NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Aug 10, 2017 at 7:25 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    It don't matter what you do mike. If the end is under the fender the air filter will be hammered. My stock intake was roughly where you have it to now and I still had my plastic liners in and all the dirt roads on the way to, during, and after Moab rekt it. Just check it on occasion and bang it on the tire to knock some crud out. Or carry an extra one no big deal. The west is dusty and it gets in no matter what haha been dry since been dry since been dry
    The Hunter likes this.
  2. Aug 10, 2017 at 7:53 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Since I got back from rausch I've got this loud fucking screeching sound coming from the driver's side not sure if it's the leafs or front suspension it's driving me fucking insane
  3. Aug 10, 2017 at 7:58 PM
    Tatts521
    Only when I'm driving I tried rocking the truck back n fourth with no results. Guess I'm gonna try power wash everything again. And grease bushings
    Blackout14 likes this.
  4. Aug 10, 2017 at 7:58 PM
    Tatts521
    I'll check that also
  5. Aug 10, 2017 at 8:31 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    You might have banged up your metal dust shield and it's hitting the inside of the rotor. Or there's stuff caught between the rotor and that dust shield.
  6. Aug 10, 2017 at 9:09 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Sounds like a rock is stuck in the rotor. Remove the caliper with a 17mm socket and remove the rotor. Clean throughly and pru back together
  7. Aug 10, 2017 at 10:33 PM
    Subway4X4
    Lloyd
    NY/NJ
    Hey Matt.
    Don't do what Hunter suggests. At least not initially.
    Do the easy things first, then work your way through the troubleshooting process systematically.
    First try to locate the source of the noise before you remove anything. It may not even be the brakes or in that general area.
    If you feel it's around the wheel/brake area, then pull off the wheel and inspect the area.
    Rotate the rotor by hand to see if you can duplicate the noise to some extent.
    You may hear/feel the rubbing.
    Then check for crud, rocks or a possible bent brake dust shield.
    Then go ahead and try to wash off the area, pry off the rock(s) or re-bend the dust shield.
    If that doesn't work, and the noise continues in the brake/rotor area, then go ahead and start pulling the rotor to further investigate.
    Before messing with the brakes, make sure you have brake cleaner handy.
    Good luck man!
    Tatts521[QUOTED] and Blackout14 like this.
  8. Aug 11, 2017 at 2:48 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    no whistles
  9. Aug 11, 2017 at 3:10 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    If you need help swing by. I've got a pressure washer also.
  10. Aug 11, 2017 at 3:48 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Go home TW your drunk
  11. Aug 11, 2017 at 3:55 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Does it sound like the squealing coming from my truck at the end of this vid? That was a rock between the rotor and backing plate.
    https://youtu.be/Fmj58Hgg8C4
    Blackout14 and The Hunter like this.
  12. Aug 11, 2017 at 4:01 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Pulling the wheel caliper and rotor off is MAYBE an hour job start to finish... id rather pull it all off even if there was nothing in there and make sure there was nothing in there. Im not exactly sure why he needs brake clean for after he gets whatever Is causing the noise out... unless his brakes are covered in oil or severe brake dust there is no meed for brake kleen
  13. Aug 11, 2017 at 4:08 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Okay so have you ever measured the gap between the brake pads and a rotor? Hownthe hell is a rock gonna get in there?:rolleyes:
    Subway4X4 and Blackout14 like this.
  14. Aug 11, 2017 at 4:16 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    :confused: i didn't say it could be in there. The pads practically rest on the rotor. But it is possible to get little pebbles and shit usually as you know itll clear itself. But sometimes there is too much sand.
    Pulling the caliper is to remove the rotor. Instead of fighting with a rock behind the caliper between the dust shield with a screw driver or pry bar take the extra minute to remove the 2 caliper bolts and remove the rotor... way easier in my eyes. Then the shit just falls out.
  15. Aug 11, 2017 at 4:19 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  16. Aug 11, 2017 at 4:36 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Why not run them for your trip? Better mileage and easier for the mountains.
    Nimble9 and The Hunter like this.
  17. Aug 11, 2017 at 5:07 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    About 0.002"(whatever the lateral run out on the rotor is). So very very very very small rock? ;)
  18. Aug 11, 2017 at 6:25 AM
    Subway4X4
    Lloyd
    NY/NJ
    Here's the marquee for this match:
    The Voice of Reason from the You Tube Master Automobile Technician (and Chef)
    VS.
    The Voice of Stupid from the "Professional" Master Mechanic (and LEO)
  19. Aug 11, 2017 at 6:32 AM
    Subway4X4
    Lloyd
    NY/NJ
    It's gonna be funnier than shit if Matt @Tatts521 pulls the caliper and rotor off and cleans it and the noise is still there.
    Matty will probably have to pull the caliper/rotor again to find that tiny, tiny, tiny rock.
    I have a magnifying glass you can borrow Matt.
    LMAO
    stairgod[QUOTED] and Blackout14 like this.
  20. Aug 11, 2017 at 6:37 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Thought about it, but Then I'll have to find a place to put the even bigger 315s :bananadead:
    Nimble9, stairgod and Blackout14 like this.
