NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 11, 2017 at 4:31 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Dont forget Shotgun Tim.
  2. Jan 11, 2017 at 4:40 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    And Matt
  3. Jan 11, 2017 at 4:41 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Dibs if it fits
  4. Jan 11, 2017 at 4:57 AM
    conifers4
    conifers4 Tired and Broke
    Brian
    Long Island, NY
    2010 DCLB 4X4
    :wave:
    Long Islander in the New Jersey thread now...
  5. Jan 11, 2017 at 4:59 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Which is why I like to regularly inspect and maintain stuff. With steel cable is easy to visually spot any weak point along the entire line. With good care and careful use, you shouldn't see rust for MANY years and its an easy and much cheaper replacement cost. I believe about 1/5 the cost of synthetic. Steel winch cable has been used for over 70 years and is still in active use today.
    With synthetic, not so easy to inspect. Dirt and grit have a tendency to work its way into the fibers and into the core of the line. Much more closer visual inspection is required to determine compromised fibers. Also more susceptible to UV deterioration, chemicals, heat and abrasion, which is especially prevalent in our type of wheeling here in RC. Also, the synthetic line can hold water. In the winter, that equals ice.
    Safety of course is always a primary concern for both steel and synthetic lines. Make sure you take all necessary measures to protect the operator and those people in the immediate area.
    The reason I'm replacing this steel cable winch with a synthetic model is that it goes into my portable winch cradle, because I poached my cradle winch w/ synthetic line and installed it into my bumper. That steel cable + winch is HEAVY!
  6. Jan 11, 2017 at 5:02 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    True. And the ability to pull yourself out backwards is nice. Would love to permane t mount a rear winch. Might be fun figuring out hiw to fit that and a hidden receiver in a HC bumper.
  7. Jan 11, 2017 at 5:03 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Ahoy:cheers:
  8. Jan 11, 2017 at 5:05 AM
    Subway4X4
    Lloyd
    NY/NJ
    With BFF Rear HC bumper, I don't see a way to fab a permanent winch mount and keep the hidden receiver. Unless you lose some of that high clearance that I paid for.
  9. Jan 11, 2017 at 5:05 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Not yet, tonight I will
  10. Jan 11, 2017 at 5:08 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    GET THE :censored: OUT! :mad:
    conifers4[QUOTED] likes this.
  11. Jan 11, 2017 at 5:11 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    :bored:
    Subway4X4[QUOTED] likes this.
  12. Jan 11, 2017 at 5:28 AM
    Subway4X4
    Lloyd
    NY/NJ
    Slacker
  13. Jan 11, 2017 at 5:36 AM
    Subway4X4
    Lloyd
    NY/NJ
    I thought you might want it Ryan.
    It should fit. It has the standard winch base bolt pattern.
    You have first dibs.
    And you get the Subway$x$ special promo:
    1. If I know you and I've wheeled with you, then you can use my reverse layaway plan: Pay for half, take the item. Pay the other half within 6 weeks.
    2. If you've rescued me, recovered me (winch, snatch, tow, stacked rocks, hi-lifted) you can take the reverse layaway plan above AND an additional 5% off my prices.
    3. If you've screwed me like @maholacunto, you can send me $335 and I'll give you... nothing.
    04yota and Lilcarkid like this.
  14. Jan 11, 2017 at 5:38 AM
    Subway4X4
    Lloyd
    NY/NJ
    Updated list:
    Jon
    Lloyd
    Others.
  15. Jan 11, 2017 at 5:38 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Don't forget this day while giving @Sub-Zero a deal... :boink:
  16. Jan 11, 2017 at 5:39 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    This is why no one likes you Lloyd. One reason anyway.
    Manual man74 likes this.
  17. Jan 11, 2017 at 5:39 AM
    Subway4X4
    Lloyd
    NY/NJ
    Or the ability to pull the winchless vehicle behind you is nice as well.
    stairgod[QUOTED] likes this.
  18. Jan 11, 2017 at 5:42 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Leave @stairgod out of this! :rolleyes:
  19. Jan 11, 2017 at 5:49 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I has winch
    Now anyway
  20. Jan 11, 2017 at 5:50 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    This isn't the only instance haha. Just a few minutes after this Remember Lloyd climbing out his window. I was crying I was laughing so hard
    stairgod likes this.
