NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 3, 2017 at 7:47 PM
    Lilcarkid
    Lilcarkid Well-Known Member
    casey
    Ny/nj
    11 dcsb sport
    2 inch front and rear. 32" stt pro's 30.5 inch bumper led light bar Volant cai
    I might be buying a bigger trailer this week or next tho. Brothers deciding on a 4x4 quad now instead of a sport quad. Used to just put his front tires on my tool box in the bed
    With the 3 feet of bed I have from having a box in there
  2. Jan 3, 2017 at 8:19 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    @cynicalrider considering 2 kits. Either power stop kit from summitracing or Napa calipers with ebc rotors and pads
  3. Jan 4, 2017 at 5:23 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    hmmm....
    I might take you up on this.
    Let me think this through.
    fatfurious2 likes this.
  4. Jan 4, 2017 at 5:41 AM
    Subway4X4
    Lloyd
    NY/NJ
    @Lilcarkid - Can I borrow for this Saturday morning?
    Lilcarkid[QUOTED] likes this.
  5. Jan 4, 2017 at 6:07 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  6. Jan 4, 2017 at 6:14 AM
    04yota
    Angelo
    Central New Jersey
    Summit racing beats Amazon with the power stop kit. Cheapest I found with the $80 core refund. With the ebc brakes it's definitely expensive, but I'm sure it will make a difference. The key is to find brake pads that when pressed the entire surface is on the rotors. So far I found the toyota oem and the ebc with this characteristics.
    https://m.summitracing.com/parts/pwr-kc2324
  7. Jan 4, 2017 at 6:16 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I will need brakes in the spring. I was just going to replace with the same as what the OP put. But I figured out they used EBC Yellowstuff towing brakes and Drilled and slotted rotors. Over $300 for the front!
    ChadsPride and 04yota[QUOTED] like this.
  8. Jan 4, 2017 at 6:34 AM
    04yota
    Angelo
    Central New Jersey
    Yea they are pricey, but us 1st gen owners need it. Specially with bigger tires. I think the 2nd gens have stronger brakes.
  9. Jan 4, 2017 at 6:57 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not bad but where are you going to get tundy cores? Can't send them your taco cores. :p
    It's different for second gen's than what we are discussing. We literally put Tundra calipers and rotors on our 1st gen tacomas.
    fatfurious2[QUOTED] likes this.
  10. Jan 4, 2017 at 7:02 AM
    Lilcarkid
    casey
    Ny/nj
    11 dcsb sport
    Yea of course.
    It's 4x8 if you were wondering 4 tie down points on each side. Little custom jobber, old jet ski trailer.
  11. Jan 4, 2017 at 7:05 AM
    Subway4X4
    Lloyd
    NY/NJ
    Nice. Thanks.
    You coming over to help?
    If not, how early can I pick up trailer on Saturday morning? Or Friday evening?
  12. Jan 4, 2017 at 7:18 AM
    Subway4X4
    Lloyd
    NY/NJ
    @HolyHandGrenade and others.
    What portable heater do you guys recommend I get for my garage? I'm tired of working in the cold.
    I have a parabolic reflector heater, but it just doesn't cut it.
  13. Jan 4, 2017 at 7:28 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I have a "torpedo" heater and run it off 100# tanks. I can give you the datails on it later.
    Blackout14 likes this.
  14. Jan 4, 2017 at 7:54 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    That's an expensive setup. I just went with Wagner OEX pads and Centric solid rotors. Best setup I've had. I had EBC on my xterra. I saw no real benefit other than looks.
  15. Jan 4, 2017 at 7:56 AM
    fatfurious2
    David
    Ashburn, VA
    I didnt do it, but I dont think Im going to replace it with the same. I dont do any towing currently, so looking into other options. I like using www.r1concepts.com
  16. Jan 4, 2017 at 7:57 AM
    Subway4X4
    Lloyd
    NY/NJ
    That'd be perfect. Enough room to keep the two bumpers separate, so not a lot of protective wrapping required.
    And low to the ground too. Bringing those heavy bumpers down from a lifted bedside was going to be painful.
    Thanks again.
  17. Jan 4, 2017 at 9:25 AM
    04yota
    Angelo
    Central New Jersey
    If you are sneaky about it, maybe you could get away with it in napa. :D
  18. Jan 4, 2017 at 9:29 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
  19. Jan 4, 2017 at 10:07 AM
    Subway4X4
    Lloyd
    NY/NJ
  20. Jan 4, 2017 at 11:45 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Tim if you ever go this route I still know a guy that will buy your current wheels and tires :spy::D
