Nitto Ridge Grappler Review
Discussion in 'Wheels & Tires' started by double dee, Aug 3, 2016.
  1. Oct 7, 2017 at 10:55 PM
    #241
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well, in my opinion, it's all about the sipes. Tires primarily designed to be superior in winter conditions have an excessive amount of sipes. Since 2000 I've had a reg cab Dodge 1500, a quad cab Dodge diesel 2500, a quad cab Tundra V8, a 4Runner Trail (and now a Tacoma). I believe that if you live in an area that gets snow you should have a 4WD, so yes, all of these were. I ran a lot of different tires in all those years. The list is long. The best were the Dura Tracs. My only guess is because they had deep tread groves and the blocks had two zig zag sipes each, and were spaced farter apart than all the other AT tires I ran before them. I'm a firm believer too that the type of snow is the most important factor when it comes to traction in the snow. Our snow tends to be wet, slushy, little pellets, and we also see a lot of sleet, and freezing rain. My BFGs would load up so bad they turned into slicks. My driveways are asphalt and steep.
    Before deciding on the Ridge Grapplers I read as many reviews as possible. Because they are so new there aren't many of them for snow, and barely any at all for my neck of the woods. At the same time, there are countless positive reviews for BFGs in the snow.......but we know my opinion on those.
    So I am keeping the faith, and hoping for the best. They have a unique tread pattern and the depth of the grooves are like the Dura Tracs. They are exceptionally quiet so I hope that all translates to a competent snow tire even though they only have the single sipe in the tread blocks.
    We've been exceptionally lucky for a couple years and I have a feeling we are due so we will see.
  2. Oct 8, 2017 at 3:23 AM
    #242
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    you are getting better mpg because they are E load ? ive been reading some reviews where these are great in the snow..
    RobP62[QUOTED] likes this.
  3. Oct 8, 2017 at 6:50 AM
    #243
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The difference between the MPGs I was getting with the 4Runner and what I am getting with the Tacoma could be so many things. But one thing that is the same is my driving habits.
    The weight of the two vehicles, 4,445 lbs Tacoma, and 4,750 lbs 4Runner, combined with the 3.5 vs the 4.0 engines, plus gearing could be the difference.
    The contact patch is greater with the Ridge Grapplers than the Dura Tracs but I'm running higher psi's in these than I ran with those.
    So when I say maybe it's because it's an E range vs a C range I'm just adding that to the guesswork.
    I can tell you this, as the Dura Tracs wore down my mpg's started to go up. But only up to almost 17.
    And, I was running them on the Tundra I had, in C range too, and the mpg's in that was nearly identical to the 4Runner.
    Yes, I did read some positive snow reviews for these tires. Not hundreds like I would like to have, but enough to convince me to give them a try. I want them to provide the safety I require while commuting. If they don't I'll replace them.
  4. Oct 8, 2017 at 7:11 AM
    #244
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    The proof is in the pudding. Keep it under 2 grand on the tach and I can do this all day.....
  5. Oct 10, 2017 at 8:42 PM
    #245
    muddywater
    muddywater Member
    2005 Desert Sand Tacoma 4x4
    Anyone know if the weight posted on Nitto's site for the new load C Ridge Grapplers 265/70/17 is a typo? They have them down as being slightly heavier than the same tire in a load E (54.67 lbs vs 54.66). That does not make any sense... If they are lighter I will be buying some otherwise I may have to take another road....
    RobP62 likes this.
  6. Oct 11, 2017 at 2:44 AM
    #246
    bludweiaer
    pa
    read post 235,, i too have been waiting for a c load 265/70/17 grappler,,, if something doesnt happen soon.. im considering the st maxx
    RobP62 likes this.
  7. Oct 11, 2017 at 8:10 AM
    #247
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Must be flat where you live?
  8. Oct 11, 2017 at 8:55 AM
    #248
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, definitely not like the pic in your signature, that's for sure. And it was all down hill. From our place up in the woods to the beach. Now granted, there are some hills, and even the Bay Bridge to cross, but I basically kept the speed under 80 and the tach around or under 2 grand the whole time. Because of traffic I could only average 60 mph, based on the distance traveled checked every hour.
    ChadsPride and rlx02[QUOTED] like this.
  9. Oct 12, 2017 at 1:24 PM
    #249
    bludweiaer
    pa
    if anyone see's the ridge grappler in a 265/70/17 in a C-load for sale anywhere, please post where,, thanks,, supposedly there just released them 1st of the month..
    ChadsPride likes this.
  10. Oct 15, 2017 at 3:22 AM
    #250
    bludweiaer
    pa
    well after several emails to nitto, inquiring about the c-load 265/70/17 ridge grapplers, and not one response back from them, i guess im not going to buy there tires, if they cant take the time to answer a question or two, i dont want anything to do with them..
  11. Oct 15, 2017 at 5:01 AM
    #251
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Just call them like I did. During their working hours, of course. I got through to a very nice, informative rep. Maybe their email server is experiencing issues. You can tell them that too.
  12. Oct 15, 2017 at 5:59 AM
    #252
    S P A R K Y
    S P A R K Y Well-Known Member
    Mark
    2004 4runner V8
    If that’s the logic, e-mail the next tire company and see if they respond in a quicker time.
    Call them like Rob did. I can’t imagine the number of kids and people that e-mail them asking dumb questions or good questions. Over and over and over if someone doesn’t respond within 24 hours. Just ask VIN at scs!
    RobP62 likes this.
  13. Oct 15, 2017 at 2:50 PM
    #253
    ChadsPride
    Sponsored by TacomaWorld.com
  14. Oct 17, 2017 at 12:50 PM
    #254
    S P A R K Y
    Mark
    2004 4runner V8
    Discount tire direct eBay sale is on!! $100 off a $400 purchase! Buy 2 tires and buy another 2 to get $200 off!
    Went to local DT and got them to price match!
    285/70 in C! Waiting for them to come in!
    Watt maker, RobP62 and ChadsPride like this.
  15. Oct 17, 2017 at 1:35 PM
    #255
    ChadsPride
    :woot::woot:
  16. Oct 17, 2017 at 2:02 PM
    #256
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    DID YOU FREAKING ASK ABOUT THE 265/70R17 IN "C"?!!! Sorry, D mode came out. :oops:
  17. Oct 17, 2017 at 2:06 PM
    #257
    bludweiaer
    pa
    man i might get me 4. even tho ive been holding out for the c-load grappler..265/70/17 , supose to be coming out
  18. Oct 17, 2017 at 2:19 PM
    #258
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl::rofl::rofl: Good One!
  19. Oct 17, 2017 at 2:28 PM
    #259
    bludweiaer
    pa
    yes, got a set of stealth SR8's in garage for 2 months just waiting, i guess for this price i can take a chance on a 10 ply..
  20. Oct 17, 2017 at 2:41 PM
    #260
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I am confused as heck now. :goingcrazy:
    Why not call DTD and ask them if they are getting that C in the 265/70 you wanted? Or why not get the 285/70 in the C if you have the lift to accommodate it?
    I thought all along all you wanted was the C ? Why now are you going to "settle" for the E just because it is cheaper?
    :smack:
    Man am I confused :der:
