NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Aug 4, 2018 at 7:20 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Nope. It’s the torch that came with the unit.
  2. Aug 4, 2018 at 7:21 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Looks different than mine. Probably just different colors.
  3. Aug 4, 2018 at 9:16 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Straight edge & adjust the power and air like Tim said.
    I’m no metal fab guru but I’ve used one with pretty consistent results.
    Takes some practice.
    HolyHandGrenade likes this.
  4. Aug 5, 2018 at 4:58 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    @Subway4X4
    I tried using a stand-off too. I didn’t like it. Make sure it’s not keeping the tip from touching the cutting surface.
  5. Aug 5, 2018 at 7:09 AM
    Subway4X4
    Lloyd
    NY/NJ
    @Lux @JCjeeper ive busted out the plasma and welder. Come on over if you want to do some welding.
    JCjeeper likes this.
  6. Aug 5, 2018 at 7:10 AM
    Subway4X4
    Lloyd
    NY/NJ
    Mine’s a Pilot Arc cutter, so the stand-off is supposed to keep the tip from touching the surface.
    At least that’s how I understand it
  7. Aug 5, 2018 at 7:17 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Like I said. I’m no expert. I can only tell you how mine works best for me.
    Subway4X4[QUOTED] likes this.
  8. Aug 5, 2018 at 7:27 AM
    Subway4X4
    Lloyd
    NY/NJ
    Just pulled the front 1/4” reinforced steel IFS skid. Took all of 7 minutes. This goes back on the truck in October, my next RC or AAOA trip.
    It looks pretty exposed down there, so I’m thinking about fabbing a skid using 1/8” steel that I have laying around. At least I’ll cut the ~90 lb weight in half for DD.
  9. Aug 5, 2018 at 7:32 AM
    Subway4X4
    Lloyd
    NY/NJ
    Doing an oil change and always pull my catch can canister and it was 2/3 full.
    The bottle is about two years worth of funky oil that the catch can accumulated.
    JJ TACO likes this.
  10. Aug 5, 2018 at 7:53 AM
    Subway4X4
    Lloyd
    NY/NJ
    Premium Wally World 5w-30 inbound!
    U-bolt likes this.
  11. Aug 5, 2018 at 8:33 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  12. Aug 5, 2018 at 8:37 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Lost interest in the used 3rd Gen aluminum one?!
  13. Aug 5, 2018 at 8:38 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Some plasmas have a drag tip, others do not. The actual tip should never be in contact with the work.
    :confused:
    You do realize that your truck came stock with a splash guard that woukdwou protect against anything larger than a beetle. Exactly wtf are you going to need a skid for on the street?
    Hey, it's your truck, your time, and your material. But still had to ask.
    Chux likes this.
  14. Aug 5, 2018 at 8:56 AM
    Subway4X4
    Lloyd
    NY/NJ
    Bare bottom looks horrible with my plate bumpers.
  15. Aug 5, 2018 at 8:59 AM
    Subway4X4
    Lloyd
    NY/NJ
    My freehand control is getting better.
    And I think I dialed in the Amps/PSI/speed for 3/16” mild steel.
    Cut looks a lot cleaner than last night’s first attempt.
    U-bolt and stairgod like this.
  16. Aug 5, 2018 at 9:28 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    You basically have to learn to adjust cutting speed to amperage/material. You will learn what the sweet spot is through familiarity. Much like weledin in the respect of travel speed. Higher amperage/faster travel speed. Lower/slower.
  17. Aug 5, 2018 at 12:02 PM
    JCjeeper
    JCjeeper Member
    Jeremy
    2016 Jeep JK
    3 inch BDS lift 35x12.5x17 bfg mud terrains Go industries front bumper body armor rear bumper smittybilt sliders
    Thinking about Changing my name to iceberg… What do u all thing
    stairgod, Lux, Bastek and 1 other person like this.
  18. Aug 5, 2018 at 12:06 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I think you're in the wrong neighborhood is what I think...
    :stirthepot:
    stairgod, Subway4X4, Lux and 2 others like this.
  19. Aug 5, 2018 at 1:32 PM
    Subway4X4
    Lloyd
    NY/NJ
    Swingout mounted 2” receiver for my bike rack:
    Plasma cut 2” receiver to fit the vertical brace.
    Welded receiver to c-channel vertical brace.
    Welded assembly to upper and lower swingout cross-members and rattle canned black.
    Bike mounted on bumper receiver doesn’t allow swingout to open. Vvv
    With this mod, I can leave bike on rear rack and open the swingout for bed access. Bike rack/bike pics later. Paint is still drying.
    @Nimble9 ;)
    JCjeeper, MY50cal, JJ TACO and 4 others like this.
  20. Aug 5, 2018 at 2:00 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's a neat idea.
