NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Sep 7, 2016 at 7:35 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Cool.
  2. Sep 7, 2016 at 7:35 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Sorry to hear that Tim :( tell her I send my best
  3. Sep 7, 2016 at 7:35 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Sorry to hear.
  4. Sep 7, 2016 at 7:37 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Sorry to hear that. Let me know, and I might just cut my visitation short to Jon
  5. Sep 7, 2016 at 7:38 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thanks Ryan, will do.
  6. Sep 7, 2016 at 7:40 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    If he's going to help you with welding or whatever, no worries. I won't be offended if you don't make it :thumbsup:
    fatfurious2[QUOTED] likes this.
  7. Sep 7, 2016 at 7:40 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you John
  8. Sep 7, 2016 at 8:02 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Sorry to say but your only options are pulling the rack or the diff. If you go the rack route make sure you straighten the rack fully, and lock the steering wheel in place. If you reinstall a spline off on the internediate shaft you will be driving with a cockeyed steering wheel.
  9. Sep 7, 2016 at 8:41 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Phew ima start doing research, how many hours is the job you think Mike?
  10. Sep 8, 2016 at 4:22 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    :confused: i wouldn't say I wheel the piss out of it... I would if I got invited more often now that I make money to fix it but Ive wheeled the local sand pit to me every weekend.
  11. Sep 8, 2016 at 5:34 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    2-3 hours tops with air tools and two people I think. I would go pulling the diff route. Remove the 4 lbj bolts on each side, pop the cv's from the diff but leave them in the spindles, and drain and drop the diff. Make sure you use blue loctite on the lbj bolts when you put them back. I would also mark the bolts with a paint pen so @sente3 can make sure they aren't backing out. Lbj failures are really common on first gen's due to lbj failure or one bolt backing out and the rest shearing
    Sub-Zero[QUOTED] likes this.
  12. Sep 8, 2016 at 5:44 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    @sente3 spray all the above mentioned bolts with pb blaster frequently between now and when I get there. Get some blue lock tite and a paint pen. Do you have Jack stands and a decent Jack? Get oil for the diff 75w90 I think it is, and hopefully you have a drain pan too
  13. Sep 8, 2016 at 5:44 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Thank you, we won't have air tools tho :/
  14. Sep 8, 2016 at 5:47 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I agree tho dropping the diff sounds better than pulling the rack. We can get it done
  15. Sep 8, 2016 at 6:06 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Oh and you'll probably need to disconnect the front driveshaft too. only 4 nuts I think. Could probably leave it on but it would make it easier. I've never actually pulled my diff, but this is what I would do if it was me. @ToyRyd04 any other advice?
    Sub-Zero likes this.
  16. Sep 8, 2016 at 6:06 AM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    @sente3 since your going to be there, check your steering rack's bushings. I changed mine this summer. Everything underneath our trucks wear quicker because of the winters here.
  17. Sep 8, 2016 at 6:21 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    The word is that you say you do on FB.... I haz no FB so I cant confirm nor deny such accusations... I did see screenshots but those could be manipulated... I would not think you pose like that...
    Unless you getting pizza delivered and you need a welding mask
    JLink[OP] likes this.
  18. Sep 8, 2016 at 6:25 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    I don't say i do on facebook... Was talking to some dude on FB about his $120 clevis he has on his pavement princess though...
  19. Sep 8, 2016 at 6:34 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Tried to weed through the bs,got lost. Is a 1st gen guy trying to just replace the ADD actuator? @cynicalrider
  20. Sep 8, 2016 at 6:39 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    :spy:
    Disclaimer: I do not have the rights to this photo nor do I have AT&T therefore I didn't take the screenshot. But it does appear Fabs is correct
    Sub-Zero and JLink[OP] like this.
