NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Sep 1, 2017 at 7:52 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    It's called sarcasm... obviously got your attention
    Tatts521 and Blackout14 like this.
  2. Sep 1, 2017 at 7:56 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    What happened with camping at aoaa?
  3. Sep 1, 2017 at 8:54 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Qué paso?
    Blackout14 likes this.
  4. Sep 1, 2017 at 12:01 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I just paid $9.95 for in flight wifi to catch up on life outside work and all I got was this thread.
    Tatts521 and Lux like this.
  5. Sep 1, 2017 at 12:07 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    10 bucks for WiFi for TWNJBS sound like the worse 10 bucks ever spent
    planters15, HomerTaco and Blackout14 like this.
  6. Sep 1, 2017 at 12:08 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Indeed. If that was all I spent the $10 bucks on.
  7. Sep 1, 2017 at 12:11 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I hope it was not.
  8. Sep 1, 2017 at 12:12 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Wifi should be free in all flights dammit
  9. Sep 1, 2017 at 2:25 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    damn, gas went up 14 cents today, up to 2.69
  10. Sep 1, 2017 at 3:17 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I noticed that. 2.79 at a raceway but there's a quick check / wawa battling it out up the street at 2.43
    Tatts521 likes this.
  11. Sep 1, 2017 at 3:49 PM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    Front locker leaking air? Does your compressor run a couple times if you've got the front locker on?
  12. Sep 1, 2017 at 5:14 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It used to but because the compressor leaked from the factory. I'll have to check with the new compressor. Should be easy enough to test at home. I hope that isn't the case because then I would need to send it back to ECGS to fix, right?
  13. Sep 1, 2017 at 5:43 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Anyone holding a mod day or anything Sunday? I gotta figure out this damn noise. If not, @Tatts521 and I are going to have a noise finding party at my house.
  14. Sep 1, 2017 at 6:35 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Unless the leak it's right at the nipple on the diff
  15. Sep 1, 2017 at 6:45 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    But that wouldn't be sending gear oil out the breather then would it?
  16. Sep 1, 2017 at 6:58 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    If the locker unit has a bad seal, it can over pressurized the diff, sending fluid out of the breather.
  17. Sep 2, 2017 at 12:31 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
  18. Sep 2, 2017 at 3:40 AM
    TNT4X4
    CENTRAL NEW JERSEY
    2006 Tacoma
    @cynicalrider this is what I'm saying. The easiest way to tell since you probably wouldn't be able to hear it leaking inside the diff is it the compressor runs again after the initial turning on of the locker because it's lost pressure. I'm sure with you having recently regeared, all the axle seals and pinion seal have a good tight seal and the breather is just the path of least resistance for the oil to blow out when the air leaks inside the clamshell. The system could be at 100psi, easily enough to blow oil thru the breather tube.
  19. Sep 2, 2017 at 6:13 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I totally understood what you meant. That's why I am hoping it's not the case because I don't want to pull the front diff again.
  20. Sep 2, 2017 at 6:33 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Not sure.
    Maybe cuz of vaccum.... :notsure:
