NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 10, 2017 at 7:14 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Two spares. Especially when I go solo.
    fatfurious2[QUOTED] likes this.
  2. Jan 10, 2017 at 7:14 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    except your build is not in your signature
    I just noticed, I made it into your signature! woo!
  3. Jan 10, 2017 at 7:15 AM
    fatfurious2
    David
    Ashburn, VA
    should have done it this way
  4. Jan 10, 2017 at 7:17 AM
    Subway4X4
    Lloyd
    NY/NJ
    And it will be much stronger.
  5. Jan 10, 2017 at 7:18 AM
    fatfurious2
    David
    Ashburn, VA
    EDIT: I found the build. But I cant copy your dual battery setup. My air compressor is in that location. Thanks Lloyd!
  6. Jan 10, 2017 at 7:21 AM
    Subway4X4
    Lloyd
    NY/NJ
    I agree with @HolyHandGrenade - you need to stop the mad experiments, and get some real stuff done.
    Can you or @Sub-Zero fab up a crossmember that still allows me to hang my spare?
    HolyHandGrenade likes this.
  7. Jan 10, 2017 at 7:22 AM
    Subway4X4
    Lloyd
    NY/NJ
    Exactly why I can't install an air compressor in my engine bay
  8. Jan 10, 2017 at 7:24 AM
    fatfurious2
    David
    Ashburn, VA
    you can probably mount the small ARB one.. but theres no sense in having that giant one that you have, and a small one
  9. Jan 10, 2017 at 7:42 AM
    Subway4X4
    Lloyd
    NY/NJ
    I was thinking maybe I should move my aux battery to the compartment behind the rear seat and install the Dual ARB into the vacated space in the engine bay.
    Too much work...
  10. Jan 10, 2017 at 7:46 AM
    fatfurious2
    David
    Ashburn, VA
    thats alot of work.. we are lazy
  11. Jan 10, 2017 at 7:58 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    @2stroketrush plans to link it to the sliders eventually, but did something similar.
    @Mobtown Offroad did the fab IIRC
    Took J5 out to work today.
  12. Jan 10, 2017 at 8:03 AM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    two thumbs up for the NJDB discount :thumbsup: :thumbsup:
  13. Jan 10, 2017 at 8:10 AM
    Subway4X4
    Lloyd
    NY/NJ
    I should be getting a spare or two from you, considering all the crap that we wheel through. It's gonna happen sooner or later. Better to be prepared.
    Or else it will be a late Sunday night, hunting for a replacement wheel bearing. @Sub-Zero :boink:
    I have two of my original wheel bearings in my shed. You take these as cores?
  14. Jan 10, 2017 at 8:24 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    We could. Or we can fab a new xmember and then fit the spare lifting mechanism to it. Maybe do 2x3 tuving laying flat to save some space. I was going to do mine vertical, but am rethinking it.
  15. Jan 10, 2017 at 8:25 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    We get a NJDB discount???
    nj636[QUOTED] likes this.
  16. Jan 10, 2017 at 8:28 AM
    Subway4X4
    Lloyd
    NY/NJ
    How about beefing up/gusseting the front spindles and LCA?
    I've been looking into all of this. Most of this seems to be a West Coast fabricator thing.
    Other things on my list: Weld on my rear frame plates, replace rear crossmember with better/stronger.
  17. Jan 10, 2017 at 8:29 AM
    Subway4X4
    Lloyd
    NY/NJ
    In!
    So I'm gonna finalize my frame plate order to 1 piece, solid. Right?
  18. Jan 10, 2017 at 8:30 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    LCA gussets? See no reason to do that. Coil tower gussets yes.
    I need a set of donor spindles. That way I can weld gussets on them, then swap mine. Then weld gussets and saap yours. Then weld gussets and swap Tims. Then Ryans, etc etc
    Sub-Zero and HolyHandGrenade like this.
  19. Jan 10, 2017 at 8:31 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Do it!
  20. Jan 10, 2017 at 8:31 AM
    Subway4X4
    Lloyd
    NY/NJ
    No to LCA gussets. Yes to spindle gussets. I'll link you to some nice ones hat I've seen on TW.
