NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Oct 3, 2016 at 1:34 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    No, for a bumper I'd imagine $100/$200 or something
  2. Oct 3, 2016 at 1:42 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    For my rear bumper and swingout, it was $400. But im in Va.
  3. Oct 3, 2016 at 1:52 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Oh that's not so bad. Cool
  4. Oct 3, 2016 at 1:53 PM
    04yota
    Angelo
    Central New Jersey
    So this is supposed to be stronger and longer lasting than a painting?
  5. Oct 3, 2016 at 2:03 PM
    fatfurious2
    David
    Ashburn, VA
    Yes, but harder to touch up. Ie, spray paint is easier to touch up
  6. Oct 3, 2016 at 2:33 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    I'm still blown away on how well the front lift feels. 10x better then stock.
    Sub-Zero likes this.
  7. Oct 3, 2016 at 2:43 PM
    04yota
    Angelo
    Central New Jersey
    sounds like the way to go :)
    Tatts521 likes this.
  8. Oct 3, 2016 at 2:50 PM
    Tatts521
    @JLink yes my rear leafs are shot they are negative. No beuno
  9. Oct 3, 2016 at 2:52 PM
    Tatts521
    My buddy used rhino lining on his front bumper and it looks awesome. Polly cheaper to buy sum and brush it on your self
  10. Oct 3, 2016 at 3:53 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I painted all my armor in vht chassis black. Bumpers are worth powder coating cause you don't scrape them as much as sliders but get an easy color to touch up. I scrape the bottom of my rear bumper a ton.
    04yota and fatfurious2 like this.
  11. Oct 3, 2016 at 5:00 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Blower!
    Definitely start with the easiest and check fuses...
  12. Oct 3, 2016 at 5:17 PM
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Thats the price I'm looking for but that shop is almost 3 hours from my house so i need to find somewhere closer to me.. Anyone else get it done in NJ for around this price?
  13. Oct 3, 2016 at 5:38 PM
    04yota
    Angelo
    Central New Jersey
    Will do! hey brotha how you liking the 35s? any issues with the stock gears?
  14. Oct 3, 2016 at 6:03 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Low-cost exhaust in Fairless Hills PA. That's in lower Bucks County and a heck of a lot closer than Schukill Haven
  15. Oct 3, 2016 at 6:21 PM
    PPansini10
    Paul
    NJ
    Okay great ill look into that shop!
  16. Oct 3, 2016 at 6:52 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Here's the fix guys! From my Toyota Technician buddy in the 50's thread.
    Thanks everyone for your input.
    And yes @V5ioV , it was the BLOWER!
  17. Oct 4, 2016 at 2:55 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    If that was the fix, I'm sure it will happen again soonen than later.... seems to me like its worth it to give a clean like the write up @Sub-Zero linked....
    If it fails again while your windshield is foggy it's going to suck.
  18. Oct 4, 2016 at 3:29 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Spray paint over crinkle powder coat is the best of both worlds.
    MY50cal likes this.
  19. Oct 4, 2016 at 6:05 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Guess he didn't read it:notsure:o_O
    The Hunter likes this.
  20. Oct 4, 2016 at 6:09 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    "First attempt was pulling the filter and cleaning things up a bit. So with a strong pimp hand I gave the motor a good slap and it starting working again.
    I thought that was it. The following day the motor got kind of noisy. This warranted a more in depth inspection."
    Fyi lloyd :thumbsup: just in case
