NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Aug 17, 2016 at 7:50 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Can you report back to here with your results. This shackle flip still baffles me as to any true benefit.
  2. Aug 17, 2016 at 7:51 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Trying to get ready for this weekend
    Tatts521 likes this.
  3. Aug 17, 2016 at 7:52 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    What you doing this weekend?
  4. Aug 17, 2016 at 7:53 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Mounting my tires on wheels and putting them on the truck, and maybe putting on new ucas ;)
  5. Aug 17, 2016 at 7:54 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Sure will. Was just thinking that the flip moving the axel lower also allows it to go into more of a negative arch, therby actually increasing wheel travel.
  6. Aug 17, 2016 at 7:55 PM
    Subway4X4
    Lloyd
    NY/NJ
    Damn, I thought you were gonna go wheel'n with inviting us!
    stairgod likes this.
  7. Aug 17, 2016 at 7:57 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Another benefit to the shackle flip is the ability to alter the spring rate of the leaf pack
    The Hunter likes this.
  8. Aug 17, 2016 at 7:57 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Not yet, I was thinking labor day weekend tho
  9. Aug 17, 2016 at 7:59 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I will be around Friday night if you want the UCAs
    Sub-Zero[QUOTED] likes this.
  10. Aug 17, 2016 at 7:59 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Explain please
  11. Aug 17, 2016 at 8:26 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Here comes math. :lalala:
    Blackout14, The Hunter and stairgod like this.
  12. Aug 17, 2016 at 8:28 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    It's all physics. And physics required math. And math requires alcohol. Or used to at least. :(
  13. Aug 17, 2016 at 8:28 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Sweet thanks, they just did an alignment today....it was not looking good
    Tatts521 and stairgod[QUOTED] like this.
  14. Aug 18, 2016 at 12:19 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I just realized its been roughly 12k miles since ive rotated my tires :eek: :anonymous: ehh whats another few hundred while I wait for the new tires to come in
  15. Aug 18, 2016 at 12:20 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Get new TCs from DSM!!! 665 shipped for me. I think thats just the blanket TW discount
  16. Aug 18, 2016 at 1:24 AM
    PSU Taco85
    optional
    Angle of the dangle
  17. Aug 18, 2016 at 1:29 AM
    PSU Taco85
    optional
    With the stock inverted shackle setup this adjustment is not possible
    And you can see, even with tiny tires, more articulation is gained assuming you relocate your shocks to be able to handle the travel
  18. Aug 18, 2016 at 2:55 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    I need shackle flip in my life.....
    need to find my 4x shackle flip :anonymous:
    It's missing in the mess I call my garage/shed.
  19. Aug 18, 2016 at 3:00 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    That pic really shows how the shackle angle changes through the movement of the spring from arched to flat. I am having a hard time wrapping my head around the idea of shackle position effecting spring rate though. Not sure how the shackle can either cause more or less force needed to flatten out the leafs.
  20. Aug 18, 2016 at 3:58 AM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    It doesn't, at different angles tho, more of the suspensions movement is a result of shackle movement than spring compression. IE, at < 90* net suspensions travel is more from leaf spring compression than shackle movement, at >90* net suspension travel is more from shackle movement than spring compression there for "lessening spring rate"....I think. I'm just taking guess here
