NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 17, 2018 at 3:22 AM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    Doubt it would cause an injury I hardly count a welt as an injury.
  2. Jan 17, 2018 at 3:26 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    http://www.masterpull.com/benefits-of-synthetic-winch-line/
    Read the second paragraph.
  3. Jan 17, 2018 at 3:28 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Okay so. If you ever get a winch with synthetic line we’ll hook it up and put it under a pretty decent load. Then you can stand over the line at one end and I’ll cut it near the other and we’ll see what happens
  4. Jan 17, 2018 at 3:45 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    And then you can buy me a new line... :crazy:
  5. Jan 17, 2018 at 3:51 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Nah. I’m just thinking you have such a strong opinion you shouldn’t have an issue going the extra mile to prove it
    stairgod likes this.
  6. Jan 17, 2018 at 4:02 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Im not going to spend double the money to prove it when there are a bunch of videos showing it online... it may not show what damage it will do but it certainly shows the energy difference when snapping. Everything has some sort of stored energy. Synthetic line is very minimal. It doesn’t stretch much and has a high breaking strength.
  7. Jan 17, 2018 at 4:03 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Wow. Then they are misleading people just like you. Because if that line stored NO energy as stated by you and the referenced article, then it would have dropped straight to the ground when it broke. But it did not, indicating a certain amount of potential energy in the line.
    Can I get back up from a scientist or physicist on this one?
    Bastek, Blackout14 and Nimble9 like this.
  8. Jan 17, 2018 at 4:04 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Both your original statement yesterday and the article you referenced said NO energy...
    Get your shit straight or stfu
    Blackout14 likes this.
  9. Jan 17, 2018 at 4:06 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    And @Wheelspinner , thanks for stirring the pot on this one. Sucked me in like a Mormon at a Teen pageant. Again.
    Dick
    planters15, uurx and Blackout14 like this.
  10. Jan 17, 2018 at 4:18 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
  11. Jan 17, 2018 at 4:19 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    @Wheelspinner - I too, have not personally seen a winch line failure, metal cable or otherwise. But the theory is sound that there IS energy that is accumulated and stored while actively pulling an object with a “static” line.
    My biggest concern is not a line break, (whether synthetic line or metal cable), but what happens if there is a hardware failure at the winching attachment point? (D-ring, winch hook, vehicle recovery hook/attachment) where will that metal go? Will it drop down or become a dangerous missile?
    The big question is: If there is a catastrophic failure of the winch system during an active recovery, is there a possibility of harm to an individual in the direct theoretical path of the winching terminal hardware during failure? And will a damper help stop that possible missile?
    Let’s do an experiment.
    Hunter is absolutely sure that there is NO energy stored in a synthetic line, so maybe he’ll agree to being part of an experiment.
    We will try to simulate a winching scenario where terminal hardware (i.e. metal hook) fails during an active winch recovery.
    I will cover the cost of all materials used in this experiment.
    Part I: NO Damper:
    1. Attach my synthetic winch line to Hunters truck using the winch hook attached to a synthetic soft shackle and then to his truck’s recovery point.
    2. Move my truck 75 feet from Hunter’s truck on the high side of an incline.
    3. Start winching Hunter’s truck until it starts moving. Stop winching.
    4. Hunter (Full size cardboard cutout of Hunter) stand next to the winch line at midway point (35 feet.)
    5. Someone with a very sharp knife ready at your trucks attached recovery point.
    6. Restart winching until your truck moves.
    7. Once truck has moved five feet AND while winching is still happening and truck still moving, someone cut the soft shackle with a quick/clean slice. Cutting the soft shackle will simulate a terminal hardware failure.
    Based on the “ZERO stored energy theory of Hunter,” the winch line and the attached terminal hook/hardware should drop and not even come close to Hunter (Full size cardboard cutout of Hunter)
    So Hunter (Full size cardboard cutout of Hunter) should be able to continue Part II of this experiment...
    Part II: WITH Damper
    Repeat Part I, except attach a weighted damper (~5-10 lbs) five feet from recovery attachment.
    ***edited to change out the real Hunter with a fake Hunter. For safety, of course.
  12. Jan 17, 2018 at 4:20 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Everything has potential energy. For me to say no energy was wrong but the energy is minimal... as long as your tow points don’t fail then the line is not going to hurt you by itself
  13. Jan 17, 2018 at 4:21 AM
    Subway4X4
    Lloyd
    NY/NJ
    Both of you are dicks.
    Quit picking on Hunter.
    He’s always right...
    If he interprets his google research correctly.
  14. Jan 17, 2018 at 4:25 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Find a different truck. Im not into bending frame horns. Winching is for recovery not for experiments. Lets go to a test facility and do this...
  15. Jan 17, 2018 at 4:38 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
  16. Jan 17, 2018 at 4:47 AM
    Subway4X4
    Lloyd
    NY/NJ
  17. Jan 17, 2018 at 4:50 AM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
  18. Jan 17, 2018 at 4:56 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Guys Let me know when this one is over and I kick start the next one: "manual vs queer gears"
    JJ TACO, planters15, uurx and 2 others like this.
  19. Jan 17, 2018 at 5:13 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    In
    Nimble9, Blackout14 and V5ioV[QUOTED] like this.
  20. Jan 17, 2018 at 5:19 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    After the recent failure of Marks winch line, he and I have been discussing a way to remove steel shackles from the equation. For one, I have been unable to locate a shackle stronger than a 4.75 ton WLL. And being able to eliminate an object with significant mass and potential energy from the equation is highly desirable.
    Hooking a soft shackle to the same recovery point where a steel shackle normally resides is problematic because sharp edges and synthetic material do not go well together.
    Also was thinking of removing my winch hook and just using a soft shackle to connect the spliced eye to whatever attachment point I need. My hook always get attached with a soft shackle anyway, so why not eliminate that hunk of aluminum?
    Redmann and Subway4X4[QUOTED] like this.
