NJ B.S. Thread
Discussion in 'North East' started by JLink, Apr 24, 2013.
  1. Dec 6, 2018 at 2:32 AM
    MY50cal
    MY50cal - IPFK -
    Mojo
    Chester County, PA
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Anyone ever come across wear marks like these in their front diff case before? Searched the interwebs for a few days, didn't find anything similar. Worn bearings was my first guess... no visible marks on the drive gear though :notsure:
    Getting new gears and full rebuilds so I'm not concerned, just curious.
  2. Dec 6, 2018 at 2:34 AM
    HomerTaco
    HomerTaco Chillin & Grillin Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    o_O
  3. Dec 6, 2018 at 5:31 AM
    MY50cal
    MY50cal - IPFK -
    Mojo
    Chester County, PA
    Yep.
    Maybe they're machined for clearance, I have no idea lol.
    HomerTaco likes this.
  4. Dec 6, 2018 at 5:33 AM
    JCjeeper
    JCjeeper Member
    Jeremy
    2016 Jeep JK
    3 inch BDS lift 35x12.5x17 bfg mud terrains Go industries front bumper body armor rear bumper smittybilt sliders
    That things a boat
  5. Dec 6, 2018 at 6:15 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Bumpers, rack, backseat deck(for the dog!) Backup lights, fog lights
    Does anyone have any experience with these?
  6. Dec 6, 2018 at 6:33 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Definitely looks fly cut.
    MY50cal likes this.
  7. Dec 6, 2018 at 6:34 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I was looking into those. Only issue I found was very limited wheel travel.
    Skierrichy likes this.
  8. Dec 6, 2018 at 6:41 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    That's what I see also, may need a modification but try to find someone who actually uses them.
  9. Dec 6, 2018 at 6:45 AM
    Blackout14
    Blackout14 Instagram: @The_Crippled_Angler Vendor
    Joe
    Hatfield pa
    2014 DCLB TRD Sport
    they are very similar to what came on my trailer from the factory mine just has a cross bar as well attaching the two together. they only have a few inches of up and down travel which is normally fine for me. But you need to keep some weight on them or they tend to bounce around alot. Bigger tires helps alot with that my 33's cut down on alot of bouncing when its empty i just run lower psi. Other then that ive had no problems with the torsion system
  10. Dec 6, 2018 at 7:06 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    A Truck
    Some Stuff
    I almost put those on my trailer. I wasn’t worried about Wheel travel. You don’t really suff tires on a single axle trailer. It just pivots at the hitch.
    My setup with shocks works great on and off road though. I don’t see any reason to drop the coin on the independent ones.
    IMHO of course.
    Blackout14 and Skierrichy like this.
  11. Dec 6, 2018 at 7:14 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    I have to replace everything except the axel I haven't compared prices yet but seems much easier and faster to deal with.
    Still not sure if I am going this route though.
    HolyHandGrenade likes this.
  12. Dec 6, 2018 at 7:25 AM
    steele-taco
    steele-taco Well-Known Member
    james
    NE PA
    17 TRD OR DCSB white
    The independent ones should give you more center ground clearance Clarance.
    Probably not an issue unless your getting real crazy. Just something to consider.
  13. Dec 6, 2018 at 7:44 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    A Truck
    Some Stuff
    If you’re running the same size tires as your truck, and why wouldn’t you if you’re building an off-road trailer, you’re already going to have more clearance than the tow vehicle.
    Also, once you put that tie in rod across, it’s way less a factor.
    stairgod, Grand dude and Skierrichy like this.
  14. Dec 6, 2018 at 8:58 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    I’ll need to get a trailer axle with 6-lug hubs so I can match wheel/tires to my truck.
    I’ve never done this before.
    Source of axle?
    How do I measure axle length?
    Cheaper is better.
    Any help is appreciated.
    Grand dude likes this.
  15. Dec 6, 2018 at 9:01 AM
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    a cool sticker and a baseball card With clothes pin, sounds awesome ! wicked
    JCjeeper likes this.
  16. Dec 6, 2018 at 9:05 AM
    Blackout14
    Joe
    Hatfield pa
    2014 DCLB TRD Sport
    ^^this is the same length i sent you awhile ago. measurements are made to the hub faces ;)
  17. Dec 6, 2018 at 9:08 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    That's where I can't make up my mind...
    I feel as though I'm going to trash it if I take it offroading, minor towing experience, all I see is jackknife everytime I gotta backup.
    I am more leaning towards a base camp right now.
    HolyHandGrenade and Grand dude like this.
  18. Dec 6, 2018 at 9:12 AM
    Grand dude
    Dave
    lehigh valley, PA.
    id still go with same size tire, no need to have 2 different spares, also can match up with your current setup
    HolyHandGrenade and Skierrichy like this.
  19. Dec 6, 2018 at 9:15 AM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Custom trailing arms with air bags.
    I need to draw them up in Fusion360
    HolyHandGrenade and Blackout14 like this.
  20. Dec 6, 2018 at 9:17 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    A Truck
    Some Stuff
    I can never remember where I ordered my custom axle. Joe has the link. @Blackout14
    Measure the width of your trailer at the widest point the tires need to clear. Lay one of your mounted tires face down. Lay a straight edge across the tire and measure the back spacing (including tire obviously). Multiply by 2 and add to trailer width. Decide how far you want the back of the tire to be away from the trailer. Multiply by 2 and add to last total.
    That’s your axle width.
    Clark27 and Blackout14 like this.
