Nitto Ridge Grappler Review
Discussion in 'Wheels & Tires' started by double dee, Aug 3, 2016.
  1. Aug 29, 2018 at 1:27 PM
    #681
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    If you find out let us know. o_O
    I wish I knew.
  2. Aug 30, 2018 at 5:06 PM
    #682
    bowhunterRN
    bowhunterRN Well-Known Member
    Eric
    Greenville, NC
    14 MGM TRD sport DCLB 4x4
    Will you be running a 3” lift with these tires? Looking to do the same with a fox 2.5 setup and curious if it will fit or not. Of course with CMC and plastic trimming.
  3. Sep 20, 2018 at 8:43 AM
    #683
    Cheekrs
    Cheekrs Member
    Chase
    17 trd offroad
    Been rocking my ridge grapplers for 6000 miles or so. I love them - quite on road, great off-road capabilities, good looks. Only negative thing I can say is they took about 1.5-2 mpg from my average. Other than that - they are perfect for the commuter/off-road enthusiast/adventurer
  4. Sep 20, 2018 at 11:30 AM
    #684
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Agree with this completely ^^^^^ !!!!
  5. Sep 20, 2018 at 3:12 PM
    #685
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    I have 40,000 on the truck now. The RGs have been on for alot of that. They still show very little wear, but they are getting louder.
    RobP62 and ChadsPride like this.
  6. Sep 21, 2018 at 9:28 AM
    #686
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I like to hear that!
  7. Sep 22, 2018 at 9:30 AM
    #687
    tacogeorge
    tacogeorge Well-Known Member
    George
    2016 Tacoma TRD Off Road
    Has anyone tried both the C-rated and E-rated for themselves? Price and weight seem to be the two biggest factors I hear when someone bring up load ratings but from what I can tell they really shouldn't be deciding factors at all. Looking at Nitto's page the 265/70R17 C and E are the same weight (ok, actually the C weighs 1/100th a pound MORE) and on TireBuyer the price difference is only $4 per tire. How are they adding extra layers without adding extra weight?? I don't know but it turns out the diameter of the C is about a quarter inch larger than the E.
    Anyways, I guess that just leaves the actual strength of the sidewall as the deciding factor.
    C should flex better without lowering PSI as much(ex: air down to 18-20 instead of 10-12).
    C should ride a little softer on-road (better bump absorption but sloppier cornering)
    E will be more stable while towing
    E will be more puncture resistant
    If I run an E load on road at a slightly lower PSI I feel like the ride would be indistinguishable from a C. No?
    RobP62 likes this.
  8. Sep 22, 2018 at 9:57 PM
    #688
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Load range =/= puncture resistant.
    kakwvu likes this.
  9. Sep 22, 2018 at 10:14 PM
    #689
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Nitto released that the sidewalks are identical in previous statements.
    tacogeorge likes this.
  10. Sep 23, 2018 at 9:29 AM
    #690
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    All reports by users that contact Nitto (myself included) are that the compound and construction of the tire are nearly identical. The only difference between the E & C are how the Plys are laid out. That's the only difference. The E rated Plys are designed to add strength in the sidewalls.
    I just had my tires rotated and have been monitoring the psi on the dash info display because I swear they look low. They are a constant 36 psi in the rear though (cold).
    After nearly 18.5k miles I'm still amazed how smooth and quiet these tires are. 265/70r17 E
    tacogeorge[QUOTED] and MickeyB like this.
  11. Sep 23, 2018 at 1:59 PM
    #691
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Too heavy for a C load tire.
    tacogeorge and RobP62 like this.
  12. Sep 23, 2018 at 3:02 PM
    #692
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, they are. Makes ya wonder.
    Fedup13[QUOTED] likes this.
  13. Sep 23, 2018 at 3:12 PM
    #693
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I read thru as much of this as I could.
    Do any of yall have the 285/70-17s in the SL load??
    RobP62 likes this.
  14. Sep 23, 2018 at 6:36 PM
    #694
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I feel like I've seen the SL posted in here.........
  15. Sep 28, 2018 at 8:32 PM
    #695
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    What’s the difference?
  16. Sep 29, 2018 at 9:57 AM
    #696
    Justyn98
    Justyn98 Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    Im on the fence between the ridge graps or the wildpeak at3 decisions decisionso_O but the more I read the sexier I think the graps are:eek:
    Thunder Fist likes this.
  17. Sep 30, 2018 at 9:03 AM
    #697
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    285/70/17 c load ko2. 51lbs
    275/70/17 e load ko2. 55 lbs
    285/70/17 c load nitto's 57 lbs
    285/70/17 SL nitto's. 48 lbs (standard load) is this 4 ply or something?
    RobP62 likes this.
  18. Sep 30, 2018 at 10:20 AM
    #698
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    I have a set of bfg and nitto , waiting for the front lift to install tires.
  19. Oct 1, 2018 at 4:13 AM
    #699
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Odd. Not sure. Odd.
  20. Oct 3, 2018 at 9:20 AM
    #700
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Yes, it’s a 4 ply.
    RobP62[QUOTED] likes this.
