NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Dec 2, 2015 at 7:36 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    BPF is always open for business
  2. Dec 2, 2015 at 7:55 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I haven't found anything on it either. The funny thing is I had an issue with the rear main seal last year and had that covered under warranty. I was under there after the last Rausch trip because I was leaking power steering from one of the fittings on the pressure line. I then sprayed everything down with brake clean to clean up all the oil and drove it for a week with no leaks. I then noticed the passenger side diff seal was leaking and as I was fixing that I noticed a little oil leak coming from under the crank shaft pulley that over the past week has seemed to got worse. But honestly I have no idea.
  3. Dec 2, 2015 at 8:02 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    sooonishhh
    jrzyshore likes this.
  4. Dec 3, 2015 at 6:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I still need to insulate and get my gas lines run for a heater. Was supposed to do that before winter. Why is everything so damn spensive.
  5. Dec 3, 2015 at 7:50 AM
    jrzyshore
    Scott
    SNJ
    :rolleyes: Right!
  6. Dec 3, 2015 at 8:09 AM
    Azazruk
    Azazruk Well-Known Member
    NJ
    Any of you fellas have a 17" wheel you would like to part with? I picked up a set of 4 but need something for the spare.
  7. Dec 3, 2015 at 12:26 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Sears at the freehold raceway mall has a set of 4 dick cepek wheels for 400$ 6x5.5 just throwing that out there if anyone is interested
  8. Dec 3, 2015 at 1:36 PM
    Tatts521
    Does anyone have experience with boss toytec rear shocks no res. ?
  9. Dec 3, 2015 at 3:26 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    brighter than daylight!!
    my 50'' is awesome. just wish i got to use it more
    wtf! so many leaks!
    I kinda regret installing the heater in my garage last winter. having a warm garage was great, but the gas bill was close to $100 higher every month, and the heat in the attic created a condensation effect and now i think i have to replace all the plywood when i redo my roof. when I do get to the roof i think i'll add soffit vents and insulation baffles to hopefully combat that problem.
    are you doing the work yourself?
  10. Dec 3, 2015 at 3:35 PM
    Tatts521
    @JLink can't wait to use that light bar on ppl driving with there high beams on at night haha
  11. Dec 3, 2015 at 3:36 PM
    fletch97
    fletch97 Well-Known Member
    NJ
    2020 Tacoma TRD Sport
    I just had the entire Toytec boss kit installed about 2 months ago.
  12. Dec 3, 2015 at 3:38 PM
    Tatts521
    How do u like ur boss set up
  13. Dec 3, 2015 at 3:58 PM
    JLink
    Josh
    Ocean, NJ
    i know how you feel, but i wouldn't recommend doing that. its bright enough that you could temporarily blind someone and cause an accident. definitely not worth it.
  14. Dec 3, 2015 at 4:02 PM
    Tatts521
  15. Dec 3, 2015 at 4:26 PM
    fletch97
    NJ
    It's been pretty good. The full Dakar leaf pack has pretty much squeaked since day one but it doesn't bother me much and I only hear at slow speeds with radio off. I haven't gone off-roading since I had them installed so I can't comment on that yet but on pavement is good. Cornering is so much better than stock!!
  16. Dec 3, 2015 at 4:39 PM
    Tatts521
    @fletch97 yea I hate the amount of body roll my stock coma has. Slowly getting everything done. Wish money grew on trees
  17. Dec 3, 2015 at 4:41 PM
    fletch97
    NJ
    So do I! Always seems to be an endless supply of things you want to do to the truck.
  18. Dec 3, 2015 at 5:12 PM
    nj636
    Kev
    Jersey
    Ocean County here as well :wave:
    EcoBill[QUOTED] likes this.
  19. Dec 3, 2015 at 5:51 PM
    JLink
    Josh
    Ocean, NJ
    just wait till you lift it and take off the sway bar! its like driving a boat.
    The Hunter and jrzyshore like this.
  20. Dec 3, 2015 at 5:59 PM
    jrzyshore
    Scott
    SNJ
    That's why mine is still on for now.:D
