NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Apr 17, 2019 at 11:18 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Tom responds to most emails I’ve sent within the hour.
    This might help, 17s with plenty of room.
    92E1E351-5CA1-4297-9133-05F0730D2A8D.jpg 2C30BBD5-7A58-45BE-B921-5367AC99F111.jpg 1E447BDD-6626-457C-ABC7-E01DAE95471A.jpg
  2. Apr 18, 2019 at 4:17 AM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Looks like 16s might still work
    Hawk373[QUOTED] likes this.
  3. Apr 18, 2019 at 4:27 AM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Are you running the 4runner kit now?
  4. Apr 18, 2019 at 4:58 AM
    WickedWendy
    WickedWendy Well-Known Member
    Yes. He plans on swapping to the bigger discs and calipers when these pads are done. Will replace the front rotors at the same time as they are almost toast.
    Smooth rotors are the best bet if your truck sees mud often. The slots and holes seem to hold dirt and cause all sorts of pad/rotor wear. Lesson learned.
    V5ioV[QUOTED] likes this.
  5. Apr 18, 2019 at 5:06 AM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    Got my spc bushing kit in and new ball joints hopefully the rain holds off this weekend and i can get this all done. Also installing new rotors and pads. While i have everything torn apart. And hopefully the squeaky front end noise disappears. Keeping my fingers crossed on that
    WickedWendy likes this.
  6. Apr 19, 2019 at 4:47 AM
    Tatts521
  7. Apr 19, 2019 at 10:43 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Use plenty of anti-seize, it is also a thread locker. I placed a washer on either side of each bushing on the UCA, that also serves to compress the bushings when the bolt is tightened. I spread the ucas about a 1/16 to an 1/8 using a floor Jack, in order to fit the washers in, test fit before you spread, and take it extra easy with the Jack if you try this, as I do not know an easy way to squeeze the legs back, and the bolt is not strong enough to pull them in. A vertical press might bend them back?
  8. Apr 20, 2019 at 3:56 AM
    Tatts521
    I will try this. Thank you sir
  9. Apr 21, 2019 at 12:12 PM
    WickedWendy
  10. Apr 21, 2019 at 1:21 PM
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
  11. Apr 21, 2019 at 2:04 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
  12. Apr 21, 2019 at 2:43 PM
    The Hunter
    Hunter
    Monroe NJ
    2011 Submarine
    Interested? Not sure if sarcasm. I didn’t see anyone from in here in the thread.
  13. Apr 21, 2019 at 5:45 PM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
  14. Apr 21, 2019 at 5:46 PM
    steele-taco
    james
    Jersey shore
  15. Apr 21, 2019 at 10:56 PM
    steele-taco
    james
    Jersey shore
  16. Apr 21, 2019 at 11:06 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  17. Apr 21, 2019 at 11:18 PM
    steele-taco
    james
    Jersey shore
    Yes, is there a problem with that?
    E-Paz 732NJ likes this.
  18. Apr 21, 2019 at 11:22 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Yeah, it’s not going to change things. Posting a thread and then cross linking it isn’t going to to change what is done. Doing what you’ve done only further exasperates the issue and situation.
  19. Apr 22, 2019 at 8:01 AM
    JLink
    JLink [OP] Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    People being upset about losing a member of our community “exasperates the situation”??
    Exacerbates?
    How?
    Oh yeah, we can’t speak our opinions anymore right?
    E-Paz 732NJ, uurx and Tatts521 like this.
  20. Apr 22, 2019 at 8:34 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Welcome to communist TW comrade.
