NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Mar 25, 2017 at 8:58 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not sure since my original springs are kinda shot. Supposed to be an inch though.
  2. Mar 25, 2017 at 9:53 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    @RelentlessFab just ordered the bumper reinforcement brace. Nice and easy check out process :thumbsup:
    JJ TACO and RelentlessFab like this.
  3. Mar 26, 2017 at 7:49 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Depending on the design, that will end up heavy as hell. Better to go lighter with more internal bracing.
    Thin braces in the right spots will be much stronger than thick plate without braces
    Blackout14 and Tatts521[QUOTED] like this.
  4. Mar 26, 2017 at 7:53 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    What's up fuckers....
    Anyone has the TC UCA uniballs install/removal tool I can borrow?
    Blackout14 and The Hunter like this.
  5. Mar 26, 2017 at 7:59 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    :spy:
    V5ioV[QUOTED] likes this.
  6. Mar 26, 2017 at 9:08 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    :wave: no I don't but FUDB
    Blackout14 likes this.
  7. Mar 26, 2017 at 12:52 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Any downsides to using shackles to gain lift?
  8. Mar 26, 2017 at 12:59 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Had longer shackles on my Xterra. That was a given on that truck.
  9. Mar 26, 2017 at 1:00 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Longer shackles are not really a good idea unless absolutely needed for the springs, I.e. a high arch spring that will be set up for a good amount of wheel travel. A shackle two inches longer than stock will only yield one inch of lift, but is more likely to fail because of increased stress on it due to the longer length.
  10. Mar 26, 2017 at 1:02 PM
    sente3
    sente3 -
    North Jersey
    Hmm, I see. Alright, thanks.
    stairgod likes this.
  11. Mar 26, 2017 at 2:18 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Did you make a thread for inverted vs flipped yet? If so I musta missed it if not:popcorn:
    MTopp and The Hunter like this.
  12. Mar 26, 2017 at 3:35 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Nope. Been busy. But now I am thinking that I should have made a set of long shackles and tested them the same way I ran the other tests. :anonymous:
  13. Mar 26, 2017 at 3:45 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    I hear that. I am curious of the results so keep me in the loop
    Nimble9 and stairgod[QUOTED] like this.
  14. Mar 26, 2017 at 3:48 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I certainly will. Guess I will make extended shackles and rerun the test again. After I post the results of the first test of course.
    Wheelspinner[QUOTED] likes this.
  15. Mar 27, 2017 at 3:25 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    God I miss the neg rep button
  16. Mar 27, 2017 at 4:41 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    And you guys thought salt only melts frames. Look what happens when the aliens get a hold of the stuff
    kyuss88, MTopp, 04yota and 2 others like this.
  17. Mar 27, 2017 at 6:17 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Probably
  18. Mar 27, 2017 at 6:34 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    What is that?
  19. Mar 27, 2017 at 6:39 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    It's like very fine hair like crystals growing out of the salt residue on my work truck. It only happens once in a while probably dependent on weather conditions, temp, etc. also pm coming your way:spy:
  20. Mar 27, 2017 at 6:42 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Ah gotcha
