NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Sep 25, 2018 at 5:56 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Yea I’d do all the plugs and replace the coil in question. Have you tried switching that coil with one from another cylinder to see if the problem follows it?
  2. Sep 25, 2018 at 6:03 AM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    this!
    Subway4X4 likes this.
  3. Sep 25, 2018 at 6:16 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    We use a combustion leak detector to check this.
    https://www.amazon.com/Block-Tester...1-spons&keywords=combustion+leak+tester&psc=1
    You remove your rad cap and put this guy there. Then run the engine and pump the bulb a few times. If there are exhaust gasses passing through the head gasket into the coolant system, the fluid will change color.
    JLink[QUOTED][OP] likes this.
  4. Sep 25, 2018 at 6:16 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Right. If you’re feeling ambitious. Put the plug, coil, and injector in different cylinders on the other side of the engine. You’ll know what your problem is by which cylinder the misfire moves to.
    I would replace the bad one and carry a spare.
    Subway4X4[QUOTED] likes this.
  5. Sep 25, 2018 at 6:16 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Double this.......
    If you just replace plugs and coil you are not sure where the problem is/was.
  6. Sep 25, 2018 at 6:18 AM
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Exactly. And if you move the coil and the problem is still #5 then you know you need to dig deeper. (Both into the engine and your pocket) I’m willing to wager it’s the coil though.
    V5ioV and Subway4X4 like this.
  7. Sep 25, 2018 at 6:29 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I’ll take that bet. How does one nickel sound?
  8. Sep 25, 2018 at 7:31 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    :popcorn: for an actual real good bet
  9. Sep 25, 2018 at 7:31 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Ok. That’s what I’ll do. Plus it’ll save me $250 in coils.
    My plan is change all the plugs and switch #5 to another cylinder. And see how that goes.
    I bought a big tube of Die-electric grease as well to help deal with water issues. Any recommendations on how/where to apply this stuff?
    Thanks guys for all the input. All this shit is new to me, except changing spark plugs at 100k miles.
    04yota likes this.
  10. Sep 25, 2018 at 8:09 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Placed an order from wheeler's last night right before they closed and still have not gotten shipping confirmation...... wheeler's sucks... they better send me extra candy
  11. Sep 25, 2018 at 8:16 AM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    Change just the coil to another cylinder B4 changing plugs.That way you know its the coil and not one of the plugs.
  12. Sep 25, 2018 at 8:29 AM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    Got to love the root beer barrels
    V5ioV[QUOTED] likes this.
  13. Sep 25, 2018 at 11:06 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    pulled this of another TW thread, figured yall may not have seen it so here it is for whatever it is worth...
    pinochle, JJ TACO and Subway4X4 like this.
  14. Sep 25, 2018 at 11:25 AM
    Subway4X4
    Lloyd
    NY/NJ
    Where’s the original thread?
  15. Sep 25, 2018 at 11:33 AM
    uurx
    '12 t|x pro
  16. Sep 25, 2018 at 12:01 PM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    :eek:
    That’s a good price on coil packs. I believe Toyota charges over $100
    I put dielectric grease in the tip of the coil pack where it seats on the spark plug, on the rubber boot where it seals, and on the electrical connection. I also put a bit of anti seize on the threads of the spark plug.
  17. Sep 25, 2018 at 2:16 PM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    not_nick likes this.
  18. Sep 25, 2018 at 3:00 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
  19. Sep 25, 2018 at 4:17 PM
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Trasharoo for sale. Tan is harping my feng shui
    Nimble9 and Subway4X4 like this.
  20. Sep 25, 2018 at 4:24 PM
    Subway4X4
    Lloyd
    NY/NJ
    I don’t think it’s banning people. I think it’s banning the import and sale of non-FCC authorized VHF/UHF radios.
    Bastek[QUOTED] likes this.
