nitto terra grappler question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1bad03snake, Oct 2, 2008.
  1. Oct 2, 2008 at 12:14 PM
    1bad03snake
    1bad03snake [OP] Well-Known Member
    Baytown,TX
    4x4 TRD
    none but please give me your info.
    Tomorrow is the day I will lift my truck. I got everything except the diff drop and the centering bolts/pins for the rear.(coming next day air) My 1 1/2 old daughter likes to hide daddy's key's,wallet,cell..... Anyway I have a friend that works @ discount tire and he is setting me up with 4 285/75/16 terra grapplers for $671.00 out the door. When I have them put on will I need to trim anything while I'm there? Will I need a spacer?
    Thanks for the help.
  2. Oct 2, 2008 at 12:26 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Don't know about the spacer, but remove the mud flaps before you go, more than likely you will have to trim. I don't know much about that tire, I was planning to go with it, but changed.
    The shop can do the trimming if you want, but it is real easy to do, and not rocket science. If you decide to do yourself, when you head home take turns a little wider if you hear rubbing you will most likely see it when you get home. Then while at home cut the wheels hard to left and right and you will see the rubbing areas.
    I have some pic's of the areas I had to cut, had both of them done in less than 5 minutes.
    If I am doing some crawling over rocks and log's etc, I still get rubbing but it is something I can live with since I don't do alot of it, only during hunting.
  3. Oct 2, 2008 at 1:12 PM
    1bad03snake
    Baytown,TX
    4x4 TRD
    Thanks for the help. I'll take the mud flaps off 1st thing when I start lifting it tomorrow AM
  4. Oct 2, 2008 at 4:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you mounting these on the factoy wheels?
  5. Oct 2, 2008 at 4:58 PM
    1bad03snake
    Baytown,TX
    4x4 TRD
    yes, I was going to mount them on the stock wheels for now.
  6. Oct 2, 2008 at 5:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You are going to rub your Upper Contorl Arm.
  7. Oct 2, 2008 at 11:01 PM
    1bad03snake
    Baytown,TX
    4x4 TRD
    can I run a small spacer? if so what size?
  8. Oct 2, 2008 at 11:31 PM
    josh3972000
    josh3972000 Well-Known Member
    kentucky
    02 dbl cab TRD
    1/4 inch should work fine if I remember correctly.
  9. Oct 3, 2008 at 12:03 AM
    hsc001
    hsc001 Well-Known Member
    laurel, Maryland
    08 TRD off road lifted
    BHLM, 3" toytec coilovers, blacked out billet grille, hella 500's behind grille, volant CAI, Dual flowmasters 40's, HID, DTLT
    sorry to butt in but if i get 285/75/16 tires and put them on stock wheels i will rub on the upper controle arm. and the only way to fix that is to get wheel spacers. My question would be is there any other way to make this work with out spacers, and how bad is the rubbing?
  10. Oct 3, 2008 at 12:17 AM
    josh3972000
    kentucky
    02 dbl cab TRD
    spacers or new wheels, I have heard about people grinding on the upper control arm, but I would never in any situation consider doing that. Sounds dangerous. I personally dont care for spacers either.
  11. Oct 3, 2008 at 8:59 AM
    Rudbwoy7s
    Rudbwoy7s Well-Known Member
    TEXAS
    08 Double cab 4x4 sr5
    3" Revtek suspension lift, 17" Black and silver American Eagle Alloy wheels, 285/70 Nitto Terra Grapplers, Flowmaster 40 series muffler, sockmonkey brake light cover, Maglight mod, Viper alarm, Smith & Wesson hitch receiver cover
    may have to remove some bolts inside the fender flares as well.
  12. Oct 3, 2008 at 10:14 AM
    hsc001
    laurel, Maryland
    damn that sucks, i like my wheels and want to keep them.
  13. Oct 3, 2008 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can get aftermarket UCA's that will clear, and adjust for the caster issue after a lift.
