NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 3, 2015 at 5:59 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    oh sure thing thing man, anytime!
  2. Jan 3, 2015 at 6:21 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    $440.00 with tax. No AAL, should I ?
  3. Jan 3, 2015 at 6:29 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    you're probably fine without it, but with a heavy rear bumper/etc, i need beefy leaf springs.
    I have all pro expos right now that are 3-4 years old and sag pretty bad. I've been thinking I should replace them before moab and i've been thinking about trying dakar's since most of the NJDB's seem to have them.
  4. Jan 3, 2015 at 6:34 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    That's where I got my Dakars from, definitely worth the trip.
  5. Jan 3, 2015 at 6:48 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    I've had the dakars for almost 4 years now (march 2011 installed them), and they were almost flat at ride height from the beginning. They still hold the weight pretty well with a bedrack/RTT/rear swingout with no issues and flex pretty well since they broken/broken in :D. I plan to switch to chevy 63s once these packs are finally shot.
  6. Jan 3, 2015 at 6:55 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Refurb/Chevy springs ftw. What I plan on doing when I get the garage setup
  7. Jan 3, 2015 at 7:03 PM
    JLink
    Josh
    Ocean, NJ
    does the 63 mean 63" long? I've heard a lot of people talk about them but i've never seen a lot of info about them.
    i definitely need to increase my droop. I used the hi lift to jack up a slider and i'm able to get the rear tire off the ground pretty easily, and the top of the tire is a fair amount above the slider. I'm thinking because the leaves have flattened out i don't get as much droop as i should because the leaf pack isn't arcing as much as it should. :notsure:
  8. Jan 3, 2015 at 7:07 PM
    PSU Taco85
    optional
    yep 63" long, there is alot of info on them on pirate4x4. Pretty simple to make your own spring hangers or just buy the conversion kit from ruff stuff. They hold the weight fairly well and flex for days since they're from a bigger truck. I would think if the leaves are flat they would flex even better. usually the super arched leaves are the ones with no down travel since they pretty much just sit at the arch they'd be at at full droop.
    For the most confortable ride and maximum suspension travel (both up and down), the leafs should ideally be flat or slightly arched, just like in the front with IFS you don't want to crank the lift all the way up or else the ride gets harsh. If the leaves have alot of arch, they won't have alot of downtravel and likewise if they are inverted (like many of the stock taco springs) you get barely any uptravel and are riding on the bumps.
  9. Jan 3, 2015 at 7:29 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Another option at least for first gens is to use your main leaf and build a pack out of Chevy 3/4 tons or 1/2 tons from a junkyard.
  10. Jan 3, 2015 at 8:58 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I just got the Dakars with no AAL - since Ant & I did the BL, cranked down the Coils and swapped back to the stock length shackles the truck rides like a caddy. :cool:
    I've also got a good amount of weight in the back with the cap/bumper/RTT.
    IMO it sits pretty darn good on this setup.
    No need to lift it to the moon if you don't have to right?
    Those mall curbs can get pretty brutal tho. :eek:
  11. Jan 3, 2015 at 11:22 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    HEY SCOTT HOLD ONTO YOUR CURRENT LEAF PACK IF YOU CAN AND SINCE BPF DOESN'T PLAN ON ANYTHING SOO ILL BUY YOUR LEAF PACK OR TRADE YOU SOMETHING FOR IT AFTER BASIC! Thanks :D
  12. Jan 3, 2015 at 11:34 PM
    Rebelimo
    Rebelimo Well-Known Member
    Coatesville
    08 4x4 Silver streak Limo
  13. Jan 4, 2015 at 7:49 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    lol
  14. Jan 4, 2015 at 8:04 AM
    JLink
    Josh
    Ocean, NJ
    Looking for info on 2nd gens on 63s I can't find anything. I'll definitely wait and let you do it first :p
    I think dakars are in my future.
    Your bed is usually pretty empty compared to mine so with that in mind I'll get the AAL.
  15. Jan 4, 2015 at 8:08 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Josh you see my text about your heating unit?
  16. Jan 4, 2015 at 8:17 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    I got the dakar w/ AAL installed for the swing out rear on the way, but I love the rake with no weight while I wait. Who doesn't like liff
  17. Jan 4, 2015 at 8:40 AM
    jrzyshore
    Scott
    SNJ
    Agree.
    I will hold on to them for a little while.
    :goingcrazy: The scary part is he will only be a 5 minutes away from my house.
    I like the rake too but I alreay have some take with the Eibachs in the front and the TSB AAL in the rear. So I may install them and see how it goes and possibly add the AAL later.
  18. Jan 4, 2015 at 8:41 AM
    JLink
    Josh
    Ocean, NJ
    Yea. You see my text about it?
    :p
  19. Jan 4, 2015 at 8:56 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Just make sure to take a day trip away from your house on the day Hunter is doing target practice. :D
  20. Jan 4, 2015 at 9:03 AM
    yota4Whelz
    yota4Whelz Well-Known Member
    Orange County NY
    2009 Tacoma DCSB TRD Sport 4x4
    -Removed mudflaps -Blacked out tail lights/ third brake light -Blacked out emblems -Truxedo truxport tonneau cover -Tailgate theft mod -Eyelids (Toyotaman) -Center console organizer (Salex) -WeatherTech Digital fit floor liners -BHLM -Wet Okoles fronts and backs -Homertaco satoshi grill -Pioneer h/u -Disabled seat belt chime -LED gauge swap (Jerez) -BAMF Light bar w/ 2 hella 500ffs -Old Man Emu 90000 front shocks, 885x coilovers, nitro sports and AAL in the rear -285/70/17 wrangler duratracs -1.25 Bora spacers (4) -Super 40 series Flowmaster -Differential breather mod -Blacked out bedsides -Method NV Race wheels -EGR in channel window visors -Interior/license plate/tails LEDs (Jumpers LEDs)
    Got my bsp bumper with fog lights and bulbs for sale if anyone's interested $150 obo pm or txt 8456998423
