NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 9, 2017 at 8:01 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    stairgod[QUOTED] likes this.
  2. Jan 9, 2017 at 8:05 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I don't think spring rate will be affected
  3. Jan 9, 2017 at 8:08 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    So I sound likr I know what I am talking about?
    Tatts521 likes this.
  4. Jan 9, 2017 at 8:13 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Aren't you heading to Colorado soon
    fatfurious2 likes this.
  5. Jan 9, 2017 at 8:22 PM
    Tatts521
    How do I add links
  6. Jan 9, 2017 at 8:29 PM
    Subway4X4
    Lloyd
    NY/NJ
    Copy the URL.
    Highlight the word or phrase.
    Click on the chain "link" icon on the menu (to the right of the Font selection menu)
    Paste the URL
    Hit Insert
  7. Jan 9, 2017 at 9:59 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Bumper is looking nice :thumbsup:
    But please I'll that remaining light spot. It's...bothering me.
  8. Jan 10, 2017 at 2:46 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I think Garett is planning to do the smart thing and do it at my place. You know? Instead of carting an engine hoist around... :boink:
    stairgod likes this.
  9. Jan 10, 2017 at 2:51 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Shouldn't you be figuring out the frame plates and tubular crossmember instead? ;)
  10. Jan 10, 2017 at 2:53 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Not just yet
  11. Jan 10, 2017 at 3:17 AM
    Manual man74
    Manual man74 Well-Known Member
    Garrett
    Goshen NY
    2015 trd off road dcsb mt
    Just getting started
    Yup. And I just got word it shipped. So once it's powder coated I'll give you a shout.
  12. Jan 10, 2017 at 4:29 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I think you're right. The shackle is there because eye to eye length has to change as the leaf compresses.
    One thought on "inverted shackles are stronger": that may not be a reference to the weight bearing capability of the suspension, that may be a reference to the shackle itself. Inverted the shackle is primarily under a tension load, and that will be stronger, and have a more graceful failure than one that's been 'flipped' and is now under a compression load. In almost all cases tension will be better than compression because there is no chance of buckling or bending.
  13. Jan 10, 2017 at 4:54 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  14. Jan 10, 2017 at 5:56 AM
    Subway4X4
    Lloyd
    NY/NJ
    Jon- I'd like to try to retain my ability to carry my spare in the stock location. Can we cut-off the crossmember, weld on the 1 piece frame plates and then re-weld the crossmember?
  15. Jan 10, 2017 at 6:01 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @Subway4X4 do you have pictures of your dual battery setup?
  16. Jan 10, 2017 at 6:23 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    If your going so far to plate the frame it wouldn't be that hard to fab up a new cross member while your in there as well
    Subway4X4[QUOTED] likes this.
  17. Jan 10, 2017 at 6:25 AM
    fatfurious2
    David
    Ashburn, VA
    I thought you got a swingout with adjustable height spare... or are you running dual spares, with all those wheels that you have?
  18. Jan 10, 2017 at 6:45 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Looks good.:thumbsup:
  19. Jan 10, 2017 at 7:02 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Are you guys c channel from the front spring hanger back like me? Typically first gens have two options, box the frame or frame plates.
  20. Jan 10, 2017 at 7:13 AM
    Subway4X4
    Lloyd
    NY/NJ
    There's a link in the OP of my build thread
    fatfurious2[QUOTED] likes this.
