NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Sep 3, 2013 at 6:34 AM
    #3961
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Soo I have to buy a new tent any suggestions. Just looking for a 2-3 person dome.
  2. Sep 3, 2013 at 6:40 AM
    #3962
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    yeah it was a good deal even if it only last me 2-3 camping trips…. plus i got damage protection for $3.99…. so i got a good deal….. all my tents have been hand me down from my brother…. but they have been EMS, Sierra Designs etc…. so I've had decent tents for free :)
  3. Sep 3, 2013 at 6:47 AM
    #3963
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Scott check it out!
    its the
    "Field & Stream" Field Lodge 3
    model CEH00890 7x6 Dome Tent with 3ft Vestibule
  4. Sep 3, 2013 at 6:48 AM
    #3964
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
  5. Sep 3, 2013 at 6:50 AM
    #3965
    cynicalrider
    cynicalrider #NFG
    Jersey
    2nd gen problems.
  6. Sep 3, 2013 at 6:50 AM
    #3966
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
  7. Sep 3, 2013 at 7:09 AM
    #3967
    cynicalrider
    cynicalrider #NFG
    Jersey
    Nice! My work was a lot more mild mannered. Just did some cutting/grinding with the dremel so I could flip my light brackets and install stock skids. My lights look really nice centered in the grill now though. Went from this:
    1E2752C6-50C0-46E9-8C58-2FE92AAC927C-711_b4214c6c496cabf059284db9d42d192c26ac85e1.jpg
    To this:
  8. Sep 3, 2013 at 9:48 AM
    #3968
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    Coleman hooligan4
  9. Sep 3, 2013 at 10:06 AM
    #3969
    jrzyshore
    Scott
    SNJ
    Thanks I will check it out.
    I do like the Coleman's I found a few on Amizon that are reasonably priced.
  10. Sep 3, 2013 at 10:30 AM
    #3970
    cynicalrider
    cynicalrider #NFG
    Jersey
    Thank you sir. What were you guys doing? New UCA's? Or fixing boots?
  11. Sep 3, 2013 at 10:45 AM
    #3971
    kjf216
    kjf216 Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    i have had field and stream and coleman. field and stream aren't bad for a cheap tent but i would get a coleman (my current setup is a 4 or 6 man coleman instant tent)
  12. Sep 3, 2013 at 10:45 AM
    #3972
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    ...both diff seals, spindle gussets, cut the fenders/bumper, rebuilt UCA's, icon c/o's, removed and greased drivers LCA... found out both pass are seized, pinch weld and firewall beating.
    Props to you for sticking with those fubar coil gussets :eek:
  13. Sep 3, 2013 at 10:47 AM
    #3973
    cynicalrider
    cynicalrider #NFG
    Jersey
    Nice. I have a buddy do all my welding I have needed for my bike so far since I haven't touched a welder since 10th grade. I can't wait to get and install my lift since it will be my first real suspension work I've done. I have always been intimidated by big projects on my DD but I feel confident enough that I could do most part change outs relatively easily.
  14. Sep 3, 2013 at 10:52 AM
    #3974
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    Installed my scan gauge this morning, dam code for trans temp ain't working -__-
  15. Sep 3, 2013 at 11:12 AM
    #3975
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Tacoma problems! :D
  16. Sep 3, 2013 at 12:41 PM
    #3976
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I got really lucky that the ones that were snapped for my skid were relatively easily accessible to get at with a dremel/angle grinder. I put anti seize on all of the new ones and got two stainless steel ones for the ones that go into the frame that I would never be able to get at.
    Speaking of welding etc. do any of you have a tube bender and a welder and can help me with a little exhaust project of mine? It's not a truck exhaust it's for my pit bike.
  17. Sep 3, 2013 at 1:34 PM
    #3977
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    Well I cleared the maintence required light nd im still waiting for my buddy to take my truck to his buddies 4x4 shop this light is killing me slowly inside...
  18. Sep 3, 2013 at 2:19 PM
    #3978
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Make sure you check those wires. Good chance that's what it is
  19. Sep 3, 2013 at 4:57 PM
    #3979
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    whats up buddy? howve you been?
  20. Sep 3, 2013 at 4:59 PM
    #3980
    aw10tacoma
    Andrew
    Northern New Jersey
    2011 AC Mgm
    I called all my friends I could think that would have a scanner but they only had one for engine codes so I think tomorrow I might go to toyots after work and have them read it nd pay whatever the fee is
