Nitto TG tire pressure
Discussion in 'Wheels & Tires' started by 06Bluez, Sep 21, 2008.
  1. Sep 21, 2008 at 9:57 AM
    06Bluez
    06Bluez [OP] Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I recently had 285/65/r18 Nitto TG's installed. the mechanic set the tires at 30psi. Ive noticed my gas mileage dramatically dropped and i only moved up about a half an inch or so in tire size. I checked the recommended PSI on the tire and it says 80!!! Any ideas on what PSI i should be running for better performance/gas mileage?
  2. Sep 21, 2008 at 10:01 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Do the chalk method. This method is a bit time consuming but I love it. Get some white chalk and make a thick line across the tread of all 4 tires. Start at I would guess 55 or 60 psi. After you have the mark drive forward a few feet make sure you stay straight and on good pavement or cement. Stop and check the chalk lines your goal is to have the chalk almost worn competely off, you will need to air up and down the tires to achieve this. Your rear tires will require less psi as they are not carring as much weight.
  3. Sep 21, 2008 at 4:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On my TG's Im running 34 front 30-31 rear. Found this via the chalk methode mentioned above. Thereason they are rated at 80 psi is because they are load range "E" tires. :)
  4. Sep 23, 2008 at 6:34 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I run 50 psi in my 285/70/17 Nitto TG's. seems to be ok, thats what my tire guy recommended. I rotate every oil change, with 25000 miles on them they look a little under half tread wear.
  5. Sep 23, 2008 at 6:50 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    at 50 psi is it a bumpy ride
  6. Sep 23, 2008 at 6:56 AM
    Dark Knight
    Jeff
    NC/SC
    Feels like a tank, specially with it being a DC LB, 3" lift and 33's....Love it!!!
  7. Sep 23, 2008 at 7:09 AM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
