NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Dec 12, 2016 at 8:01 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Still has spiders cept has 4 instead of two. And the carrier is stronger. The "locker" is on the ring gear side of the carrier and works just like a locking hub assembly.
  2. Dec 12, 2016 at 8:03 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    :smack::p:D:cheers::santa::jellydance::kona::broccoli::bananadance::hattip::bucket::alien::canada::bikewhoops:
    JLink[OP] likes this.
  3. Dec 12, 2016 at 8:36 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Steve laying down the knowledge.
  4. Dec 12, 2016 at 8:37 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    It is a catch 22. The carrier assembly is stronger with an ARB. But being locked up front can cause you to grenade CVs. But common sense and light use of the skinny pedal can prevent that.
    The Hunter likes this.
  5. Dec 12, 2016 at 8:37 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Steve knows his shit.
  6. Dec 12, 2016 at 8:38 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Also the lower the gear set (numerically higher) the weaker the pinion gear. Less teeth means less strength.
  7. Dec 12, 2016 at 8:43 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Light use of skinny pedal is something I need to get better with. I used to be real good till takeover. And I rather grenade a CV than the diff again. At least that I can carry spares for. I think the 5.29's will slow me down enough though. Gonna def take it easier now that I blew some shit up.
    stairgod[QUOTED] likes this.
  8. Dec 12, 2016 at 8:47 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    The pain of grenading shit will temper your actions. As will age and experience. Until you get too old and then just don't give a fuck anymore! :)
  9. Dec 12, 2016 at 8:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ha I lost all my fucks long ago. I just don't want to break anything before Moab once I'm buttoned up again. Then I can go back to going full retard.
  10. Dec 12, 2016 at 8:50 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  11. Dec 12, 2016 at 8:51 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Never mind. Got that backwards...
    stairgod likes this.
  12. Dec 12, 2016 at 9:21 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I helped Mike replace his add on his first gen, didn't remove diff tho, but did drop the diff a bit to get more room. But front diff is pretty straight forward, similar to third member. Remove axles and mounting hardware and wrestle it out.
  13. Dec 12, 2016 at 9:26 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @stairgod what have you used to clean the TRD air filter? Is it worth getting the Toyota cleaning kit?
  14. Dec 12, 2016 at 9:46 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    72k on mine and have not even cleaned it yet. But I will use the Toyota cleaning kit when I do it
    fatfurious2[QUOTED] likes this.
  15. Dec 12, 2016 at 9:54 AM
    fatfurious2
    David
    Ashburn, VA
    Im at Toyota now. The TRD kit is $47. They told me the K&N will work the same
  16. Dec 12, 2016 at 10:56 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I knew he had something between his ears.
  17. Dec 12, 2016 at 10:56 AM
    Subway4X4
    Lloyd
    NY/NJ
    Same exact kit
  18. Dec 12, 2016 at 11:14 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    J00 need crawl box mang
  19. Dec 12, 2016 at 11:24 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Good to know. Sound like the TRD filter may actually be made by K & N?
  20. Dec 12, 2016 at 11:26 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Eventually will probably happen. But for now being overgeared will be enough. Love the extra challenge of the manual. That is until it keeps me from getting onto even harder trails. So far it hasn't been the limiting factor though.
