NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Aug 21, 2013 at 8:38 AM
    #3201
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Yeah... I still look younger than you.
  2. Aug 21, 2013 at 8:41 AM
    #3202
    cynicalrider
    cynicalrider #NFG
    Jersey
    Are you sure you are full on fluid and not leaking?
  3. Aug 21, 2013 at 8:51 AM
    #3203
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    The temp gauge seemed to be higher but it could just be me....I will take a pic of the gauge when I get out of work and no I'm not leaking any fluid
  4. Aug 21, 2013 at 9:13 AM
    #3204
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Don't hate on the good genes son
  5. Aug 21, 2013 at 9:27 AM
    #3205
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    .38 special, .357 magnum, 9mm, .22LR
    Haven't seen .22 for a decent price in almost a year. The other 3 I've been able to find here and there.
    That's perfect
    They're better than nothing, but I prefer shooting outside regardless of the range.
    A few people have killed themselves at shore shot. (Not accidentally)
    This
    This too.
  6. Aug 21, 2013 at 9:39 AM
    #3206
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I used to get 9mm in PA for $9.50... Now its like 20something.... At the very same spot
    I like to shoot outside too...but the only place I have to do that is my in-law's land in upstate ny.... Like 5 hrs away....so it doesn't happen too often... I just got a 5.56 and I'm itchy to go break it in...
  7. Aug 21, 2013 at 9:41 AM
    #3207
    JLink
    Josh
    Ocean, NJ
    There's a few 24 hour ranges and not all are expensive.
    Quite unlikely that I'd ever go shoot past 10:00pm or before 10:00am though
  8. Aug 21, 2013 at 9:43 AM
    #3208
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    Are u f ing serious u wouldnt be there before 10pm on your best day
  9. Aug 21, 2013 at 9:44 AM
    #3209
    JLink
    Josh
    Ocean, NJ
    Yea I try not to pay more than $20 for 50 rds of 9mm. Usually ill only buy it if its $15 or if I really need it.
  10. Aug 21, 2013 at 9:45 AM
    #3210
    JLink
    Josh
    Ocean, NJ
    :rofl:
  11. Aug 21, 2013 at 10:31 AM
    #3211
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    I see wires...
  12. Aug 21, 2013 at 10:33 AM
    #3212
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I don't even think u grow armpit hair...
  13. Aug 21, 2013 at 10:37 AM
    #3213
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Where are this 24hrs ranges in NJ?
    I think I suddenly developed insomnia!!!!!
    Idk but that's really cool all jokes aside.... "Oh shit...can't sleep" pop pop pop.... Granted... It would have to be a close drive!
  14. Aug 21, 2013 at 11:15 AM
    #3214
    JLink
    Josh
    Ocean, NJ
    You had shit apart that didn't need to be apart, and didn't take apart what needed to be taken apart! :rofl:
    The A pillar comes off with 2 10mm bolts and that's the only thing that needed to come off.
    This! Now fix it hunter! :D
    They are all private clubs so you have to be a member to go there. One or two in Jackson and I believe the oldbridge club is 24 hours too
  15. Aug 21, 2013 at 11:45 AM
    #3215
    JLink
    Josh
    Ocean, NJ
    Where's it going now? Through the headliner and down the A pillar?
    For future reference you can remove the A pillar and then tuck the wires behind the black door seal trim to run it down below the dash. That way if you have to remove it you just have to remove the A pillar and tug on the wire.
    Looks good though.
    Edit:
    I thought there were 2 wires... Why did you wrap the wire up around the visor and then down? Still see too much wire lol
  16. Aug 21, 2013 at 11:59 AM
    #3216
    JLink
    Josh
    Ocean, NJ
    Fair enough
  17. Aug 21, 2013 at 4:14 PM
    #3217
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    unsubbed
  18. Aug 21, 2013 at 4:39 PM
    #3218
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Welcome back Skip :cool:
    You didn't miss anything..
    besides bashing Hunter :rolleyes:
  19. Aug 21, 2013 at 4:58 PM
    #3219
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    not lying - I've considered it. :rolleyes:
  20. Aug 21, 2013 at 5:00 PM
    #3220
    XXXX
    sKiP
    05 Prius
    time to clean this crap up in here
