NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 12, 2017 at 7:59 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yeah, 27" is definitely more than 3" longer than stock.
    No problem Lloyd :thumbsup:
    I need a link to those fancy vice grips you brought. I'm going to own a set of those.
    Blackout14 likes this.
  2. Jan 12, 2017 at 8:00 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
  3. Jan 12, 2017 at 8:03 PM
    Subway4X4
    Lloyd
    NY/NJ
    I did the much longer 27" brake lines because I was planning on the Dakars with the 29XL AAL's AND shackle flip at the time.
  4. Jan 12, 2017 at 8:08 PM
    Subway4X4
    Lloyd
    NY/NJ
  5. Jan 13, 2017 at 1:47 AM
    Manual man74
    Manual man74 Well-Known Member
    Garrett
    Goshen NY
    2015 trd off road dcsb mt
    Just getting started
    :censored:
    Subway4X4[QUOTED] and stairgod like this.
  6. Jan 13, 2017 at 2:37 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    What?
  7. Jan 13, 2017 at 3:51 AM
    Manual man74
    Garrett
    Goshen NY
    That was for Lloyd for being a typical smart ass
  8. Jan 13, 2017 at 4:18 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    And any placement so that the shackle isn't perpendicular to the ground is going to preload the spring.
    In further conversation with Physicist Wife, she doesn't see any way the effective spring rate of the suspension setup can be the same between stock and flipped shackles.
    She also opines we should just listen to her in the first place. :)
  9. Jan 13, 2017 at 4:35 AM
    Subway4X4
    Lloyd
    NY/NJ
    That's interesting (your wife opinion, not the spring rate math.)
    In a recent conversation with my Microbiologist Wife, she believes that any work performed on a Tacoma Truck should be done with great care, with minimal damage to body parts, to prevent great possibility of infection and therefore loss of affected body parts. Or performed by someone else.
    Her opinion is similar as well: I should just listen to her in the first and LAST place. :)
    Arcticelf[QUOTED] and stairgod like this.
  10. Jan 13, 2017 at 4:38 AM
    Subway4X4
    Lloyd
    NY/NJ
    Who? What?
  11. Jan 13, 2017 at 5:01 AM
    Subway4X4
    Lloyd
    NY/NJ
    Can you guys help me find the LCA Cam Bolts? I can't seem to find them on the Wheeler's website.
    Thanks,
  12. Jan 13, 2017 at 5:05 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Toyota...
  13. Jan 13, 2017 at 5:06 AM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Ouch!! That one def had to hurt. Well worth it tho right? How are the breaks with the new line?? Any different with the steel line vs the regular one?
  14. Jan 13, 2017 at 6:22 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Best bet with anything lca bushing/cam/bolt related it's best to stick with factory
    planters15, Subway4X4 and Blackout14 like this.
  15. Jan 13, 2017 at 6:29 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Is it because of your diminutive stature that you require a micro biologist for medical supervision? :boink:
    If that's the case, I need to find a macro biologist.
  16. Jan 13, 2017 at 6:34 AM
    Subway4X4
    Lloyd
    NY/NJ
    Next weekend, I'll be changing out my front suspension: Bilstein B6112's, Eibach 700#, SPC Light Racing UCA's and Super-bumps.
    I also feel the need to refresh some of the 12 year old hardware and "soft" ware, such as UCA Pivot Bolt, coil spring rubber isolator, shock stem washers/rubber rubber cushions.
    Is there anything else I need to replace?
    TC weld-on Cam Tabs and TC Spindle Gussets, LCA refurbish (replace bushings and joint) are planned for a later date.
    Thanks guys
    Lilcarkid likes this.
  17. Jan 13, 2017 at 6:34 AM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    If I can meet with Jerry @loosnut today, and he can meet with @stairgod or @Sub-Zero sat, the spindle gusset party will begin soon!
    Tatts521 likes this.
  18. Jan 13, 2017 at 6:36 AM
    Subway4X4
    Lloyd
    NY/NJ
    Ok. I'll stay with the factory stuff.
  19. Jan 13, 2017 at 6:38 AM
    Subway4X4
    Lloyd
    NY/NJ
    You need a chiropractor. You need to quit doing shit under your truck that causes you great neck pains. You already have off-camber for that.
  20. Jan 13, 2017 at 6:39 AM
    Subway4X4
    Lloyd
    NY/NJ
    Nice!
