NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Sep 19, 2016 at 9:15 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Im going to pass this weekend. But if you guys go for a winter run, I'll join. Hopefully have the rest of my skids by then
  2. Sep 20, 2016 at 3:01 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Only rubbing when flexed on the cab mount... but I will do that today
  3. Sep 20, 2016 at 3:44 AM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    it won't flex more but the up travel would definitely be useful if you're somewhere other than level and the other tire is already up travel from flat. Idk if that makes sense but I personally would want as much suspension travel as possible, why limit it with bump stops if you're not at the max travel of the springs and shocks?
  4. Sep 20, 2016 at 3:46 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Was Jay drinking the liquid courage and telling you that you can do it?
  5. Sep 20, 2016 at 4:10 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Nope. That makes perfect sense. Rookie mistake. Looks like the angle gender is coming back out tonight...
  6. Sep 20, 2016 at 4:53 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Here is my plan. Anyone with actual experience please chime in( that means not you Hunter). I am going to remove all the leaves my my Dakars and just use the top leaf and my factory block, which will give me the exact height if my new fully installed leaf pack. I am going to tack my upper shock mount in place, droop it out, taxk the lowers at max shock extension minus 1/2". Then Jack the rear up until I am at max compression minus 1/2" and set my bumos for that height. That will give me 11" of travel out of a 12" shock. That should set me up to keep from topping or bottoming out my shocks. Whether or not I ever actually acheive max droop or stuff with a full pack remains to be seen. Anything wrong with this plan?
    Subway4X4 and Arcticelf like this.
  7. Sep 20, 2016 at 4:58 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Well with the trajectory of the moon and the sun id sayyou have a solid plan.
    @Wheelspinner hows that sound?
    stairgod[QUOTED] likes this.
  8. Sep 20, 2016 at 5:26 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Seems like extra work. I'm not super familiar with the bamf relocate but the top is pretty much "this is where it goes" correct? Then the axle mounts are where you adjust for your specific shock. Once you have your shackle flip done (not sure if you have or not) if you jack the truck up by the trailer hitch/ rear bumper that will get you full droop With a full pack. Then if you jack up one side at a time by the axle you should be able to get full compression. Maybe add some weight to the bed first if your running the add a leaf. That's how I set my shackle position and bumpstops up. I'm getting between 10.5"-10.75" out of my 11" shocks
  9. Sep 20, 2016 at 6:39 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    The top is set height wise. Just have to position it forward/aft on the frame. Shackle flip will be done prior to setting shock tabs as the rear of the spring will be lower by about 3/4" at the shackle eye(which should only be 3/8" at the axle and slightly less at the shock mount). I can always use a ratchet strap around the axle and frame to get full compression if I can't get enough weight in the bed
  10. Sep 20, 2016 at 7:01 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    @stairgod Yea that would work. Also keep in mind with your bumps not only are they there to keep your shocks from bottoming out but you also don't want your springs going too far into negative arch. I mean a little is okay and the dakars aren't the most arched to begin with but it might be a factor depending how the shocks end up. It might not matter either because your shocks are probably fairly long even collapsed. It's something your gonna have to get it all setup and see how it plays out.
  11. Sep 20, 2016 at 7:08 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I am not going to rush through it. Thanks for your help Steve.
  12. Sep 20, 2016 at 7:45 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    What do you need cut? I have oxy-accetalyne in my shed...
  13. Sep 20, 2016 at 7:47 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    :thumbsup:
  14. Sep 20, 2016 at 7:55 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    He has to adjust the trans skid to fit the stock crossmember. This will require cutting some of the lip and re drilling a few holes.
    Realistically, it could be done with a angle grinder and some patience.
    Sub-Zero likes this.
  15. Sep 20, 2016 at 7:59 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    \/\/ that.
    It can. Time is what I do not have. Well now I will since the GF is going to be busy as fuck for the next 2 months with school. Ill be lucky to see her once a week. Gonna have to make excuses to show up at your place and then tell her im in the neighborhood and head over there LOL.
    stairgod likes this.
  16. Sep 20, 2016 at 8:13 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    So get a grinder and get cutting. Sounds EZPZ.
  17. Sep 20, 2016 at 8:17 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    I made an entire trans/transfercase skid in a few hours with a grinder drill and welder. How long can a little change take sonny boy?
  18. Sep 20, 2016 at 8:37 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Possibru today.
  19. Sep 20, 2016 at 9:07 AM
    Arcticelf
    Gladiator
    I'm still not sure what the issue was in that spot, it was far from the hardest thing we did that day.
    The Hunter[QUOTED] likes this.
  20. Sep 20, 2016 at 9:16 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Loss of traction not enough down travel... shorter wheel base then your truck. Also trying to avoid the rock that wanted to touch my door really bad
