NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Jan 22, 2018 at 1:42 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Well, how the hell do you think I’m going to fill the hot tub?
  2. Jan 22, 2018 at 1:46 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    there are natural hot springs out there.. no need to bring one with you
  3. Jan 22, 2018 at 2:36 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    If it’s plugged into the cig outlet will it work without batteries do you know?
  4. Jan 22, 2018 at 3:20 PM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    If you're looking for trailer spares, I've got a couple low tread LRD 315/70R17 BFG all terrains. If you can't turn something up, I figure one of these could at least serve as a trailer spare and you could keep moving matching tires to the truck where it matters.
    I've also been trying to keep an eye out for a 285/70R17 if anyone has one. Need it only as a spare, don't much care tread type, AT MT or whatever, just needs to hold air and be able to get me out of a jam.
    Tatts521 likes this.
  5. Jan 22, 2018 at 3:25 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you Sir. I’ll keep that in mind :thumbsup:
  6. Jan 22, 2018 at 3:27 PM
    fatfurious2
    David
    Ashburn, VA
    I only have one :anonymous:
  7. Jan 22, 2018 at 3:29 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yours is probably a white wall anyway...
    Toy4me likes this.
  8. Jan 22, 2018 at 3:34 PM
    fatfurious2
    David
    Ashburn, VA
    It is not
    Nimble9 and Tatts521 like this.
  9. Jan 22, 2018 at 3:50 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    :D
    fatfurious2[QUOTED] likes this.
  10. Jan 22, 2018 at 3:54 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    @Subway4X4
    Check it out Floyd. I finally found a use for this damned thing :thumbsup:
    Blackout14 and Subway4X4 like this.
  11. Jan 22, 2018 at 4:23 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    That sucks.... it's harder and harder to find nice clean wheels lately... I liked those wheels.
    Mostly these days is obnoxious fake deadlocks with fake beadlock rings and fake bolts...
  12. Jan 22, 2018 at 4:52 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Does anyone here ever rev match? Specifically down shifting, is it even possible to heel/toe it?
  13. Jan 22, 2018 at 5:04 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    I always rev match and I never “heal toe”. Rev matching is habit now after years of driving big trucks with non synchro transmissions.
  14. Jan 22, 2018 at 5:05 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    When I had a manual car, yeah I would rev match while downshifting. I do it on my bike too.
    JJ TACO and Lux[QUOTED] like this.
  15. Jan 22, 2018 at 5:06 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    I just started doing it so Im an amateur, how do you hit the brakes and blip the throttle at the same time if you don't heel toe it?
  16. Jan 22, 2018 at 5:08 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Steve, correction ^^^ you CAN recharge the batteries with the provided power cable. The reason I decided not to do it this way, is because there is no true protective charging circuitry in the radio to sense when to stop charging. You’ll need to remember to unplug when you “think” the charging is complete.
    I use an automatic charger that makes sure I don’t overcharge my relatively expensive rechargeable batteries.
    According to the manual, yes.
    Wheelspinner[QUOTED] likes this.
  17. Jan 22, 2018 at 5:09 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    I never heal toe. So there would be no braking while blipping the throttle. I would anticipate the stop and just push the clutch in, match the rev, down shift, release the clutch
  18. Jan 22, 2018 at 5:12 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I like these wheels, but I have them because they were the cheapest black wheels, with the correct specs, that DDT had at the time. I knew I would just tear them up on the rocks, so I wasn’t too picky.
    I hear you though. There are some terrible looking wheels out there. I like simple.
  19. Jan 22, 2018 at 5:13 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    To be honest, I didn't even know the process of heel/toe when you asked. I googled it and the first video that popped up really explained it pretty good. It was titled something like learn how to heel/toe in under 2 mins.
  20. Jan 22, 2018 at 5:17 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    What I love about my f5s is the simplicity
