NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. May 1, 2017 at 9:40 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I'm bending the 4" inch side, which should be a little easier.
    What's a whiskey bend?
  2. May 1, 2017 at 9:46 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    So the entire thing is home made? Damn that's coming out great then.
    This. But usually it's then welded since you are weakening it with the cuts.
    Blackout14 and Subway4X4 like this.
  3. May 1, 2017 at 9:50 AM
    Subway4X4
    Lloyd
    NY/NJ
    Ok. I'll do the notch, the straight line cut and then bend it.
    Once I get it bent at the correct angle, I'll ask @Sub-Zero to run a bead along the bend/cut.
    Thanks guys!
    Blackout14 likes this.
  4. May 1, 2017 at 9:51 AM
    Subway4X4
    Lloyd
    NY/NJ
    Subway is horrible at welding... until he gets his ass into the local community college welding class :)
  5. May 1, 2017 at 9:55 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Thanks guys! Ordering now :goingcrazy: need to order a tire filler that isn't ARB so it doesn't cost $20 extra
  6. May 1, 2017 at 10:00 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Gonna do mcmaster carr. Friends dad works there and gets a decent discount
  7. May 1, 2017 at 10:37 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Autoanything matched that price that Steve posted... will ship by the 3rd and will take 3-5 business days... ill be hoping i have it friday! Thanks @Subway4X4 for the tip
  8. May 1, 2017 at 10:43 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Anyone here done the ARB diff breather? I want to see if the tube fits..
  9. May 1, 2017 at 10:45 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Just do the cheap diy diff breather and use the stock breather cap. Youre nucking futs if you do anything more because youre spending more than you have to
  10. May 1, 2017 at 10:47 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    ARB is a 2 way breather. The cheap way isn't..from what I gather. Plus, I was told this weekend that I need to have something on order at all times. So I gotta buy something.
  11. May 1, 2017 at 11:00 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    This I still haven't done
  12. May 1, 2017 at 11:21 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    That camry breather isn't a breather... its just a union... you reuse the breather... unless for
    Some reason there is a different breather mod now...
  13. May 1, 2017 at 11:30 AM
    evoviii1220
    evoviii1220 Well-Known Member
    Dan
    NJ
    05 4x4 DCSB
    Silver touch up paint
    When I did this I ordered the one from Toyota. The Camry one I believe. I thought that was always the way :notsure:
  14. May 1, 2017 at 11:31 AM
    evoviii1220
    Dan
    NJ
    05 4x4 DCSB
  15. May 1, 2017 at 11:33 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Just don't use the original breather either and leave it an open barb in a closed location. That's what I did.
  16. May 1, 2017 at 11:36 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    this is my understanding but I don't know for sure:
    Re using the stock one doesn't fix the problem.It's a one way valve so diff heats up, pressure goes out. Then it cools down and there is negative pressure inside. Air (or water) is then sucked in from the axle seals to equalize a pressure
  17. May 1, 2017 at 11:37 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Correct. That's what I read and it makes sense. So, $60 for ARB breather seemed to be a better solution.
  18. May 1, 2017 at 11:38 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Just a hose would work
  19. May 1, 2017 at 11:41 AM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    I get all my wire off eBay. I have magnetic based angle finders from harbor freight that have always worked great. Make sure your welder has a good ground clamp. I've heard Lincoln machines sold at Home Depot come with cheaper parts than normal Machines, idk what you have or got or where you got it from but that's something I've heard from body shops that we work with. I know a lot of guys have welded a small bolt to vice grips and then nutted down a eyelet end they have on the ground cable to the vice grips to get the best possible ground. And I never built a welding cart, just got a single drawer cart from harbor freight and put the welder on top of it, has a drawer for wire brushes and cutters and the misc stuff and is big enough to leave the helmet and gloves on the bottom of it. Works great for me
  20. May 1, 2017 at 11:45 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
