Nitto Ridge Grappler Review
Discussion in 'Wheels & Tires' started by double dee, Aug 3, 2016.
  1. Aug 12, 2018 at 10:32 AM
    #661
    ChadsPride
    Sponsored by TacomaWorld.com
  2. Aug 14, 2018 at 1:11 PM
    #662
    Cincysean
    Cincysean Active Member
    Cincinnati Ohio
    O7 Dbl Cab Sport
    Hi Gents,
    Been following this thread for a while and appreciate all the insight!
    I'm set on the NRG tire but I'm at a loss when it comes to size.
    Right now I'm running 265/70/17 on stock suspension. I have the OME 3" lift about to be installed in the next few weeks.
    I have been researching which tire size will look/perform best and not require me to cut/tuck any fender material.
    With that being said, I have been told by a "tire guy" that the 33/12.5/17 will give me what i'm looking for without cutting fenders. I've also been told by some TW guys that 285/75/17 will work.
    Any help/suggestions are much appreciated!
    derf77 and RobP62 like this.
  3. Aug 14, 2018 at 3:40 PM
    #663
    derf77
    derf77 Well-Known Member
    Fred
    South Chesterfield, VA
    2017 TRD DCSB OR MT Silver
    6112's 2.75 in. lift front, Icon UCA's, 5160s w/res, Deaver mini pack in the 1.5 in rear lift, TJM Rock Crawler front Bumper, Baja Squadron Sport lights, TJM Rock crawler lights, SPOD w/touchscreen, Rokblokz rear mud flaps, Method NV Wheels, 285/70R17 Nitto Ridge Grapplers
    I did the bilstein 6112/5160 with deaver mini-pack lift. About 2 3/4 in the front with about 1 1/2 lift in the rear. I am running 285/70/R17's on 17 x 8.5 0 offset and -4.75. I had to do a CMC and a bit of trimming to eliminate rubbing when aired down. It fits oh so nice now. I would like to move up to 305/70R17 but that would involve more cutting and trimming and pounding the firewall.
    dskakie and Cincysean[QUOTED] like this.
  4. Aug 14, 2018 at 5:31 PM
    #664
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Stay with 285s.
    12.5” look way too wide, in my opinion, for a 2-3” raised truck. You’ll also appreciate a little less rolling resistance.
    Cincysean[QUOTED] likes this.
  5. Aug 15, 2018 at 10:37 AM
    #665
    9bhs2012
    9bhs2012 Well-Known Member
    Michael
    Lynchburg, VA
    2016 Black Tacoma TRD OR DCSB
    Just checking in to see how you are still liking your Ridge Grapplers? I just had a set of 285/70/17s installed this week. Coming from a set of 265/75/16 Duratracs. I put 32k miles on my duratracs and my god they had gotten extremely loud. 1 duratrac had started to wear a little funny but other 3 were still at least 1/3 of the original tread still remaining. What kind of life/mileage should I expect out of the new Nitto's? And you are recommending tire pressure around 36/37?
    Thank you!
    kakwvu, RobP62[QUOTED] and ChadsPride like this.
  6. Aug 15, 2018 at 11:23 AM
    #666
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Looks great. Funny you should ask, the talk of tires has reared it's head as of late. Not sure why, I am still happy.
    I shot these pics the other day, this is at about 15k - 16k miles, but none of it is off road.
    Front tire:
    Back tire:
    I have not measured them with my caliper but to me they look new still, save for some dirt or scuffing. Maybe they are 25% worn????
    I will have to measure.
    I definitely still like them. Even now they are still smooth and quiet like they were new. Now, there are times, when the truck sits (it's not my DD) and they sorta get a little flat spot. So for the first maybe 3 miles or so there is a tiny amount of steering wheel wobble. I think that has always been that way though. But for the most part I am still astonished how quiet they are, or how smooth.
    I hope to try them out off road here in Maryland before I need new ones. :bananadead:
    I would definitely recommend them to anyone.
    9bhs2012[QUOTED] and ChadsPride like this.
  7. Aug 18, 2018 at 12:54 PM
    #667
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    @derf77 @9bhs2012 @ChadsPride
    Ok, tread wear update! I bought these the other day and they came today.
    Godeson 88702 Smart Color Coded Tire... https://www.amazon.com/dp/B0793HMWP1?ref=yo_pop_ma_swf
    I checked right away down at the mailbox (was on my way out to test my CAI fix, another story) and both front and rear tires measured 14/32s in the middle of the tire. 14/32s !!! Factory is 16.4/32s. I have about 15k miles on these. Soooo, what's that, 2.4/32s less. LOLOLOLOL
    Yea, I definitely endorse these tires!
    MickeyB, ChadsPride and 9bhs2012 like this.
  8. Aug 22, 2018 at 9:11 PM
    #668
    TWENTYCO
    TWENTYCO Tree top flyer
    Tim
    North FL
    2015 TRD Off Road 4X4 Acess Cab
    Plenty mods on many vehicles since 1982. Current: 15 Tacoma 4X4 V6 TRD OR Access Cab Pyrite Mica- Icon full stage 7, All-Pro APEX sliders & rear Expedition Springs + custom Tampa Springs leaf spring upgrades, Timbren bump stops, u-bolt flip, Road Armor front stealth winch bumper & rear steel, Warn Vr 8000, Nitto Terra Grappler 285/75/r16, Off Grid Engineering Dual Battery system, SPod 6 switch, 2 pairs Rigid D2 spot & flood in bumper, ARE Expedition Cap, bedglide,Tru Cool 45K GVW add on transmission cooler, Re-gear to 4.56, rigid rear bumper floods, scan guage II, rigid ditch lights. full size spare on matching factory wheel, seat mods/insert, CB w/magnet mount.
    I’ve been running Terra Grapplers since 2009 I think? Always the E rated tires and higher pressures for better load capacity and high speed on road manners. Just air down for off road. Last set has 40000 miles of aggressive driving on and off road and I’m just getting to the point where they are showing tread wear.
    I’m going to go with the Ridge Grapplers this time. Why wouldn’t we want more plys? I’m not sure about the argument for the c class other than $.
    RobP62 likes this.
  9. Aug 23, 2018 at 3:49 AM
    #669
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup:
    I agree about going with the E range. I like mine a lot.
    TWENTYCO[QUOTED] likes this.
  10. Aug 23, 2018 at 9:46 AM
    #670
    Taquitoqvola
    Taquitoqvola Well-Known Member
    2018 TRDORDCSB MT QUIKASFKSAND
    Where r u guys getting good deals on these? Cheapest ive found is 240 ea shipped. Everywhere else is 256ea shipped.
    285/70/17 E
    RobP62 likes this.
  11. Aug 23, 2018 at 9:48 AM
    #671
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    E range is always more. That 285 adds. Are you near a Discount Tire Direct? They have free M/B at least. Sometime discounts. :oops:
  12. Aug 23, 2018 at 9:54 AM
    #672
    Taquitoqvola
    Nowhere near a dtd. They aint cheap.. but they are pretty. Thats why we pay. Maybe labor day sales will lead to a score..
    RobP62[QUOTED] likes this.
  13. Aug 23, 2018 at 10:00 AM
    #673
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I know sometimes some local places will price match online retailers.
    TWENTYCO likes this.
  14. Aug 27, 2018 at 6:19 AM
    #674
    TWENTYCO
    Tim
    North FL
    My local GMC dealership that services (and sells us most of our other cars and trucks) our other vehicles has a price match guarantee. I typically let them know what I need well in advance and they hunt down the best deal. They’ve had me wait until the end of the month so I’ll get an available $100.00 rebate. I’ve never heard of a rebate on Nitto’s ...lol....but I’m still sticking with them because we’ve gotten a couple rebates from GoodYear through them. I try to also give my business to the local shop that will be fixing anything that I can’t plug on my own.
    RobP62 likes this.
  15. Aug 27, 2018 at 6:23 AM
    #675
    TWENTYCO
    Tim
    North FL
    If you’re not with a local shop, see what the local 4wheel parts store can do for you. The staff in Jacksonville FL are great and can do some amazing things with hard to find parts and tires and pricing as well. They have store to store transfer and warehouse pick up that can really save some $. I’m assuming that same thing can work for tires...never bought tires from them though.
    RobP62 likes this.
  16. Aug 27, 2018 at 6:24 AM
    #676
    ChadsPride
  17. Aug 27, 2018 at 7:40 AM
    #677
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You're so sexy wrapped in those Nittos!
    ChadsPride[QUOTED] likes this.
  18. Aug 27, 2018 at 7:50 AM
    #678
    ChadsPride
    Thanks man!!! Love these tires
  19. Aug 27, 2018 at 8:43 AM
    #679
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :hattip: I know right! Like I said, 15k miles and only 2.4 mm of wear. Works for me!
  20. Aug 27, 2018 at 3:58 PM
    #680
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Why are these tires so heavy? The C load 265 70 17 is heavier than some bigger tires. Why is that?
    RobP62 likes this.
