NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Nov 9, 2017 at 5:50 AM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    It's all about being use to it. Come winter I got layers on layer on bibs. I get so use to it when I go home and shower and head out in regular clothes I feel under dressed. On top of dealing with the temps and weather conditions, I actually work for an underground utility so we also have to contend with the frost line and frozen ground.
    Lux[QUOTED] likes this.
  2. Nov 9, 2017 at 6:11 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    feeling cold is just a cause of being underprepared :evil:
    but in all honesty if you have piss poor circulation you are much more susceptible
    tcBob and Blackout14 like this.
  3. Nov 9, 2017 at 6:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    What's this cold and working outside thing? Is that when I walk from my car to my office building?
    tcBob, JJ TACO and HomerTaco like this.
  4. Nov 9, 2017 at 7:01 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    You better RUN to the office to keep warm.
    tcBob likes this.
  5. Nov 9, 2017 at 7:29 AM
    Subway4X4
    Lloyd
    NY/NJ
    Hey Eric - you got a contact name/number. I'll check to make sure its there before I head out later today.
    Thanks!
  6. Nov 9, 2017 at 8:47 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Sean Peets. I spoke to him yesterday he said it would be there.
    Subway4X4[QUOTED] likes this.
  7. Nov 9, 2017 at 8:49 AM
    Subway4X4
    Lloyd
    NY/NJ
    Thanks Eric!
  8. Nov 9, 2017 at 10:32 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    @diabetik81 @TNT4X4 @stairgod any of you guys know if a 4x2 rear drive shaft will work in my truck? It looks similar but Idk about the dimensions if there is no t case
  9. Nov 9, 2017 at 11:05 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    The 2wd driveshaft is not the same length from what I've read.
  10. Nov 9, 2017 at 11:08 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I doubt it. Measure center to center I’m sure it’s longer for the 2wd.
  11. Nov 9, 2017 at 2:04 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    @Lux when I used to drive the garbage truck even tho I was in and out side of the truck which mind you my truck had no heat but I never wore gloves either I can't function in them. Just get use to the weather after awhile. It's all about layers of clothing u wear
    Lux likes this.
  12. Nov 9, 2017 at 3:50 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    It won't work. On the 4x2 trucks the transmission side is splined and that is the slip joint and the second half is solid where on our 4x4 shafts the shaft bolts to a flange on the transfer case and the slip joint is on the second part of the shaft. Also even if it were the same style the shaft would be the length of the transfer case longer than ours
    Hawk373, Nimble9 and Subway4X4 like this.
  13. Nov 9, 2017 at 5:10 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Some tailhousings are really long in 2wd trucks and the 2wd and 4wd trucks have the same rear driveshaft. Early 70s Chevy for example. But not any Toyotas that I know of.
  14. Nov 9, 2017 at 6:25 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Yea fords had long and short tail housings aswell but even if the length was the same the style of shaft itself is different between 2 and 4 wheel drive Toyotas. If he didn't live so dame far away I know where he could get one to borrow until he found one:spy:
    Blackout14 likes this.
  15. Nov 9, 2017 at 6:27 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Btw @stairgod did you every get that one driveshaft of yours retubed? I was talking to someone the other day about that and they were told by axle exchange they don't retube anymore so he had to have a whole new shaft made. He's not super mechanic savvy though so they might have given him the run around
  16. Nov 9, 2017 at 6:29 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    I may know a guy that has retubed a drive shaft or two in his day:spy: I never I mean he never balanced them though but only one ever had a slight shimmy between 60-62 mph the others could have been out of balance but they went into truck with huge lifts and huge tires so everything rattled and vibrated
  17. Nov 9, 2017 at 6:35 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    The hardest part is cutting the ends off. They are actually a cup that fits into the end of the toob. You have to cut the weld without cutting the cup and it has to be perfectly square. Then put them in the new tube, make sure the u joints are timed correctly and weld the ends one with one hot, continuous weld. I never had anything balance honestly because I always thought it would be weird going to a drive shaft shop and having them work on something they didn't make. Like the old saying you don't bring your own eggs to a diner.
  18. Nov 9, 2017 at 6:37 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Never did call them. Still running it and even added a new dent.
    Nimble9 likes this.
  19. Nov 9, 2017 at 6:39 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Nice hahaha
  20. Nov 9, 2017 at 7:54 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    That's what I figured, thanks anyway guys.
