NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Aug 24, 2018 at 10:07 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Same chit
    Different shovel.
    I peep j0hny5’s build thread. What a transformation. Beastmodeengauged
    JLink[OP] likes this.
  2. Aug 24, 2018 at 10:07 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    Lmao.
    Where the grass is green and girls are pretty
  3. Aug 24, 2018 at 10:21 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Haha yeah it's come a long way since the pine barren days!
    JJ TACO, V5ioV and w00dy[QUOTED] like this.
  4. Aug 24, 2018 at 10:32 AM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    The good ole days
    Twerking like bawses
    D3A2B9B6-E138-4734-84DF-D0A9403A4C2A.jpg 95A91E45-E84D-4685-A850-C52B5C12A43D.jpg E48F41BA-B50A-4709-82E9-37DE8B145798.jpg
  5. Aug 24, 2018 at 12:15 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    This os AGES ago.....
    w00dy likes this.
  6. Aug 25, 2018 at 7:36 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Rest In Peace Captain John McCain.
    JJ TACO, Bastek, Lux and 4 others like this.
  7. Aug 26, 2018 at 11:23 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    20180826_142028.jpg which one of you is spying on me?
    :spy:
    Tatts521 likes this.
  8. Aug 26, 2018 at 2:20 PM
    Subway4X4
    Lloyd
    NY/NJ
    See ya in a coupla hours
    JJ TACO and Grand dude like this.
  9. Aug 26, 2018 at 3:36 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    :wave: Anyone have a passenger side second gen spindle? Asking for a friend :anonymous:
    V5ioV likes this.
  10. Aug 26, 2018 at 4:03 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Anyone interested in a set of Camburg Ball Joint Arms? They have about 4K miles on them.
  11. Aug 26, 2018 at 6:28 PM
    Subway4X4
    Lloyd
    NY/NJ
    Why hello there...
    Toy4me, Cooktop86 and Anchovy like this.
  12. Aug 26, 2018 at 6:44 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I may. Text me in the AM & remind me to look.
  13. Aug 28, 2018 at 5:38 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    I’d appreciate your guys thoughts here...
    I’ve basically disassembled my entire front end, replacing upper and lower ball joints (Moog), inner and outer tie rod ends (Moog), CV axles (new from Napa) all due to NY rust.
    My new to me truck has a new frame but the front has clearly seen 15 years of NY salt.
    While I’m in here should I just go ahead and get new bearings pressed in? If so does anyone have a relatively quick source for quality bearings?
    Truck only has 63k on it FWIW.
    Also, is there anything else you guys would do while you’re in here?
  14. Aug 28, 2018 at 5:48 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I would...
    Are you replacing lca bushings while you are at it too? I would.... like this you basically fresh to socks
  15. Aug 28, 2018 at 5:54 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Aren't the lcas replaced with the frame swap? @avw4x4 I'd at least make sure all the lca alignment cams and bolts are well greased.
  16. Aug 28, 2018 at 6:06 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    It’s a little hard to tell. Based on the condition of the LCA’s vs the UCA’s I’d guess they were replaced with the frame.
    And good call, I was considering replacing the alignment cams and bolts with greasable ones too.
    Also eyeing the JBA UCA’s... money tree is getting a bit sparse though :oops:
    Toy4me likes this.
  17. Aug 28, 2018 at 6:10 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Keep the oem cam bolts. The greasable ones are garbage
    planters15 and Arcticelf like this.
  18. Aug 28, 2018 at 6:17 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Thank you! In that case I’ll just wire wheel and repaint the cam tabs too.
  19. Aug 28, 2018 at 6:54 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    At 63k, no those bearings have a good 150k left on them, don’t bother.
    Should have gotten new lca’s with the frame so you are good there, just anti-seize the hardware. Oem hardware is best there. Biggest thing to watch for on our trucks are lower ball joints, and you should go oem. They typically can last 100k or so though. Get new bolts if you replace them. Lbj failure on a first gen can mean a new spindle, cv, and steering rack if it goes.
    Lux likes this.
  20. Aug 29, 2018 at 3:20 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    This ^^^^^^
    They are a great concept but horrible design/materials
    Arcticelf likes this.
