NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Oct 30, 2016 at 4:11 PM
    Urineovrurhead
    Urineovrurhead Well-Known Member
    05 taco
  2. Oct 30, 2016 at 4:38 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    3412 for me... idk the bottom of the con rods have an injection port but I swear that the con rod cap had a scoop on the back to scoop oil and inject it into a little tube that went all the way up to the wrist pin.
    Yes thats a splash type lubricating system... they are actually designed to splash in the sump... if you check the oil while its running it will spray out of the dip stick tube...
    Most house hold air compressors are this type as well... reciprocating air compressors are the exact same concept as an engine...
  3. Oct 30, 2016 at 4:46 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Two stroke or four stroke?
    Wheelspinner and Tatts521 like this.
  4. Oct 30, 2016 at 6:48 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
  5. Oct 30, 2016 at 8:44 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I've never changed brake lines or bled brake system.
    I'm gonna install extended brake lines from @OCTaco and SpeedBleeders.
    Any words of wisdom before I tackle this?
    fatfurious2 likes this.
  6. Oct 30, 2016 at 8:46 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Do it carefully.
    sente3 and fatfurious2 like this.
  7. Oct 30, 2016 at 8:59 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    the fronts, you need to pump the brakes and hold. Its a 2 person job. Look up the process online. I am doing my fronts tomorrow.
    The rears, is a different system. Learned this when doing someone elses. You need to have the key on ACC, but not engine on. Then one press, and the system will push the fluid through. Make sure NOT to let the brake fluid get below the lower line of the reservoir in the engine bay. Might be better to have 3 people. One to watch the fluid, one to press the pedal, and one to be at the bleeder, bleeding
  8. Oct 31, 2016 at 3:17 AM
    Tatts521
    Ifs skid will be here tomorrow. Painting it red..
  9. Oct 31, 2016 at 3:35 AM
    fatfurious2
    David
    Ashburn, VA
    what if it comes tuesday?
    diabetiktaco likes this.
  10. Oct 31, 2016 at 4:36 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Attach the top of the line first wait til brake fluid runs out the end of the new line and then screw on... you can bleed the brakes by yourself... you just have to build as much pressure as you can. I did mine by myself and I didn't even get air to bleed.
    You make things too complex lol
    fatfurious2[QUOTED] likes this.
  11. Oct 31, 2016 at 4:40 AM
    fatfurious2
    David
    Ashburn, VA
    the rears are different, I swear! there is an electronic pressure system thing there
  12. Oct 31, 2016 at 6:45 AM
    Tatts521
    It is coming in on Tuesday but we will see how accurate that is.
  13. Oct 31, 2016 at 6:48 AM
    Tatts521
    I ordered the jumper led hood light kit. and a fumoto valve. not that dumb little clip thing shit was 4$ and 5$ shipping and handling. WTF...
  14. Oct 31, 2016 at 6:51 AM
    Tatts521
    I did the brake thingamajig on my cousin car it's not hard but it helps with 2 people.. makes thing so much easier
  15. Oct 31, 2016 at 7:24 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    :notsure: I always bleed with the truck off...
  16. Oct 31, 2016 at 7:43 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    3.75" BS is the ideal BS for these trucks. You will clear the UCA fine, really clearing the UCA is typically not an issue, it's clearing the frame. You will clear the frame too though. You will likely need to bash/cut the pinch weld and the plastics near there. Regardless of lift you would need to do that if you wheel.
    04yota[QUOTED] likes this.
  17. Oct 31, 2016 at 9:15 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
  18. Oct 31, 2016 at 9:18 AM
    fatfurious2
    David
    Ashburn, VA
    Yes off. Try it out! Rears wont budge.
  19. Oct 31, 2016 at 9:31 AM
    04yota
    Angelo
    Central New Jersey
    Thanks bro.
  20. Oct 31, 2016 at 10:08 AM
    Subway4X4
    Lloyd
    NY/NJ
    Feeler:
    Just replaced my rear suspension with Dakars, SuperBumps and Bilstein B110's.
    Up for grabs is my relatively new suspension.
    1 year old Toyota Factory leaf springs (new from the frame replacement campaign that was done a year ago)
    7 month old HeadStrong three leaf AAL's
    7 month old rear Bilstein 5100's
    Extended length u-bolts to fit the AAL's
    In about a month, after I install my Bruteforce front and rear bumpers, I'll have a Mobtown recovery bar available as well.
    Also thinking about selling off my Archive Shackle Flip kit. NIB.
    I refuse to ship. I haven't figured out pricing yet.
    Local pickup, or meet at RC is ideal.
    Other pics to follow.
    Tatts521 likes this.
