NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. May 13, 2017 at 7:28 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Hunter doesn't really know what your back looks like.
  2. May 13, 2017 at 7:54 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Yeah sure. Feel free to borrow it if you want. You'll need an app called Torque Pro. It's like $5. But it does the job well. Or just use it on my phone. Whatever you want.
    Alternatively, @HolyHandGrenade said he has that Scanguage II. IIRC, that reads O2 data as well.
  3. May 13, 2017 at 8:18 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Leave it by the front door just in case your not home.
    diabetiktaco[QUOTED] likes this.
  4. May 14, 2017 at 12:43 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    :stareswhilestandinginginthepouringrain:
    Lmao
    Blackout14 likes this.
  5. May 14, 2017 at 4:36 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Happy Mother's Day Wicked and OCK!!!
    stairgod and Blackout14 like this.
  6. May 14, 2017 at 4:57 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Was just a question. He was gonna go. While I had no idea who was under the truck I knew it wasn't Ant.
    Looks like you when you showed uo to Ant's garage that night LOL
  7. May 14, 2017 at 5:34 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Thanks for stopping by @HomerTaco and thanks for the grill! :D
    I'll get better pics of it when it's all back on all 4's.
    Didn't get a ton of pics. And a big fucking thank you to @Sub-Zero and @MY50cal for the help today. Def wouldn't be where I'm at without you guys!
    Still have a little to finish up, mostly just torquing everything to the new spindles.
    04yota, V5ioV, sente3 and 8 others like this.
  8. May 14, 2017 at 8:04 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Hardware deconstruction getting the drawer system ready for paint
    Nimble9, HolyHandGrenade, Lux and 3 others like this.
  9. May 14, 2017 at 8:13 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :eek:
  10. May 14, 2017 at 10:29 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
  11. May 14, 2017 at 10:44 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    When you design and build it, it is easier than IKEA furniture to put back together.
    Chux, The Hunter and Blackout14 like this.
  12. May 14, 2017 at 1:07 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I just thought it was funny that was the first thing you asked
    Nimble9 and The Hunter[QUOTED] like this.
  13. May 14, 2017 at 2:26 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Guys need some assistance. I hit a nasty pothole hard af on Friday. Now I've got a popping sound coming from what sounds like the front left. It almost sounds like if you were to hit a small puddle..the splash. My thoughts are the strut bearing plate may be sloshing around. You only hear it when hitting a sharp bump or when my truck nose dives coming to a stop. I can hear it backing out of my driveway too but doesn't seem to be any joint. Thoughts? Turning left or right doesn't seem to effect it.
    04yota likes this.
  14. May 14, 2017 at 2:48 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Try and tighten up the Camber toe adjustment bolts. Torque spec i think is like 125... might have jarred them loose. My clunking was from that. The LCA would move around a little. Made it go away when I tightened them up
  15. May 14, 2017 at 4:12 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I had two things making that noise: bad ball joints, which I found shaking the control arms at ride height (because at full droop they were locked up tight); the highlift in the bed hitting the wheel well, due to flex in the mount.
  16. May 14, 2017 at 4:36 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I've eliminated the hi lift by taking it out. I'll check then all joint next. That was also my thought because if I stand on the slider and rock the truck hard enough I can hear creaking.
  17. May 14, 2017 at 6:18 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Hey folks I have bed rail hilift mounts... forget what ones they are... got them from @HolyHandGrenade in a trade... idk what he paid for em but youll pay a whopping 40 bucks for em...
  18. May 14, 2017 at 6:20 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I'll take them!! Thanks @Blackout14
  19. May 15, 2017 at 4:08 AM
    Arcticelf
    Gladiator
    If you can make it happen on demand you need a second person to listen and track it down.
  20. May 15, 2017 at 1:54 PM
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    Just saw that desert tan color 3rd gen tacoma with blacked out center hood, bed rack with rotos on the side and grey cover RTT on top in Toms River.. Who dat?
