NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Dec 3, 2015 at 6:06 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    x2
    I refuse to drive on the highway without it. Damn near wrecked Fred's FJ with his removed. :oops:
    The Hunter and jrzyshore[QUOTED] like this.
  2. Dec 3, 2015 at 6:06 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    :rolleyes: I almost forgot I had a real bad water pump leak too at 40k that was covered under warranty.
  3. Dec 3, 2015 at 6:08 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I would like to devise a disconnect tho... :drevil:
    The Hunter and jrzyshore like this.
  4. Dec 3, 2015 at 6:08 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I'm pretty sure that our long wheel bases and leaf spung rears keep it a lot more stiff than an FJ anyway, but I don't have any complaints with running without a sway bar.
  5. Dec 3, 2015 at 6:09 PM
    jrzyshore
    Scott
    SNJ
    There's got to be a way.
  6. Dec 3, 2015 at 6:09 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Says the hippie with a longer wheelbase than me. :p
    The Hunter likes this.
  7. Dec 3, 2015 at 6:11 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    There is. I've got some ideas that Ant & I have kicked around. Really just need the time to do it. :oops:
  8. Dec 3, 2015 at 6:15 PM
    JLink
    Josh
    Ocean, NJ
    FJC wheelbase- 105.9″
    Tacoma DCSB- 127.4"
    Tacoma DCLB- 140.6"
    :notsure:
  9. Dec 3, 2015 at 6:19 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I know. ;)
    Just call me the cautious old man. :laughing:
  10. Dec 3, 2015 at 6:43 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah usually do. Insulation is the easy part, doing the gas lines would be a bit harder. I have a ton of pipe fitter friends I can probably borrow threaders from which will make it that much easier though. And honestly I'll probably only run it on the days I need to paint or its ridic cold out. I doubt I'll have a condensation issue though, ton of open air up there.
    Ripped mine out and never looked back the moment I put new coil overs on. I do think if I had to make a super fast deer swerve it might be a tad sketch. But as far as daily driving goes it's not bad at all.
  11. Dec 3, 2015 at 7:21 PM
    JLink
    Josh
    Ocean, NJ
    oh i will! :p
    yea i was going to say running gas lines is easy. I ran everything from the meter into the house. I just measure what i need and go to home depot and buy what i need and have them cut and thread it. just use plenty of pipe dope and tighten it down real good.
  12. Dec 3, 2015 at 7:57 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    You only have to disconnect one side to make it not function.
    You want one you can disconnect from the cab?
  13. Dec 4, 2015 at 3:06 AM
    jrzyshore
    Scott
    SNJ
    :wave: I've ran a lot of gas lines. I still have my Trac Pipe cert fom way back when I work for a plumber. It's pretty easy just make sure you soap up your fitting when you are done to make sure there are no leaks.
  14. Dec 4, 2015 at 4:05 AM
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    Soap and water to check for leaks...the classic way not the "sniffer" I do the work before the meter and after, lmk if u need any tools mike
    Fifthwind likes this.
  15. Dec 4, 2015 at 4:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Thanks guys! I'll probably at minimum insulate this year and grab a propane attachment from my dad for now.
  16. Dec 4, 2015 at 6:18 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    GPF Gas Pipe Fab $15 holladayz special at mikes house
    PSU Taco85 likes this.
  17. Dec 4, 2015 at 7:07 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Even easier is to just use a map gas torch and go around the fittings, leaks become obvious pretty quick. My dad has a whole trailer with a threader and cuter on it for both 1/2 and 3/4" if anybody ever needs some black pipe ran :D
    Chux and Blackout14 like this.
  18. Dec 4, 2015 at 9:00 AM
    TuckHolladay
    TuckHolladay Well-Known Member
    JT
    NJ
    2015 TRD Offroad, Blue, stock for now
    Hey I am in NJ and am thinking about getting a Tacoma. Anyone have a reputable dealer they like?
  19. Dec 4, 2015 at 9:34 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Just use a CO (Carbon Monoxide) detector with propane heaters, they are notorious for CO; don't want ya to take the permanent snooze.:thumbsup:
    fletch97 likes this.
  20. Dec 4, 2015 at 3:05 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    That would be a problem... We'd have to find someone else to make RC videos :luvya:
