nitto terra grappler's AT
Discussion in 'Wheels & Tires' started by fltaco000, Nov 5, 2008.
  1. Nov 5, 2008 at 5:28 PM
    fltaco000
    fltaco000 [OP] Member
    fl
    08 prerunner
    im thinkin about gettin the Nitto Terra Grappler All Terrain's i dont have a lift and im not gonna put one on whats the biggest tire you think i could fit without it rubbing, and its the 08 taco
  2. Nov 5, 2008 at 5:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you have the 16inch offroad wheels......biggest tirre without a lift is 265/75/16........if you have sport with 17's.......... 265/75/17 i think.
  3. Nov 5, 2008 at 5:31 PM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    I just got a set, great tires! The biggest size you can run without a lift is 265/75/16 or 265/70/17.
  4. Nov 6, 2008 at 5:33 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I just got a set of 265/70/17 and I have minor rubbing :( on my Base model 4x4, hoping the TSB with Bilsteins all around will fix that, if not then 4 Wheel Parts will trim a little for me.
  5. Nov 6, 2008 at 7:23 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Get a set of sheet metal shears and trim yourself. Why let 4 Wheel Parts rip you off...
  6. Nov 6, 2008 at 7:58 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I agree with all posts above. I'm going to say Nitto TG's are great, I've had mine for 30,000 and they still have maybe 12,000 to 15,000 left on them.
  7. Nov 7, 2008 at 12:13 AM
    FoxySandChick
    Kristin
    Henderson, NV
    They only rub on the plastic fenders where the mud flaps use to be attached. Oh and free wouldn't be a rip off and they are right around the corner from my house, but my BF did his and he could do mine also if I wanted to wait for him to get around to it :D. Also I saved over $300 on my wheels/tires at 4WP and my BF saved $75 on airbags. It took them less than an hour to install my wheels/tires and the customer service was great.
  8. Nov 7, 2008 at 2:06 PM
    Jay_bruce
    Jay_bruce Active Member
    Southern Illinois
    07 Double Cab, TRD 4x4
    5100's up front @ 1.75, LT285 75R Nittos on 16" MB Predator rims.
    I used a simple utility knife, just keep an extra sharp blade handy-
  9. Nov 7, 2008 at 5:15 PM
    roxspin72
    NC
    Oh Yeah!!!
    Thats a first. Seems every quote I get from 4WP is higher then all others. You are lucky, have at it...
  10. Nov 7, 2008 at 5:38 PM
    whiteknight303
    whiteknight303 Proud New *****
    Campbell River, BC
    01 4x4 DC White
    Alpine 9886 head unit, Black UWS tool box
    How big can you go on a 2001 without a lift with the terra grapplers?
  11. Nov 7, 2008 at 6:21 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    on an 01 dcab, nothing bigger than what you already have stock...
    265-70-16
  12. Nov 7, 2008 at 6:22 PM
    whiteknight303
    Campbell River, BC
    01 4x4 DC White
    not even a few inches? Dont the 4x4s have a little more clearance than the prerunners though?
  13. Nov 7, 2008 at 6:26 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    a prerunner is a 2wd w/ the suspension of a 4x4. same heights
  14. Nov 7, 2008 at 6:27 PM
    whiteknight303
    Campbell River, BC
    01 4x4 DC White
    ohhhh iv always wondered, thanks for the tip, so only stock size? whay can 2nd gens go higher?
  15. Nov 7, 2008 at 6:31 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    they are built differently
    just like 01-04 xcabs sit a lil higher than the dcabs...
  16. Nov 7, 2008 at 6:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You sure about this? everything I find lists the double cabs higher than the others. :confused:
  17. Nov 7, 2008 at 10:23 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    positive on the 01-04 gen...
    i went through a lot of money in tires, wheels, and suspension changes to get it down right....
  18. Nov 8, 2008 at 2:12 AM
    FoxySandChick
    Kristin
    Henderson, NV
    They price match, so find the lowest price online and take it to them, I did that with tires and wheels.
    My BF got a discount due to working at the Chevy Dealership.
  19. Nov 8, 2008 at 3:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Everything I find says otherwise:
    http://consumerguideauto.howstuffworks.com/2001-toyota-tacoma-3.htm
    http://www.internetautoguide.com/reviews/09-int/2001/toyota/tacoma/summary.html
    Seems the 4 doors are higher than the reg cabs. and extra cabs. Since the springs are a higher rate given the extra weight of the vehicle. Headroom is only 1/10th of an inch difference, so obviously the cabs are the same. Many of my friends with 4 door first gens are running 265/75/16's with no rubbing of any kind. This holds true for the second gen trucks, also.
    Im thinking your truck may have had weak springs?
  20. Nov 8, 2008 at 5:56 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    one thing about TG's.. they run very true to their size. Great tires though, excellent ride quality, tread life and very well priced.
    be sure to get LT rated and not P rated though ;)
