NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Mar 27, 2018 at 7:48 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Not mine, sorry. Island Toyota in Staten Island, NY had issues that I had some mus, scrapes and scratches on underbody.... Can't imagine them not asking silly questions
  2. Mar 27, 2018 at 2:53 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    I might need a new driver side lca. Where should I buy from that stocks them
  3. Mar 27, 2018 at 6:41 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    OEM?
  4. Mar 27, 2018 at 6:50 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    I think I have two OEM ones boxed away. Had two sets, sold one, can't remember if they're the set that needs new bushings or the good set. I'll check tomorrow and let you know, if that helps.
    Tatts521[QUOTED] likes this.
  5. Mar 27, 2018 at 6:59 PM
    Tatts521
    Thank you. Sounds good I can always buy new bushings.
  6. Mar 27, 2018 at 7:09 PM
    evoviii1220
    evoviii1220 Well-Known Member
    Dan
    NJ
    05 4x4 DCSB
    Silver touch up paint
    What makes you think you need a new one? Isn’t your truck relatively new?
  7. Mar 27, 2018 at 7:11 PM
    Tatts521
    Last off road trip smack the fuck of my lca been squeaking since then.ive done everything possible to get it from that. Pretty positive it's the cause of it
  8. Mar 27, 2018 at 7:23 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Due to financial issues, decided to just go ahead and re gear since I won't be able to swap in d60s for a bit. Anyone think 5.29s will be too much with a 6 spd manual? Gonna buy new shoes either 35 or 36". @cynicalrider any regrets?
  9. Mar 27, 2018 at 7:27 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    4:88 for auto 2nd gen V6 on 35’s.
  10. Mar 27, 2018 at 7:30 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    :confused: I got a m/t. I'd rather sacrifice highway speeds and crawl a little better up the rocks
  11. Mar 27, 2018 at 7:31 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Plus I been towing a trailer with two snowmobiles almost every weekend up the mountain and could use the torque
  12. Mar 27, 2018 at 8:40 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You will hate life if you go higher than 4.56 gearing with a manual trans. Even 4.88 is too much.
    You wanna crawl? Do dual cases. ;)
  13. Mar 28, 2018 at 6:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I love my 5.29's but IIRC the final drive ratio for you guys are much much different from ours. At 75 mph my rpms are in the 3500 range, I would not want that any higher. Gotta defer to the 2nd gen guys for that one, sorry Ryan. :p
  14. Mar 28, 2018 at 8:14 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I would not go down this path with a 2nd Gen taco. The power train is not designed for this and spinning the 4.0 at 3000 to 4000 rpms on the highway will produce a ridiculous amount of waste heat. Homer is right on this:
    Based on what you stated, I would have a smaller diameter set of tires for towing, and toss the larger set on the trailer, then have the crawl box for serious crawling. The alternative is adding a large fuel tank to the trailer.
    The Taco 4.0 set up is under-appreciated for the amount of power and torque it delivers at low rpm, but that comes at the price of high losses at high rpm.
    Subway4X4 and HomerTaco[QUOTED] like this.
  15. Mar 28, 2018 at 9:24 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Do you know the model your transmission is. Example mine is a R155f
  16. Mar 28, 2018 at 10:12 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    IIRC it's the R150F
  17. Mar 28, 2018 at 12:17 PM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    Ditto, couldn't be happier with the 5.29's and 35's. Also on a first gen though
  18. Mar 28, 2018 at 12:18 PM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    That trans is super similar to mine. Here is an awesome reference for figuring this kinda junk out. @Sub-Zero play with this a little and it will give you a good idea what you wanna do.
    http://www.grimmjeeper.com/gears.html
    Enter your trans, transfer case, gear ration and tire size and it gives you crawl speeds and highway speeds and rpms formeach gear. It’s pretty neat.
    HomerTaco and Fifthwind like this.
  19. Mar 28, 2018 at 2:19 PM
    TNT4X4
    TNT4X4 Well-Known Member
    CENTRAL NEW JERSEY
    2006 Tacoma
    285/75R17 on methods, Icon RR front with UCA, dakars with fox 2.0's out back. CBI Dakar Hybrid with homemade 1/4" skids. 4.56's with ARB.
    ^^^ what Steve said, I've had a lot of people with jeeps come to me looking to regear with no idea what ratio to go to and this is an awesome tool to use to help them sort it out
  20. Mar 28, 2018 at 2:21 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Browser issue...I'm trying to find a workaround. Appears to happen you're viewing a post like that (quoted, with a YouTube), go to another program, then come back to the browser.
    Nimble9[QUOTED] likes this.
