NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Nov 14, 2017 at 8:46 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I could make one there but it looked like you have a large sheet of metal and already have the template shape. I give you monies
    uurx likes this.
  2. Nov 14, 2017 at 9:00 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    does anyone know if the rubber seal on my cap will wear the bed rails down to primer or something? I figure they'll have the same effect as bed liners, any way to prevent this? Not trying to keep the rails mint or anything they're already pretty beat up but I don't wanna have ugly white rails if I take the cap off.
  3. Nov 14, 2017 at 9:08 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Do you have weather stripping on the cap rails?
    Blackout14 likes this.
  4. Nov 14, 2017 at 9:25 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    Im gonna be replacing the old strip on the cap today, but yea its on the cap rails not the bed rails.
  5. Nov 14, 2017 at 9:51 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
  6. Nov 14, 2017 at 9:53 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    :thumbsup:, :sawzall: no mo
  7. Nov 14, 2017 at 10:17 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Thank God, so sick of cut off wheels lol
    The Hunter likes this.
  8. Nov 14, 2017 at 10:22 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    You will wonder how you ever lived without it.:boom:
  9. Nov 14, 2017 at 10:23 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Anyone here w/ a welder able to weld aluminum and want to make a few bucks?
  10. Nov 14, 2017 at 10:31 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I don't doubt it. Now I'm on the hunt for a Hobart 210mvp and a cheap tig . Hopefully I come across a jd2, that would be nice too
    Nimble9 likes this.
  11. Nov 14, 2017 at 11:49 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Maybe Plastidip the top of the rails? Then itd atleast rub the dip not the rail
    Lux[QUOTED] likes this.
  12. Nov 14, 2017 at 12:00 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    This is next on my list.
  13. Nov 14, 2017 at 12:01 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Thats nice! :drool: one day maybe Ill have one.
  14. Nov 14, 2017 at 12:05 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    Yea that's what I was thinking too, I'll give it a shot
  15. Nov 14, 2017 at 12:47 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I'll let you know how it does. I want your welder
    Subway4X4[QUOTED] likes this.
  16. Nov 14, 2017 at 12:47 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Although I have a nice snap on welder to use till I find one, does mig tig and stick
    Tatts521 and The Hunter like this.
  17. Nov 14, 2017 at 2:12 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Cold weather's here so soup and stew time. Did a 6lb pork shoulder in green sauce last week. That's gone as of yesterday so with a little help from chef Mike a big pot of spicy curry and pepper lentil soup is on the stove.
    Tatts521 and diabetiktaco like this.
  18. Nov 14, 2017 at 2:24 PM
    Subway4X4
    Lloyd
    NY/NJ
    Get your own :D
  19. Nov 14, 2017 at 2:27 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Forgot to mention, with SUA and shocks going through the bed I moved the lower shock mounts over the springs which creates a lot of space between the tire and bypass tubes. IMG_3389.jpg
    This is part of the reason why I abandoned mounting the 14" bypasses with my SOA. What I did find out while attempting that setup was you can face the tubes inward without frame contact because of how far the lower mount kicks the shock out toward the wheel. With enough backspace (through wheel backspacing and spacers) you can successfully mount bypasses that have the standard layout.
    It would definitely take a leap of faith as I have little proof. I never fully cycled my mock-up. I've seen only one other example from afar by TC. They used 1.5" spacers, faced the tubes inward using 14" triple bypasses, under bed shock hoops with 285s. And even though they used a SUA, the lower mount had to go so low on the axle it had to stay outboard of the leaf pack.
    Ordering forward facing tubes may be the better option depending on the mounting system you choose and clearance between the tower, hoops, etc.IMG_3390.jpg
    I just started to realize going that route wasn't exactly what I wanted in the end, so I took the leap and ordered the DMZ kit, 16" shocks and designed and built a bed cage and still have virtually all my bed space.
    It's a shameless DMZ copy, but came out very nice considering I went solely off of photo espionage.
  20. Nov 14, 2017 at 2:54 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Goddamn these parts are pretty.
    On a different note, did I mess up with the rear brakes? I ordered a single rear brake line. Am I going to need 2, or is ti just 1 I need? My limited understanding was that one line goes into the BPV and that line is what needs to be extended.
    Arcticelf, Nimble9, stairgod and 2 others like this.
