NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Dec 18, 2017 at 11:55 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This. I got married at 27 and even then my wife and I were together for almost 8 years by the time we tied the knot. Don't rush that shit.
    Lux and Blackout14 like this.
  2. Dec 18, 2017 at 12:03 PM
    ADV4R
    ADV4R Well-Known Member
    Toyota 4Runner
    Agreed! That's where I'm at. :burnrubber:
    Lux likes this.
  3. Dec 18, 2017 at 12:36 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Just bring it to toyota you can’t do anything with an auto trans anyways. Needs to be vacuumed
  4. Dec 18, 2017 at 12:37 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Lmfao. I want to settle down but my hobbies and wants don’t allow it. Until then :bananadance:
    ADV4R likes this.
  5. Dec 18, 2017 at 12:40 PM
    evoviii1220
    evoviii1220 Well-Known Member
    Dan
    NJ
    05 4x4 DCSB
    Silver touch up paint
    You can certainly check fluid level, top off, and do drain and fills. So not sure why thats the logical next step.
    The overflow/fluid level check is the bolt with the allen key hex head more toward the front of your truck. The drain is the normal 6 point bolt toward the back...
    Subway4X4 and jrzyshore[QUOTED] like this.
  6. Dec 18, 2017 at 1:02 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Bringing it to Toyota is not the logical next step.
  7. Dec 18, 2017 at 1:14 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Nope
    Subway4X4[QUOTED] likes this.
  8. Dec 18, 2017 at 1:15 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Automatic trans is to be filled via vacuum pump.
  9. Dec 18, 2017 at 1:19 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yup. This. I’ve done a drain and fill twice. Then, I did the IPT valve body. I can just never remember which bolt is which.
    evoviii1220[QUOTED] likes this.
  10. Dec 18, 2017 at 1:22 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    No it is not. It’s filled through the fill hole until it runs out while the truck is running. Then, you get the trans up to the proper temp and remove the level plug, once again while the truck is idling, until it stops running out.
    There is a specific procedure that does not require a vacuum pump.
    Blackout14 likes this.
  11. Dec 18, 2017 at 1:26 PM
    Subway4X4
    Lloyd
    NY/NJ
    I've been doing the drain and refill as preventative maintenance.
    I'm gonna do this DIY fluid flush sometime in the future Scott.
    Temp check procedure is here.
    No need for a vacuum pump.
    I've been doing this mechanic shit for a year and half now (NOT since I was 13 years old.) But I try to gather sensible information when I do something. The two procedures that I linked appear to be sensible.
  12. Dec 18, 2017 at 1:26 PM
    evoviii1220
    Dan
    NJ
    05 4x4 DCSB
    Exactly. Not even sure it needs to be running when filling, just when checking the level it needs to be idling and to operating temp which it will tell you on dash by tripping two connectors.
  13. Dec 18, 2017 at 1:29 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    This is true. Actually, that’s bad information on my part. Poorly worded.
    I measure what I take out and put that amount back in. Then start the truck and top it off while its running until it spills out. Just to get it close.
    THEN, warm it up and set the level.
  14. Dec 18, 2017 at 1:31 PM
    evoviii1220
    Dan
    NJ
    05 4x4 DCSB
    Thats my exact procedure. Im sure no harm in either. I've probably also filled it while running like you said because beers.
  15. Dec 18, 2017 at 2:18 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    But Zyzzyva :anonymous:.
    I'd like to do this too. Maybe trans flush day at my place in the spring.
  16. Dec 18, 2017 at 2:27 PM
    Subway4X4
    Lloyd
    NY/NJ
    Valvoline MaxLife ATF. At Wally World
  17. Dec 18, 2017 at 2:30 PM
    Subway4X4
    Lloyd
    NY/NJ
    Never had an issue with it.
  18. Dec 18, 2017 at 2:34 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    OEM. IPT told me you can’t beat it. Says he’s the first one to upgrade anything, but OEM is best for our transmissions. Who would know better than guys who build performance transmissions?
    Subway4X4 and Blackout14 like this.
  19. Dec 18, 2017 at 3:37 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Stock fluids.
  20. Dec 18, 2017 at 5:40 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    I had this happen to a 96 4runner.Replaced radiator,flushed trans,fluid till i got all the pink out,truck is still running.
