NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Aug 18, 2016 at 4:57 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Because lazy.
  2. Aug 18, 2016 at 4:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not sure if you did all the fenders yet but this method worked well for me for solid marks:
  3. Aug 18, 2016 at 5:22 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I did the fronts, rears today. Yea I was going to do that but got lazy and just taped those pencils, it worked fine...How did you protect the edge from rust and also what section of home depot did you get the little rubber trim you put on yours?
  4. Aug 18, 2016 at 6:28 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I figured the adhesive I used was going to protect it enough. I used 3M Plastic and Emblem adhesive on the edge all the way around and then used this stuff I got from the local pep boys:
    It's that same shit ricers put on all their doors in chrome lol
  5. Aug 18, 2016 at 6:33 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    The only reason the shackle moves is because the eye to eye distance of the springs changes as it goes through its cycle. Shackle angle at static ride height should be determined by the length of the spring at its longest to ensure that the shackle can move that far without obstruction. So in all actuality the shackle angle at static rise height is immaterial. Or so my brain tells me.
  6. Aug 18, 2016 at 6:34 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Alright yea I was wondering if I should just use adhesive to prevent rust, thanks!
  7. Aug 18, 2016 at 7:06 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    No problem :thumbsup: You'll love rocking the dirty 5's.
  8. Aug 18, 2016 at 7:27 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Soon well all have inboarded shocks and shackle flip like Ant
  9. Aug 18, 2016 at 7:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not this guy. Also shackle flip from the factory ftmfw.
    The Hunter[QUOTED] and ToyRyd04 like this.
  10. Aug 18, 2016 at 8:07 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Shackle lengths & Angles act as levers on the springs with the weight of the vehicle. Setting the shackle angle really is a balance of three things 1. Ride Height 2. Spring Rate, and 3. Spring movement in an ARC.
    Offroad wise, a "laid back shackle is ideal" (60*+ from a vertical shackle) While the spring has less ride height and spring rate, when flexed, the spring will go back to its natural arc as well as the additional travel from the shackle length + angle.
    Onroad wise, a more "traditional" shackle angle is (45* and less from a vertical shackle) Now the spring has more arc and more height, adding more spring rate to the pack. When flexed since the springs are closer to the natural arc they will only rely on the little bit of shackle angle left for travel.
    Essential the further of an angle that the shackle has, the more of a role it plays in the decrease of spring rate.
    HomerTaco likes this.
  11. Aug 18, 2016 at 8:50 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    First gens worst gens
  12. Aug 18, 2016 at 8:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    That first gen as done more trails at RC on 265's and no lift than you. ;):p
  13. Aug 18, 2016 at 9:17 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    So fragile though....
    :boink:
  14. Aug 18, 2016 at 9:27 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Lol it's not fragile, Mike drives it how it wants to be driven, sometimes shit happens :notsure:
    The Hunter and stairgod like this.
  15. Aug 18, 2016 at 10:16 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Lol either you or Tim were right behind me when it happened. I had no business trying that obstacle from that side on stock gears and no front locker. :rofl:
    I have however been up the backside on 265's too.
    :D Next time will be up and over from the backside but not till after I get back from Moab. Goals are to get my shit into tip top shape for Moab because driving cross country ain't no joke. Will probably do some easier trips to RC in the early spring to work any bugs out.
  16. Aug 18, 2016 at 10:20 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    That 2' ledge will get you, nice photo!
  17. Aug 18, 2016 at 10:52 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    funny... I've never done that one. Maybe next time
    The Hunter likes this.
  18. Aug 18, 2016 at 11:16 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    It's the 4x innovations kit. It's a good kit and works well your just limited on shackle options because it uses the same style wide on one end and narrow on the other that the stock shackle is. Also I set everything up to provide minimal lift. Those photos I posted are stock verse flip kit at full droop. The truck is on a lift with all 4 tires off the ground.
    Please stop talking. Thank you.
    stairgod[QUOTED] and planters15 like this.
  19. Aug 18, 2016 at 11:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I blame @ToyRyd04. I saw him go up and over on my 2nd Rausch trip and it's made me want to ever since.
    Sub-Zero likes this.
  20. Aug 18, 2016 at 11:29 AM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    HAHA I dub that thee 1st gen hill. :burnrubber:
    Breakover angle is perfect for 1st gens, just by a c*** hair it kisses the gas tank at the very front.
