NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Nov 18, 2017 at 3:29 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Let’s see how much of a mess this FF makes in here...
    Then we’ll talk lol
    The Hunter and Blackout14 like this.
  2. Nov 18, 2017 at 3:38 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I’ve done it with the cans. This will be the first time I’ve done it with the paint gun.
    Nimble9 and Blackout14 like this.
  3. Nov 18, 2017 at 3:48 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Is it really that bad to just use cans?
  4. Nov 18, 2017 at 3:54 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I’m wondering if it’ll coat my leaf springs enough to shut them up.
  5. Nov 18, 2017 at 5:15 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I wish. POs never brought it in for inspection, so I'm SOL even though I'm still in the 15 year window. Idiotic stipulation.
    If it were brought in for frame inspection before the cutoff in 2012, you then get to 15 year from your model year (or manufactur date, nor sure) and it would be coated if it passed and set for replavement if it failed. Could be inspected over and over until that 15 year mark. Only applies to 01-04. Older Tacomas were bought back.
    Indeed possible. I've used it oh squeaky metals before and it worked.
    Yeah the makers say certain rubbers can swell. Another reason to switch to poly bushings!
    Blackout14 likes this.
  6. Nov 18, 2017 at 6:53 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I just realized there is a portable ARB twin compressor. I think I just found my next purchase. Comes with a 1 gal tank too. That should fills tires quick.
  7. Nov 18, 2017 at 7:02 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Yeah I did. Kind of like the idea of it being portable.
    uurx and Blackout14 like this.
  8. Nov 18, 2017 at 7:04 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    My brother got a letter and a call from Toyota the other day. His truck is an 09 and they have a class action suit up to 2010. His frame is good but has a lot of surface rust. He's dropping it off Tuesday and they are gonna remove a bunch of parts and sand blast and repaint his frame. Then he's still covered for a replacement for X amount of years should it get worse. Not sure if it's a dealer specific deal or something toyota is doing to prevent mass frame replacements :notsure:
    sente3, diabetiktaco and Blackout14 like this.
  9. Nov 18, 2017 at 7:11 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    That’s a deal. I’ll sell my single portable and make enough for the dual. I’ll be in Perkiomenville the day after thanksgiving if that helps.
  10. Nov 18, 2017 at 7:19 PM
    sente3
    sente3 -
    North Jersey
    What Joe said, that's news to me. Would be nice if that were the standard procedure.
  11. Nov 18, 2017 at 7:20 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Duuude that sucks, and we were JUST talking about this the other day :bananadead:
    Hopefully it's sorted out, I'm gonna have to quadruple check my frame when I get home I guess.
    If Toyota doesn't do anything for you I'd probably inspect the entire frame and see where the weak spots are, spray or paint the shit out of the inside of the frame with POR and use those auto rust weld on pieces if there's still solid steel around the rust areas. Just my 2 cents
  12. Nov 18, 2017 at 7:26 PM
    sente3
    sente3 -
    North Jersey
    Yeah I know. And here I was thinking I was sitting on the outside of the conversation.
    That's pretty much what my approach is looking like. Patch any weak spots if possible and give heavy attention to everywhere else. Unless there's some better alternative, seems like that's the only direction.
    Toyota won't do anything for me. Last year or so, when I was at a dealer for something, I verified whether or not I was covered under the replacement program and was informed no. My spare tire carrier just busted when I was putting the spare up the other day, so I will need that replaced per recall. Maybe while I am there, I am bother them about the frame and see what they say. But I have no hopes it'll do any good.
    Lux[QUOTED] likes this.
  13. Nov 18, 2017 at 7:33 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    I’ll check PayPal. I think that’s about right.
  14. Nov 18, 2017 at 7:35 PM
    sente3
    sente3 -
    North Jersey
    Yeah I know autorust is one. They sell ones that cup the frame on 3 sides. There are also the plates that go on the sides of the frame either to patch or turn C-channel into boxed. Can't recall who sells them though.
  15. Nov 18, 2017 at 7:40 PM
    sente3
    sente3 -
    North Jersey
    Not surprising. The need to address frames is becoming more and more common as they age and take more abuse. Especially ones that aren't covered by Toyota.
  16. Nov 18, 2017 at 7:45 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    I believe trail gear has a box section kit with crossmember (and shock mounts?) Id highly recommend doing that or somethin similar while you're in there welding things.
  17. Nov 18, 2017 at 7:51 PM
    sente3
    sente3 -
    North Jersey
    Ah yeah I believe they're who I was thinking of. But I think their focus is frame reinforcement rather than frame repair.
    And I won't be welding anything. No experience and no equipment. I'd be paying someone.
    Tatts521 and Blackout14 like this.
  18. Nov 18, 2017 at 8:35 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Shits heavy af
  19. Nov 19, 2017 at 3:48 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    @Chux what size alum tubing did you use for your pole holders?
  20. Nov 19, 2017 at 5:11 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    would really be nice if a company started offering aftermarket frames for first gens
    there is a company called throttle down kustoms who offers beefed up jeep frames
    aside from paying 1500-3000 for a frame alone... i do not see why it is not possible
    here is an article about a 1st gen that had repairs done by a rust technician auto shop in R.I.
    http://www.fourwheeler.com/how-to/body-chassis/1603-toyota-tacoma-rotted-frame-fix/
    this site might have some frames for sale
    https://www.partshotlines.com/parts/toyota/tacoma/frame.html
    I thought years back bud built had been working on building some jigs in effort of getting a frame offered up... :notsure:
