Nitto Ridge Grappler Review
Discussion in 'Wheels & Tires' started by double dee, Aug 3, 2016.
  1. Apr 3, 2018 at 11:26 AM
    #481
    Double Deuce
    Double Deuce Well-Known Member
    JJ
    Sioux Falls South Dakota
    Double Cab 02 TRD
    I called Nitto today and they advised same rubber compound in c or e. They also advised in the 265/70-17 both the c and e have same 2 ply sidewall so the only difference is how they are laid out within the tire. I would assume the c would ride softer but the rep would not state that is the case with these due to both having just a 2 ply sidewall
    Watt maker and RobP62 like this.
  2. Apr 3, 2018 at 11:51 AM
    #482
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yup, I posted that each time I called them (twice) but it is great to have someone else reiterate it. I talk a lot and I know some people probably think I am talking outta my butt most of the time. They told me the same thing and no matter what I could not get them to say what I wanted to hear, and that is that the E rated tire is Harder than the C rated tire. All they would say, as you just posted, is that the wires are laid out differently which in turn increases the load rating/psi. That's it.
    That's why if I buy these again, and I likely will, I will buy E's again. I tow, not all the time but sometimes, and when I do I want the added strength. My thought on this for off roading is that if I air these down then they are still able to withstand more force acting against them too.
    Aaannnnd, there I go talking a lot again.
  3. Apr 3, 2018 at 6:35 PM
    #483
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Maybe its winter gas vs summer gas, but my mpgs have gone up in the last 3 tanks to almost 19 with the E rated version of these.
    RobP62[QUOTED] likes this.
  4. Apr 3, 2018 at 8:03 PM
    #484
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That could definitely be the case. Mine was over 18 on the last tank and that's up 2.
  5. Apr 4, 2018 at 3:46 AM
    #485
    Black05
    Black05 Well-Known Member
    Harford Co. MD
    2005 ac 4×4
    Full trd pro suspension. Toytec progressive add-a-leaf pack (with overload in). Sema trd 4runner rims. 285 70 17 ridge grapplers. Satoshi grill.
    Increased ethanol and slightly different formula in gas during winter months. Your mileage will go down around November/October and up around April/May
  6. Apr 27, 2018 at 2:05 AM
    #486
    s1t808
    s1t808 Sitting in the timeout corner
    HI > OCONUS
    2015 Taco
    Lift? Yea I got one of those
    Just curious if anyone is running a set of RGs in 305s. I'm currently on 285s RG.
    JoseyWells and RobP62 like this.
  7. Apr 30, 2018 at 11:52 PM
    #487
    PNWskibum
    PNWskibum Well-Known Member
    2018 TRD off-road Access cab,blue
    LED interior lights,LED lows/highs,window rain guards
    Anybody used this nitto before?its on a 4Runner I’m looking at buying
    RobP62 likes this.
  8. May 1, 2018 at 4:20 AM
    #488
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    I've got a friend who has been running those for about two years or so now. He's got no complaints, but has said his next set of tires will be the ridge grapplers.
  9. May 1, 2018 at 7:46 AM
    #489
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I hear they are great in the mud, but not so great in the snow. For the obvious reasons. These will most likely be a lot louder than the Ridge Grappler too. Look for lower MPGs as well. However, I do see these on a lot of jeeps in my neck of the woods and we get some snow. They are a little lighter vehicle so maybe that's the defining factor. They are pretty beefy looking. That's for sure. I would certainly not let them stop me from buying a 4Runner with them on it. If you don't like them, you will not have a problem selling them.
  10. May 1, 2018 at 7:56 AM
    #490
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    1000 Miles now and I’m liking my Ridge Grapplers a lot !!!
    576F6D03-2D35-49F5-95E4-3C6E3B959DFB.jpg 06EB887F-5B33-4645-949E-1B24392ACC8F.jpg 42ACE154-DA88-42EF-9FB5-D8FE34E34140.jpg 882FBA32-DE2C-460C-8A28-BA4A98C053E2.jpg
  11. May 1, 2018 at 7:58 AM
    #491
    ChadsPride
    Sponsored by TacomaWorld.com
    What PSI are y'all running?
    285/70/17s here C load (me thinks)
    RobP62 likes this.
  12. May 1, 2018 at 7:59 AM
    #492
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    36 rear, 37 front on my 265/70r17s E load. Seem to be wearing even after 13k miles.
    ChadsPride[QUOTED] likes this.
  13. May 1, 2018 at 8:00 AM
    #493
    ChadsPride
    Nice, is that the recommended pressure for your set?
  14. May 1, 2018 at 8:22 AM
    #494
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    No, the door tag says 32 psi, and the tires say 80 psi LOL That would be insanity. I know originally when I asked the question a guy on here (and I'm a dufus for not remembering his name or being able to find the post) based the weight of the truck and the load range of the tire did some hocus pocus math trickery and came up with 37 psi.
    I run that in the front because of me and the engine being up there and no load in the rear besides the Bak X2 Tonneau. I bump the rear up to 37 when I load it down when we go on vacation.
    I should just do the damn chalk test to be 100% sure. To be honest, at 36/37 there is still some bulge. Also, since I have the TPMS I can monitor each tire and I do that occasionally while I am running down the highway. On average, the pressure increases anywhere from 3-4 psi from the heat. So I am happy with them being a little firmer at 41 psi to help with MPGs than I am with them at 32 psi which would obviously not be as good. Even though they would increase to that 36/37 on the road. When I do the chalk test eventually I will do it with them hot at the 41 psi and then let some air out to bring them back to mimic the cold psi and do it again.
    Oh, and I have 3 pressure gages. 1 mechanical dial and two digital. I don't trust any of them but the one I have is better than the other two.
  15. May 1, 2018 at 8:23 AM
    #495
    ChadsPride
    The suggested PSI for mine is 50 and that's what I've been running. Just feel like that's a little much.
    RobP62 likes this.
  16. May 1, 2018 at 8:28 AM
    #496
    Tacomamike mike
    Michael
    That sounds high, running 33psi all around on my 295/70/17’s thinking about bumping it to 38-40 .
  17. May 1, 2018 at 8:35 AM
    #497
    ChadsPride
    What's the recommended for your set?
  18. May 1, 2018 at 8:38 AM
    #498
    MMoreno16
    MMoreno16 Cupcake Forest Ranger
    Los Angeles
    2018 TRD OR DCSB
    36 all around....
    same size and load rating as your Chad
    Edit : Nevermind you have 16s
    Road_Warrior and ChadsPride like this.
  19. May 1, 2018 at 8:39 AM
    #499
    ChadsPride
    Load?
  20. May 1, 2018 at 8:40 AM
    #500
    MMoreno16
    Los Angeles
    2018 TRD OR DCSB
    C
