NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Oct 12, 2017 at 4:47 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    The guy with the garage door opener tangled in his roof rack.
    Your computer skills equal mine:anonymous:
    Maybe a lifense is like one of those life skills credit classes:notsure:
    Who would have guessed.
    Busy at Ants'. Or splitting the atom or something.
  2. Oct 12, 2017 at 4:49 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Haha dick
    04yota, stairgod and Toy4me[QUOTED] like this.
  3. Oct 12, 2017 at 5:06 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    No I said it's very interesting... I know they are anaerobic
    stairgod[QUOTED] likes this.
  4. Oct 12, 2017 at 5:10 PM
    Toy4me
    Tom
    NNJ
  5. Oct 12, 2017 at 5:13 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I don't do torque remember?
  6. Oct 12, 2017 at 5:22 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    HomerTaco and The Hunter like this.
  7. Oct 12, 2017 at 5:27 PM
    Toy4me
    Tom
    NNJ
    Not working right now. No monies for new stuff.
  8. Oct 12, 2017 at 5:41 PM
    evoviii1220
    evoviii1220 Well-Known Member
    Dan
    NJ
    05 4x4 DCSB
    Silver touch up paint
    I always thought 4lo was nicer on the transmission (as long as you’re going slow) and especially on the torque converter as it’s able to lock up being in higher gears and not generate a ton of heat by rolling around at low rpms in hi.
    I know my tranny temp gauge always runs much cooler when I’m crawling on the trail all day in 4lo vs 4hi
    stairgod likes this.
  9. Oct 12, 2017 at 5:58 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    let me know if it's still available, highly interested...
  10. Oct 12, 2017 at 6:47 PM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    Lmao
  11. Oct 12, 2017 at 7:53 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    More rpms to do the same work means less shear of the hydraulic fluid at the pump from a lower pressure drop, or less resistance from the power train. Your engine is exhausting a lot more heat as the trade off.
  12. Oct 12, 2017 at 8:02 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Hmm....I usually don't take them off and I've never had a problem.....I thought it was the anaerobic environment that activated the curing process:notsure:
  13. Oct 12, 2017 at 8:07 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Oh, I guess that discussion was already had
  14. Oct 12, 2017 at 8:14 PM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    @stairgod @V5ioV I think you may be reading too much into this. Loctite is a glue that is in solution in the container. The carrier, which is probably alcohol or water or some other solvent evaporates. Heat accelerates the evaporation. Superglue is an acrylic that uses the moisture in the air to complete the molecular chains and gives off heat in the process. Model or airplane or plastic glues used to use toluene as the solvent; methyl-ethyl-ketone, and other ketones are no longer used except in heavily controlled environments where they burn off the evaporated solvents, and all of these actually dissolve the plastics to become liquids until they evaporate away. Acetone is still used as a solvent as the secondary compounds are far less toxic, and it is actually a naturally occurring molecule.
    Aerobic processes require oxygen to complete. Anaerobic ones do not need oxygen.
    HomerTaco likes this.
  15. Oct 12, 2017 at 9:29 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Went to my family friends place to go and inspect the trailer further. Trailer is in great shape! Looks rough in the pics but its just surface rust. Turns out its actually an M116A2 trailer which weighs in at 740 lbs unloaded. I plan on trimming that weight down a bit more with some trimming of the front possibly to dove tail the front (forget the technical term for doving the front).
    Also if youre buying a trailer don't ever register it in NJ again... Maine does out of state registrations for trailers and to register it for up to 12 years is only $260 for 12 years you have options 1-12 years. Pretty sweet. Trailer will have a plate in 6-8 weeks which isn't terrible. In the mean time Ill be bringing it back and forth from my place to Anthony's to clean up the paint and repaint it. Not sure what color to do
  16. Oct 12, 2017 at 9:34 PM
    worseisyet2come
    worseisyet2come Well-Known Member
    South Jersey
    2007 Tacoma TRD Off-Road DCSB
    Cooper S/T MAXX 265/75/R16 | Bilstein 5100s @ 1.75" | Warn m8000-s | US Offroad Winch Bumper | ProMaxx 4" Step Bars | TRD Exhaust | 4th Leaf via Rear TSB | CompuStar Remote Start
  17. Oct 12, 2017 at 9:42 PM
    worseisyet2come
    South Jersey
    Hmm interesting, I've never heard that. Is it possible the heat or compression from torquing depletes the oxygen from the solution, which then forces the reaction? I've seen spilled loctite (any color) or red loctite that's gone poorly torqued just basically sit and do nothing vs. red loctite given proper torque which cures as expected, then holds substantially.
  18. Oct 13, 2017 at 2:36 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Looking?
  19. Oct 13, 2017 at 5:21 AM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    An automatic transmission is a hydraulic pump with the engine as the power source and the drivetrain as the load. Hydraulic fluid is a nearly incompressible liquid, meaning that it doesn't shrink when pressurized, and doesn't foam when depressurized. The rate of flow through the transmission is higher when using low range. Same load, more flow, less heat.
  20. Oct 13, 2017 at 7:52 AM
    Toy4me
    Tom
    NNJ
    Yes. I have pre-employment testing and an interview with pse&g wednesday for a meter reader job :fingerscrossed:.
    Tatts521, The Hunter and pinochle like this.
