so any luck with it?
  2. Aug 20, 2011 at 7:41 PM
    DrewH
    DrewH Well-Known Member
    It doesn't really do much, if it's free giver' , if you are paying extra don't bother.
  3. Aug 20, 2011 at 7:44 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    It's a gimmick. The atmosphere we breathe (normal air) that you use in your tires is already 78% nitrogen. The only tires that truly need nitrogen is air plane tires so they don't pop when they go 40K+ feet up.
    Welcome to the forum! :wave:
  4. Aug 20, 2011 at 7:52 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  5. Aug 20, 2011 at 7:56 PM
    FireTacMedic
    Atlanta, GA
    hahahahaa yeah I guess ass gas is free too! Just hope im not clogged up when I get a flat.
  6. Aug 20, 2011 at 7:58 PM
    FireTacMedic
    Atlanta, GA
    They say you get better mpg's and longer tread life running Nitrogen. Idk though haven't talked to many people that run it.
  7. Aug 20, 2011 at 8:07 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Going from 78% (normal air) to ~90% nitrogen in your tire isn't going to make much of a difference.
    @Crom: the reason airplane tires are inflated with nitrogen is to reduce the likelihood of a fire after a tire blowout. Hot brakes + oxygen + chemical outgassing from the tire + severed hydraulic line...
  8. Aug 20, 2011 at 8:24 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I've never heard that before. But as it turns out I did some reading and we are both correct. :thumbsup:
    http://boeing.com/commercial/aeromagazine/aero_05/textonly/m03txt.html
  9. Aug 20, 2011 at 8:36 PM
    FireTacMedic
    Atlanta, GA
    yeah im seeing more and more threads and topics online about it but wasnt sure on gains in truck tires. At least no one was wrong, LOL!
  10. Aug 20, 2011 at 11:02 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes, as Crom said... I use 78% nitrogen in my tires!
  11. Aug 20, 2011 at 11:11 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    If they are going to pop at alitude it doesn't matter what air is in them. Pressure difference doesn't care about air composition they just care about it providing oxygen for fire after it blows.
  12. Aug 21, 2011 at 8:08 AM
    FireTacMedic
    Atlanta, GA
    You've convinced me bud, thanks
  13. Aug 21, 2011 at 8:31 AM
    detnight
    detnight Well-Known Member
    David
    Texas City ,Texas
    Texas Edtion Sport Super White
    Bed cover, Borla exhaust,20in wheels The TEXAS edition
    normal air is effected by tempature and nitrogen is not. I run HOT air in Texas (78%)
  14. Aug 21, 2011 at 8:37 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Airplanes put N2 in the tires because it has no moisture or oil init like regular compressed air would. At the altitudes the planes fly, any contaminants in the tire would freeze. When the plane lands, the sudden impact of the tire hitting the ground would heat everything and the tire would blow out, thus resulting in a crash. Also the expansion and contraction of the molecules are more uniform than a mixed gas.
    The reason you would put N2 in a personal vehicle is to reduce the chance of fluid friction of the moisture in the air that could wear and cause corrosion on the inside of the tire and rim. O2 is a corrosive, and mixed with other impurities speeds up the process. People have been putting regular compressed air in their tires for a long time without a problem. But if you can get N2 for free, go for it. The next best thing is airing up with compressed air that has a moisture separator in the line.
  15. Aug 21, 2011 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not entirely true. The water in the air is what causes the temp change. If you have an air dryer on your compressor (or the shop that fills your tires), then the air wont expand oir contract as much. I've been testing this out on my comp.. I only have to make psi changes maybe once a year.....if that.
  16. Aug 22, 2011 at 2:37 AM
    detnight
    David
    Texas City ,Texas
    O2 "permeates" approximately 3-4 times faster than does N2 through a typical rubber, as is used in tires, primarily​
    because O2 has a slightly smaller effective molecular size than does N2.
    http://www.getnitrogen.org/pdf/graham.pdf
  17. Aug 22, 2011 at 2:38 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    my air compressor only gives me air
  18. Feb 29, 2012 at 9:11 PM
    Vikinglord
    Vikinglord Active Member
    Michael
    Nashville
    Gold Prerunner
    I filled mine with candy so my tires can be used as a piñata childrens parties.
  19. Feb 29, 2012 at 9:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's so when they DO pop in the wheelwell after retraction (this is extremely common, when I worked at Douglas I got the daily "crash reports" and saw this 3-4x a week), the damage caused by the debris doesn't lead to a fire since the tire's nitrogen tends to purge the oxygen from the cavities.
  20. Feb 29, 2012 at 9:20 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And an extra 14.7psi is not going to pop an aircraft tire.
    Particularly not the SR71's tires that are jacked to 600psi.
    But ya... fill a tire at sea level and take it to the moon. That tire will contain only 14.7psi more than it did at sea level.
    No tire is going to pop from altitude.
