NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 12, 2017 at 9:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah Toyota is weird about trim models as well as what is standard and what isn't. Like I am an 01 V6 Manual TRD SR5 4x4 while you are an 01 2.7 Manual SR5 4x4 so not sure if I have it because it was an option, or the TRD trim, or engine size.
  2. Jan 12, 2017 at 10:58 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    okay I'll let you know when i head that way. Text me your address
  3. Jan 12, 2017 at 11:07 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I run his relocate kit and love it. My wheels were 4" backspace so I jave to run a spacer to keep from hitting the shock at full bump.
    Blackout14 likes this.
  4. Jan 12, 2017 at 11:10 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    @stairgod trying to get a simple analysis going. What do you want me to look for exactly?
  5. Jan 12, 2017 at 11:21 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Me too @stairgod
    MY50cal and HolyHandGrenade like this.
  6. Jan 12, 2017 at 11:22 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Nice Tissues.....kinda take away from your sig.....Sub-zero uses angle soft cause his nose is delicate....:boink:
  7. Jan 12, 2017 at 11:22 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    anyone got any tips for getting a lower ball joint out? Ive got a jack under it and I'm pounding on the side but the thing won't give up
  8. Jan 12, 2017 at 11:26 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Might be too late if you don't have another car, but I don't fuck around with ball joints or tie rods without a pitman arm puller anymore. They sell at Vatozone or advance in two sizes, I believe I use the bigger one. Can get both for $30 total.
  9. Jan 12, 2017 at 11:27 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Those tissues suck lol I need much softer tissues than those but my company is cheap af
  10. Jan 12, 2017 at 11:29 AM
    Subway4X4
    Lloyd
    NY/NJ
    @Lux -Maybe rent/borrow at autozone or advance?
  11. Jan 12, 2017 at 11:45 AM
    Lilcarkid
    Lilcarkid Well-Known Member
    casey
    Ny/nj
    11 dcsb sport
    2 inch front and rear. 32" stt pro's 30.5 inch bumper led light bar Volant cai
    What shocks are you running? And with what lift in the rear if you don't mind me asking.
  12. Jan 12, 2017 at 12:56 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    So looking at the brochures online, ABS was apparently made standard in 2003 and was an available option before that (so for your 2001s), but was not part of any package. It was simply an available add-on feature.
    Lux[QUOTED] likes this.
  13. Jan 12, 2017 at 12:57 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    A dumb add on at that. Fucking hated ABS on this truck.
  14. Jan 12, 2017 at 1:00 PM
    sente3
    sente3 -
    North Jersey
    Before I replaced my front brakes, it would engage if I were braking over a rough spot in the road. I guess it was due to me needing to press the brakes at least halfway down to really do anything and that got the ABS system all panicky, so it engaged over nothing. IDK, it was stupid. Since I replaced my pads, rotors, calipers, and fluid, it hasn't engaged once. And since swapping the CVs, it can't engage :p
  15. Jan 12, 2017 at 1:18 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Pitman or ball joint tool under modest compression, torch until grease tries to flash ignite, whack the side of the housing repeatedly until it pops.
    Also, make sure to drive out the retaining ring before you start.
  16. Jan 12, 2017 at 1:21 PM
    sente3
    sente3 -
    North Jersey
    If you're not entirely against ABS, try fully servicing the front if you haven't done so in recent times. It effectively disabled mine. But if you'd rather just not have it all, then go ahead and disable it. I'm not a huge fan of ABS anyway. I see its purpose, but it doesn't always help and on some vehicles it's much worse than others.
  17. Jan 12, 2017 at 1:24 PM
    sente3
    sente3 -
    North Jersey
    Fuckin' a. What I would give to be able to say the same. Mine isn't super high (178K) but it's still significantly higher than that. That's brand new.
  18. Jan 12, 2017 at 1:24 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    @stairgod @Arcticelf I'm actually beginning to think the flip does change the spring rate based on the geometry of the shackle and the way it gets loaded. In stock shackles, the leaf has to fight the weight of the vehicle to expand and rotate the shackle past a certain point (roughly 45°). In a flipped shackle, there are much larger stresses in the shackle itself, but the leaves don't fight the weight of the truck to expand and rotate the shackle. This leads me to believe the stock hangar provides a stiffer spring rate and the shackle flip will allow for a softer spring rate based on the ease of expansion and rotation of the shackle....opinions?
    Subway4X4 and Blackout14 like this.
  19. Jan 12, 2017 at 1:30 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I wish I needed tires. I got brand new duratracs before I found out about it..I should have it tomorrow.
  20. Jan 12, 2017 at 1:30 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    I got it with a ball joint fork from auto zone, took a lot of decent whacks, thing was really on there.
    New problem: torque specs? Im seeing 37 ft/lb in this video for the 4 connecting the joint to the knuckle but not seeing it elsewhere, can anyone confirm?
