NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 25, 2017 at 12:49 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Ryan @Sub-Zero can you text me the address? I'm gonna try to make this work
    Sub-Zero likes this.
  2. Jan 25, 2017 at 12:53 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    If by some small chance you see @HolyHandGrenade before you come down could you bring my hi lift? :)
    Subway4X4[QUOTED] likes this.
  3. Jan 25, 2017 at 12:54 PM
    Subway4X4
    Lloyd
    NY/NJ
    Will try
    Blackout14 likes this.
  4. Jan 25, 2017 at 12:55 PM
    Subway4X4
    Lloyd
    NY/NJ
    Gonna get me a pair of money trees...
  5. Jan 25, 2017 at 12:55 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I'll grab it
    Subway4X4 and Blackout14 like this.
  6. Jan 25, 2017 at 12:56 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Awesome, thanks Ryan...
  7. Jan 25, 2017 at 1:17 PM
    Subway4X4
    Lloyd
    NY/NJ
    Costco has a sale on 3 Amp Battery Tender. It's a great deal.
    All charging modes, lead acid/AGM/Gel batteries, 12 and 6 volt.
  8. Jan 25, 2017 at 1:20 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Did the pinch weld mod and got some new eBay lights lol. Also attempted to figure this oil leak out but can't pin point the source, it's dripping a lot of oil, any ideas? Do these pics look normal? I see some seeping from the oil pan where it mates to the block but it's not major, must be on the bottom near the drain somewhere
    (I cleaned it off in the pics)
    This just started happening recently
    04yota likes this.
  9. Jan 25, 2017 at 1:53 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Ouch. Seems as the oil pan gasket. Did u bang the pinch weld or cut it? Any pics? Gonna try to do this on the weekend if I'm able to get some jackstands.
  10. Jan 25, 2017 at 2:19 PM
    Subway4X4
    Lloyd
    NY/NJ
    Anyone know the center pin diameter for the Dakar Leafs? I'm guessing 3/8"
    Please confirm.
  11. Jan 25, 2017 at 2:25 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    I cut a bunch more plastic and then saw It was mostly bent already so I just beat it in more, there was a thicker part that I wanted to also bend in but it wouldn't budge much. Then I just doused it in like 20 coats of paint. 90% sure it'll still rub when it's tucked but I'll just have to dick around with it more when I figure out where.
    It's not very clean lol
    04yota[QUOTED] likes this.
  12. Jan 25, 2017 at 2:25 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's not good - you've got a bad pan seal there. :(
    Lux[QUOTED] likes this.
  13. Jan 25, 2017 at 2:31 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    The leak coming out of the seal there in the one pic isn't reaching the bottom of the pan, is there 2 seperate pieces of the pan? And the lower portion is leaking? How difficult is it to fix? this is a new motor I just put in like 2 years ago and I've still got the old one so I could just swap pans if it's as easy as that. Not sure why this would suddenly happen though, was fine a week ago
  14. Jan 25, 2017 at 2:36 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Took a couple of pics for you today if it helps. Tires are 265/70s'. It's parked on a little bit of a slope, there's more rake than the pics show.
    @04yota I have a pair of stands you can borrow. You know where the house is, let me know.
    04yota[QUOTED] and Lux[QUOTED] like this.
  15. Jan 25, 2017 at 3:08 PM
    JJ TACO
    JJ TACO Well-Known Member
    16 TRD OR DCSB MT QUICKSAND
    Nice truck!
    Tatts521[QUOTED] likes this.
  16. Jan 25, 2017 at 3:53 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    What length should I get for the 3 leaf AAL? And how do I know which spacer I'm going to need?
  17. Jan 25, 2017 at 3:55 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    the 3 leaf should come with them, unless you're replacing them or something?
  18. Jan 25, 2017 at 3:56 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Used from @Subway4X4 . He suggested I get the u bolt flip. Which I'm not even sure if that's what I'm looking at here.
  19. Jan 25, 2017 at 3:57 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I'm a dumbass. I found the kit I need. Still not sure of the spacer though.
  20. Jan 25, 2017 at 3:58 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    you're flipping the U-bolts? And what spacer?
