Nitto Tires didn't fit.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TeaMan, Sep 22, 2012.
  1. Sep 22, 2012 at 3:51 PM
    TeaMan
    TeaMan [OP] Member
    I ordered my new Nitto Terra Grappler P285/70R17's and went to have them mounted today and to my surprise they didn't fit. I put a 3" lift and spydertrax spacers in and they still rubbed. I was very surprised since another member had a set of Nitto Dune Grappler P285/70R17's on his truck with the exact mods I have with no rubbing at all. It was bad enough that it couldn't be driven. They had no issue taking the tires back and I'm back to the drawing board to find a good fitting tire.
    Anyone know if the Terra Grappler runs a bit bigger than the Dune Grappler for any reason? I'm trying to figure out why one tire fits one truck and supposedly the same size tire from the same manufacturer doesn't fit the same truck. The technician thought it was the width that was the problem. I didn't get to see what it looked like on the truck, he had already dismounted the tire and had the stock one back on the rim. He said there was about an inch or so clearance going straight, but turning it hit the mud flap and the fender in front of the tire.
    Any ideas anyone?
    TeaMan
  2. Sep 22, 2012 at 4:22 PM
    Steve33fish
    Steve33fish Well-Known Member
    Yorba Linda
    13 Tacoma 4x4 LB
    Tire guy should have answerd that question?
  3. Sep 22, 2012 at 4:26 PM
    cgs2k2
    cgs2k2 old man
    put em back on and chop some plastic, or get some 265/70/17s
  4. Sep 22, 2012 at 4:28 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    im guessing it was the spacers giving you more turning radius. It will shove the tire against the wheel well. Trim it or get fenders. I had the same problem you had even with 265s and spacers. trim, hammer the pinch weld and do the cab mount chop.
  5. Sep 22, 2012 at 4:36 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    guy with dune grapplers probably had no flaps and trimmed.
  6. Sep 22, 2012 at 4:38 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    and now that you have a second chance, dont get the terra grapplers...
  7. Sep 22, 2012 at 10:46 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    alignment has a lot to do with rubbing but you're not gonna fit a tire like that without rubbing something. Either cut or get a 32. simple
  8. Sep 23, 2012 at 12:02 AM
    Tacoma1995
    Tacoma1995 Well-Known Member
    Lucas
    NC
    Tiffany The Tacoma
    different wheels?
    spacing has an affect also
  9. Sep 23, 2012 at 12:07 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    This
    And this...
  10. Sep 23, 2012 at 12:15 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    course you will rub the mud flap... then trim some plastic it will be worth having the 285's
    these were 295's and 3" liff
  11. Sep 23, 2012 at 12:31 AM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    trim trim and then trim some more... backspacing on the wheel can change it, alignment, spring weight (i cant fit my tires with a 500lb spring, cant even get out of the driveway with out ripping off my fenders.. 700lb spring is enough for me) amount of tread on the tires etc, "sagging" of the suspension, amount of suspension compression during turn (faster turns make more body roll etc..)
    I run 285-75-16 and I had to trim a lot off my fenders, grind / hammer down the pinch weld and get a cab mount chop.. its taken me 6+ months of trimming, then trimming a little more but i no longer have any rubbing :D
  12. Sep 23, 2012 at 6:24 AM
    TeaMan
    TeaMan [OP] Member
    Thanks for the great responses. I'd really like to leave the plastic on the truck and find a tire that makes it look good, is bigger than stock which is why I lifted the truck, and that performs in snow and ice which is the nasty condition I face for about 7 months of a year here. That was my objective to start with.
    It sounds like the wheel spacers may not have been a benefit by changing the wheel arc. Not that the tires would have worked anyway, but what did the spacers do for me with the 285's, would I have had rubbing on internal steering components? If I could have seen the truck with the tire mounted, it would have helped a lot. I don't need the width of the 285, I'd like the height of the 285/70R17 and want to keep the stock rims.
    Any recommendations down this path? One size recommended is a 275/70R17 but it's hard to find, even in the brand he suggested. I'm not a tire expert, so I don't know a lot about what sizes are real and available. It's easy to plug numbers into a tire calculator to get an estimate of size, but it doesn't mean you can get the tire....:(
    TeaMan
  13. Sep 23, 2012 at 7:35 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    If you dont need the spacers I would try without them to see if it doesnt rub, if not then I would go with a 275 Im pretty sure they are available you just gotta look for it.
  14. Sep 23, 2012 at 8:16 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
  15. Sep 23, 2012 at 8:18 AM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Do some trimming on the inner fenders and possibly the Cab mount. Some trucks can get away with not trimming the cab mount on 285's depending on wheel backspacing, tire tread design, alignment, etc.
  16. Sep 23, 2012 at 8:19 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    i didnt trim my cab mount with 315's :eek:
  17. Sep 23, 2012 at 8:23 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I trimmed mine with 285s with 5" lift and fenders....lol...well only cut one
  18. Sep 23, 2012 at 8:25 AM
    Brandon H
    Newhall, CA
    07 DC Offroad
    The first set of wheels (I have had 7 sets LMAO) were 285 BFG ATs on Ivan Stewarts with OME 885s and never Rubbed at all.
  19. Sep 23, 2012 at 8:32 AM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I have 265 and rubbed like crazy, mostly due to spacers, just trimmed a ton of plastic and hammered back the pinch weld. All you need is a dremel, sledge hammer, and a rattle can and a little time. No cab mount chop hear, I do rub slightly when the wheel is completely cut on non flat ground but its nothing major.
  20. Sep 23, 2012 at 8:38 AM
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    I have the same issue but with 255/75's now that I have added Spidertrax spacers. I will be headed to sick nicks tomorrow to get cab mount chop done. They use to not rub without the spacers.
